Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Super Member andrew b's Avatar
    Join Date
    Sep 2011
    Posts
    277
    Post Thanks / Like
    Scuffed/scraped leather seat repair - Grey Dakota in 2007 BMW 335i
    One of the only cosmetic flaws on my car, other than some mild swirls and RIDS, when I bought it as a CPO in June were some scuffs/worn color spots on the driver's side seat bolster.
    I finally got around to fixing it. I used a bottle of Color Flex from Magic Mender. They have a great selection of color tints to match factory color codes, and you can buy either the entire kit with the repair compound and the Color Flex, or just the Color Flex itself. I didn't get the whole kit, since I have no tears or holes in my seats. (Note: I would have bought something from Autogeek, since they are my go-to place for detailing supplies, but I couldn't find anything to do what I needed)
    The Color Flex is water-based and can be applied with a foam brush, or a cloth, or pretty much anything you'd use to apply paint or stain. I used a small foam brush. It goes on easily, and dries to the touch within about 10 minutes. According to the instructions, it cures in about 24 hours. This was consistent with what I experienced.
    My grey color went on and appeared lighter before it dried, and after the second coat it is pretty much an exact match to my leather. You can see the edges if you are extremely close and know where to look, but part of that might also be the fact that my car has had 4 1/2 years to age.
    I am quite pleased with the results, it was an easy fix, looks great, and didn't cost much. Here are some before/during/after photos:
    What I got - the bottle of Color Flex and 3 foam brushes - $24.95 + 7.45 shipping.
    Seat damage: The color was worn off, along with most of the grain texture, but not much more than that. Note in the third picture, at the very top you can see where I put just a bit of the Color Flex on to test. It's just a dab, without blended edges.
    Immediately after the first coat - you can see it's still damp. because the Color Flex is water-based, it's easy to control and dries very thin.
    And here it is after the second application, with a dry time of about an hour. Note that I turned on my work lights since I was doing some other detailing, and forgot to turn them off when I took the photos. The work lights are causing that orange-ish glow on the side of the seat. The color match is actually much better that it appears in the photo - the flash really emphasizes the difference (partly also due to the texture difference, as well, since the grain is worn off).
    As I said, overall I'm very pleased with the result. I'd recommend the Color Flex if you need to cover worn or damaged spots, and I would personally get the full kit to try if I had to fix a tear or hole.
    andrew b
    2007 BMW E93 335i Monaco Blue Metallic / Grey Dakota
    2009 Lexus RX-350 Obsidian Black / Ivory
  2. #2
    Super Member oldmodman's Avatar
    Join Date
    Sep 2007
    Posts
    2,563
    Post Thanks / Like
    Re: Scuffed/scraped leather seat repair - Grey Dakota in 2007 BMW 335i
    What a find!
    That stuff does a really great job. I think I'll get a bottle for my car since I have both scuffs and edge wear like yours.
    Thanks!
  3. #3
    Super Member shoeless89's Avatar
    Join Date
    Jul 2010
    Location
    Union, KY
    Posts
    1,985
    Post Thanks / Like
    That turned out amazing! I don't have leather seats but I have some friends that would love this!
    Sent from my DROID Pro using Tapatalk
    Rule 62: Don't take yourself to d*mn seriously
    Cincinnati, OH
    Shawn
  4. #4
    Junior Member Acer9103's Avatar
    Join Date
    Aug 2006
    Posts
    83
    Post Thanks / Like
    Where can I purchase that?
  5. #5
    Super Member
    Join Date
    Sep 2010
    Location
    Southern Kalifornia
    Posts
    301
    Post Thanks / Like
    WOW that turned out awesome. I think I will be ordering some to that for my 2 cars just for the wear spots that look like yours.
  6. #6
    Super Member slickooz's Avatar
    Join Date
    Nov 2010
    Location
    New Jersey
    Posts
    2,657
    Post Thanks / Like
    Looks GREAT!! Going bookmark their page. Thanks!
    Gary
  7. #7
    Join Date
    Sep 2011
    Posts
    277
    Post Thanks / Like
    Quote Originally Posted by Acer9103 View Post
    Here's the link to their main page. Auto colors are off on the left-hand menu under "Repair Kits and Color Charts". Organized by Make.
    Update: after curing 24 hours, the couple places that looked like they didn't quite blend (can be seen towards the bottom in the photos) are pretty much invisible. Those spots were a bit larger and I think had more of the Color Flex on them.
    The other thing to comment on is that the leather doesn't feel any different in those areas. I was worried the repair spots would be "hard", but the leather feels exactly like it does on similar non-worn spots.
  8. #8
    Super Member
    Join Date
    Jan 2011
    Posts
    522
    Post Thanks / Like
    why didn't you clean those seats before repairing them ... smh
  9. #9
    Super Member Bunky's Avatar
    Join Date
    Jun 2007
    Location
    Hillsborough, NC
    Posts
    6,201
    Post Thanks / Like
    Thanks!
    Al
    The Need to Bead
  10. #10
    Join Date
    Sep 2011
    Posts
    277
    Post Thanks / Like
    Quote Originally Posted by fredcandetail View Post
    Yeah, nice catch.
    I did clean them with DP interior cleaner, but didn't have a brush. In the light I had, they looked ok, then the photos showed the grime still stuck in the grain.
    The areas to be treated were clean though, went over them multiple times with the DP, and then with IPA (per the instructions for the color flex).
    Update - after three days, I can't even see the lines where the color flex is blended into the surrounding color. This stuff is pretty cool. And I think I've used about 4 ml...have enough left I could probably over an entire seat LOL.
Similar Threads
  1. 2007 335i Spa day
    By shadowman in forum Show N' Shine
    Last Post: 10-03-2014, 09:47 PM
  2. 2007 Dodge Dakota FARM TRUCK!
    By parttimer in forum Show N' Shine
    Last Post: 06-03-2014, 09:53 AM
  3. Repair of Leather Seat
    By phantom in forum Ask your detailing questions!
    Last Post: 11-20-2011, 10:15 AM
  4. 2007 BMW 335i
    By sal329 in forum Show N' Shine
    Last Post: 07-14-2009, 09:21 PM
  5. 2007 BMW 335i
    By HighEndDetail in forum Show N' Shine
    Last Post: 06-02-2007, 09:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
