Dislikes: 0
Clear bra removal
Found several helpful threads on removing a clear bra and tried everything suggested in those threads.
Unfortunately the clear bra on my car has been on there waaaay too long and there is just no taking it off the ways that are suggested. It has dry-rotted on the car - cracks are visible everywhere in the bra.
The basic problem is that the bra shreds as soon as I try to lift it off the paint. I can't get much more than a couple of milimeters up before it breaks off, leaving every bit of the adhesive behind.
The adhesive itself seems to have cured to the paint. There is no hint of plastic over the stuck adhesive, but using goo gone, 3M spray on adhesive remover, oils... nothing works very quickly. With a lot of elbow grease and about an hour of careful work, I was able to remove about five square inches.
I wiped down the exterior of the bra with some goo gone and actually observed it penetrating the cracks in the surface of the bra. Eventually it evaporated but at no point was the bra easier to remove.
I also tried an adjustable heat gun. Warming the bra didn't make it come off any easier, but it did begin to liquify the adhesive. I tried a range of temperatures but the underlying problem is the fact the that bra has started to decompose - the cracks don't allow the bra to be removed in a sheet. It keeps shredding into tiny peices.
Next up, I'm trying a drill mounted eraser. I could really use some advice or any other methods I could attempt. I'm not too afraid of minor damage to the paint. Pretty sure I can correct whatever I cause in the removal process.
Super Member
Re: Clear bra removal
Next tool on the list for "stubborn-clear-bra" removal:
What you're using so far...heat, removers for adhesive softening...picking the pieces off...slow going, but effective on PPF this decrepit, IMO. Maybe a plastic paint/tar-remover scraper might help some.
Good Luck!
"Be wary of the man who urges an action in which he himself incurs no risk."
~Joaquin de Setanti
Super Member
Originally Posted by FUNX725
Maybe a plastic razor blade, for say, tar-remover, might help some.
These:
ScrapeRite Plastic Razor Blades, Scrape-Rite Razor Blades, Plastic blades
~Joaquin de Setanti
biased on the title I was going to say dinner and drinks after but that may not work in this case. Although after all that you have tried it may be worth a shot LOL
These:
Great minds think alike - I ordered these the day before you posted!
I'm really banking on an eraser wheel. I really hope it's a miracle worker.
Super Member
We use steam or 3M adhesive remover at our shop along with the plastic razor blades. Take your time if you can.
Super Member
I just removed a clear bra from a 2007 Lotus and our steamer and heat gun worked wonders. Maybe see if someone has a steam cleaner, the kind used for pressure steaming engines. Just a thought????
Steaming, huh? Makes sense, I guess.
My plastic razor blade scraper arrived on Saturday. Hopefully the eraser wheel arrives before the holiday weekend. If I can't make decent progress with this method...
steam will be my next try.
Super Member
Where are you located?
Maybe I can help.
Maybe I can help.
Houston, Texas. Would welcome help in any form!
Similar Threads
By Legacykid in forum Auto Detailing 101
Last Post: 10-20-2015, 09:16 PM
By NiSyam in forum Ask your detailing questions!
Last Post: 06-29-2012, 07:35 PM
By former86camaro in forum Ask your detailing questions!
Last Post: 02-25-2011, 12:23 PM
By Mirror Detailing in forum Auto Detailing 101
Last Post: 03-16-2010, 05:51 PM
By Totoland Mach in forum Auto Detailing 101
Last Post: 11-05-2007, 09:22 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
