Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Regular Member LazerRed1's Avatar
    Join Date
    Jan 2007
    Location
    Springfield, MO
    Posts
    163
    Post Thanks / Like
    Waterless car wash question
    How can a waterless car wash not introduce micro marring if the car has any dirt whatsoever? Is this to be used only on dusty cars? I seem to have a hard time not getting micro marring even with 2 bucket etc. etc.
  2. #2
    Super Member mjlinane's Avatar
    Join Date
    Apr 2011
    Location
    Round Rock, TX
    Posts
    953
    Post Thanks / Like
    Re: Waterless car wash question
    Both waterless and rinseless washes use polymers to lift and encapsulate dirt from the paint surface so they can be picked up by MFs. I only do waterless if the car is lightly dirty. The key is not to scrub the dirt into the paint. I use lots of long nap MFs and little pressure.
  3. #3
    Super Member tw33k2514's Avatar
    Join Date
    May 2011
    Location
    Chicago, IL
    Posts
    2,298
    Post Thanks / Like
    Quote Originally Posted by mjlinane View Post
    Also if you are getting marring with the 2BM, I would not try a waterless wash. Obviously your paint is very soft.
  4. #4
    Super Member budinsc's Avatar
    Join Date
    Jul 2011
    Location
    sc
    Posts
    249
    Post Thanks / Like
    lazer, i too watched micro marring creep back into my wifes black mb after i put in about 25 hrs on a full correction. no matter what techniques i used in washing it happened even when i properly used a cal duster on VERY light dust. what i have done with much success is to let it go until i cant stand it then polish with mez micro polish 87 mc which does a fabulous job and removes very little of the clear coat.
    as mike the magician told me a while back "now that you have the paint perfect the real work begins."
    budinsc
  5. #5
    Regular Member barryscott's Avatar
    Join Date
    Nov 2006
    Location
    Tupelo, MS
    Posts
    169
    Post Thanks / Like
    Quote Originally Posted by budinsc View Post
    budinsc
    JMO that might be a part of your problem too
    Scott
    Club Flex 3401
  6. #6
    Newbie Member James Dudra's Avatar
    Join Date
    Mar 2008
    Location
    Portsmouth, NH
    Posts
    28
    Post Thanks / Like
    What kind of towel are you using? We normally suggest a 300GSM or higher towel when using the waterless method.
    Proper technique plays a major role as well. Make sure you are taking light strokes during your first pass with the microfiber towel. Personally, I take the approach of 'wipe and lift' whereby you are semi-rotating the towel as you slide across the panel. Applying too much pressure is bound to lead to problems.
    Co-founder & CMO
    Eco Touch, Inc.
  7. #7
    Super Member Jimmie's Avatar
    Join Date
    Dec 2006
    Location
    Upper Desert, CA
    Posts
    4,349
    Post Thanks / Like
    Waterless wash is necessary at these apartments I'm at. To be honest I think they do induce a few swirls. After almost three months of WW my cars are probably where they are at my annual major detail. No biggie, it's just another opportunity to
  8. #8
    SELF BANNED
    Join Date
    Oct 2011
    Location
    Chicago Area
    Posts
    394
    Post Thanks / Like
    budinsc
    Quote Originally Posted by LazerRed1 View Post
    Micro-Marring, doesn't that imply that its too small to be seen. How in fact did you actually notice this "mirco-marring"? What I find even more interesting is that
    a cal duster with very light dust can mare/scratch car paint and the clear coat.
    I dont know the hardness factor of dust, cal dusters etc as compared to car paint but I sure wish a paint chemist was part of the forum. He sure could offer allot in regards to this and other topics. Myth and Fact are so frequently blurred
  9. #9
    Super Member FUNX650's Avatar
    Join Date
    Dec 2010
    Location
    Ohio, USA
    Posts
    21,057
    Post Thanks / Like
    Quote Originally Posted by Bacon View Post
    Paint/clear-coat paint hardness is often gauged/referred to where it fits in the Mohs and/or Pencil Hardness tests. Some examples:
    Some tests OEM's require from paint manufacturers (Bolded tests may relate somewhat to your inquiry)
    -4000 hour weatherometer
    -ASTM D3363 pencil hardness
    -Amtec Kistler - Car Wash Test
    -Crockmeter test
    -Tukon hardness
    -ASTM D524 gloss (20¡/60&#161
    -ASTM D3359 adhesion test method B
    -ASTM D4060 abrasion resistance
    -ASTM D4752 MEK resistance
    -ASTM D1308 chemical spot resistance
    -ASTM D1308 skydrol immersion (7 days)
    -ASTM D522 flexibility test
    -ASTM D2794 impact resistance direct
    - ASTM B117 salt spray test method
    -Water contact degree angle
    -ASTM D4585 humidity resistance
    -ASTM D3170 chip resistance
    -ASTM D968 falling sand abrasion (100 liters)
    __________________________________________________ __
    Pencil Hardness of paints/coatings (Hard to find out which paints and by what paint manufacturers OEM's utilize at any given moment)
    Catalyzed polyester: 9H
    Catalyzed polyurethane: 9H
    Catalyzed Modified Acrylic polyurethane: 4H ***
    Catalyzed Acrylic polyurethane: 2H ***
    Water-based polyurethane: 3H ***
    Water-based urethane/Isocyanate Catalyst: 2H ***
    Conversion varnish: 4H
    Low VOC Catalyzed laquer (24 hrs): 2H
    Low VOC laquer: 3H
    Urethane/Nitrocellulose laquer (24 hrs): F
    Water reducible laquer: 2H
    Tung oil/polyurethane wipe-on finish: 2H
    Water-based polyurethane wipe-on finish: HB-F
    Aerosol precat: 3B
    Aerosol water clear acrylic: 3B
    Aerosol clear shellac: 3B
    Aerosol nitrocellulose/polyurethane: HB
    Aerosol nitrocellulose: 3B
    Amber (orange) Shellac: 3B
    Pencil Hardness Scale:
    9H 8H 7H 6H 5H 4H 3H 2H H
    Hardest -> -> ->
    F HB
    Medium -> ->
    B 2B 3B 4B 5B 6B 7B 8B 9B
    -> -> -> Softest
    Moh's Scale:
    (IMO...May apply to hardness of paint/clear-coat paint? Why is hardness of various minerals important? Abrasives are manufactured from minerals and are in compounds/polishes.)
    Mineral Hardness
    Diamond 10
    Corundum 9
    Topaz 8
    Quartz 7
    Orthoclase 6
    Apatite 5
    Fluorite 4
    Calcite 3
    Gypsum 2
    Talc 1
    -Sorry to report that most clear-coat paint films are nowhere near the very top portion on either the Pencil Hardness or Moh's Scales test. But are they getting "better"..perhaps...but still getting thinner...that's a fact!
    -Haven't been able, as of yet, to locate the Original California Duster's fibers actual placement on either of the above Scales. Need the OCalDuster's fibers make-up information, in order to possibly determine its abilities to inflict micro-marring on a given clear-coat paint. Will post that info, when obtained, ASAP.
    -And...It would be very difficult to place where "dust" fits on these Scales, without having a sample of the particular "dust" that lies atop the vehicles in question to take to the Lab....To possibly determine its impact, if any, on a given clear-coat paint as well. Too many, and different levels, of "dustiness".
    -I agree with your premise/definition of micro-marring to a point. But this Mike Phillips article, IMO, is more meaningful:
    http://www.autogeekonline.net/forum/...o-marring.html
    "Be wary of the man who urges an action in which he himself incurs no risk."
    ~Joaquin de Setanti
  10. #10
    Join Date
    Jan 2007
    Location
    Springfield, MO
    Posts
    163
    Post Thanks / Like
    I don't use waterless, never have, and probably won't since I don't think there is any way in the world to prevent some surface damage. Right now the car is pretty good on the very fine marks. Nothing even as bad in Mike's article. What I have I think was done at the dealers when the car was on the showroom floor, but I think the clearcoat even shows lines when using the best waffle weave available. Not sure there is any way to prevent it.
Similar Threads
  1. A waterless wash question
    By Bacovish in forum Ask your detailing questions!
    Last Post: 09-14-2018, 05:54 PM
  2. Waterless wash question
    By carguy2007 in forum Auto Detailing 101
    Last Post: 11-28-2017, 06:38 AM
  3. Question Regarding Waterless Wash
    By h8dirtycars in forum Ask your detailing questions!
    Last Post: 03-08-2017, 08:02 PM
  4. Replies: 9
    Last Post: 12-01-2012, 12:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
