Dislikes: 0
Recommendations for removing acid rain spots
I recently purchased a Flex 3401 along with the Pinnacle swirl remover kit to remove the swirls and acid rain spots on my metallic black BMW 1 series. The Pinnacle Advanced Swirl Remover did a great job removing the swirls in my paint but did not work on the acid rain spots on the hood, roof and trunk.
What do I need to try as a next step to remove the spots? A more aggressive pad (I used the CCS orange light cutting pad) along with a compound? Any recommendations would be appreciated.
Super Member
Re: Recommendations for removing acid rain spots
What speed were you using the Flex on? A higher speed and more slower passes might solve the problem.
Super Member
Meg's 105 and your ccs orange pad should cut it. Did you try a water spot remover?
I ran the Flex at 5 making 6 slow passes. I didn't try a water spot remover because it looks like the spots are etched in the clear. Will a spot remover help?
Super Member
I would pick up some M105. It has more cut than Pinnacle Advanced Swirl Remover. If M105 does remove them, wet sanding may be your only option.
I assume M105 followed by M205 then a wax? Would you use the M105 with an orange pad on 5 and the M205 with a white pad at 4?
Super Member
If you can stand 6, use speed 6. The rest sounds good.
Super Member
Yes M105 on an orange pad at 5-6. Then depending on how well M105 finished, you can either go to M205 with a white pad to remove either hazing/micro marring left behind or use a black pad with M205 if little finishing is needed. Use M205 on speed 4.
Similar Threads
By Ryan Bishop in forum Off-Topic
Last Post: 06-30-2017, 07:13 PM
By JChastain in forum Wet-Sanding, Cutting & Buffing
Last Post: 04-04-2017, 09:27 PM
By MONSTERMATT in forum Ask your detailing questions!
Last Post: 02-21-2017, 03:32 AM
By kc's in forum Show N' Shine
Last Post: 05-09-2011, 01:17 PM
By antennahead in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 01-24-2007, 12:29 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
