Page 52 of 58 FirstFirst ... 24243444546474849505152535455565758 LastLast
Results 511 to 520 of 571
  1. #511
    Super Member Desertnate's Avatar
    Join Date
    Aug 2013
    Location
    St Louis metro (Illinois)
    Posts
    5,809
    Post Thanks / Like
    Re: Collinite #845: The Definitive How-To Guide For This Legendary Wax
    Quote Originally Posted by mcbry View Post
    my other option is to make a UWW+ with distilled water and KSG mixture. this will be like a QD sealant/wax booster. is it ok to spray this mixture on top of collinite 845?
    If you're going to try to make a mix of KSG into a spray wax, it's already been done. You can buy it here: Sonus Acrylic Glanz Spray Sealant, Sonus paint sealant spray, spray paint sealant.
    845 is really durable and pretty forgiving of anything you want to put on it. Most of these spray waxes will only last a week or two, so there can't be too much to them to which would harm a quality LSP.
    Unless you enjoy playing the role of a mad chemist, I'd just pick up a reputable spray wax. There or lots of great ones here; Ultimate Quik Wax, Aquawax, Hydro Max, OCW...
    Drop by to see the latest at The Car Geek Blog
  2. #512
    Newbie Member
    Join Date
    Sep 2015
    Posts
    6
    Post Thanks / Like
    Quote Originally Posted by Desertnate View Post
    thanks for the info, Desertnate. this is very helpful.
  3. #513
    Junior Member
    Join Date
    Apr 2015
    Posts
    50
    Post Thanks / Like
    Question regarding Collnite 845, as i was given a sample by a buddy of mine, after he really rated it... Can you get some on plastic trim, and not worry about it? Also what about applying in direct sunlight? is that acceptable on Collnite 845?
    Up til now, I've been an Megs ULW or Turtle wax ICE guy, cos its fully synthetic, i'm not afraid to get it on any trim, and it can be applied in direct sunlight (Living in SW FL, this is a big deal)
    What i did today (after a clay treatment) was all the trim, and parts next to the trim using ICE, and the larger panels (away from trim) using Collnite 845. I could always use this method if need be? or is Collnite 845 trim safe and ok to apply in sunlight?
  4. #514
    Super Member davidc's Avatar
    Join Date
    May 2007
    Location
    Arizona
    Posts
    1,499
    Post Thanks / Like
    Sun no. Trim yes, I use it on trim all the time.
    Dave
  5. #515
    Newbie Member
    Join Date
    Feb 2016
    Posts
    8
    Post Thanks / Like
    I own a Volkswagen Vento - White and have just started off with the detailing process, it is 2 years old.
    I am a noob am have just started going through threads and getting to learn to detail my car the right way.
    I have the below products available with me currently.
    1. Pinnacle Paintwork Cleansing Lotion
    2. Wolfgang Finishing Glaze
    3. Meguiars Nxt Tech Paste 2.0
    4. Collinite 845.
    First of all i have two questions.
    1. Can the wolfgang finishing glaze be topped up after using the Pinnacle Paintwork Cleansing Lotion ?
    I see some people say that the Pinnacle Paintwork Cleansing Lotion also has a polish in it . And also that the wolfgang finishing glaze is not actually a glaze but a polish. So is it right to apply the wolfgang finishing glaze over the pinnacle paint cleansing solution.
    2. The waxes, both the meguiars tech wax 2.0 and the collinite 845 are waxes.
    I thought of applying the collinite 845 and later top up with meguiars tech wax paste 2.0. Will this affect the durability of the collinite?
    Or should i just use the collinite wax alone, and not use meguiars tech wax paste 2.0 on top of it.?
    Also how frequently should the waxes be used.?
    During every wash should we apply pinnacle paintwork cleansing solution, followed by wolfgang and then the waxes, or could we top up with waxes for a couple of times and after like 10 washes we can start with the process from first.
    Another final question on the collinite 845, and pinnacle paint work cleansing lotion.
    Can both of them be used on the head lights?
    Use pinnacle paint work cleansing lotion on the head light followed by the wolfgang glaze and then the collinite 845.
  6. #516
    Super Member RPPM's Avatar
    Join Date
    Sep 2010
    Location
    Reedsville, PA
    Posts
    324
    Post Thanks / Like
    I would not top the Collinite 845 with Tech Wax II. The Collinite is a hybrid wax/sealant, the Megs Tech II (NXT 2.0) is a sealant. I would put one coat of Collinite 845 on, remove it, let it cure for 24 hours or so, and then top with a 2nd coat of 845 and remove. You should be good to go for 4 months or so.
  7. #517
    Join Date
    Aug 2013
    Location
    Posts
    5,809
    Post Thanks / Like
    Quote Originally Posted by RPPM View Post
    I'd be willing to bet two coats would last double that amount of time. I single coat of 845 for me lasts at least six months. I got 5 months out of a singe coat in the worst winter this area had seen in 40 years. The car was constantly salt encrusted and saw frequent touchless washes, which tend to be brutal on an LSP due to the harsh soaps.
  8. #518
    Junior Member SwiftTone's Avatar
    Join Date
    Feb 2016
    Location
    Quincy, MA
    Posts
    80
    Post Thanks / Like
    What makes this an "Insulator" wax?
  9. #519
    Join Date
    May 2007
    Location
    Arizona
    Posts
    1,499
    Post Thanks / Like
    Quote Originally Posted by SwiftTone View Post
    As the story goes it was designed for Electrical insulators you see in various places.
    It would keep them protected and reasonably clean.
    Dave
  10. #520
    Join Date
    Feb 2016
    Location
    Quincy, MA
    Posts
    80
    Post Thanks / Like
    Quote Originally Posted by davidc View Post
    Dave
    Ah yes, I've read that. It sounded marketty so I thought there might be another purpose that wasn't so apparent.
Similar Threads
  1. The definitive guide to proper pad seasonning.
    By Calendyr in forum Auto Detailing 101
    Last Post: 05-19-2018, 08:04 AM
  2. Duragloss product definitive guide
    By Mike Honcho in forum Auto Detailing 101
    Last Post: 06-15-2017, 08:52 AM
  3. Replies: 20
    Last Post: 03-08-2014, 10:33 AM
  4. Help! MF pads, definitive guide?
    By jdmj0 in forum Auto Detailing 101
    Last Post: 04-01-2013, 05:02 PM
  5. The Definitive Guide to Headlight Restoration Kits
    By Nick McKees37 in forum How to Articles
    Last Post: 03-22-2012, 09:55 AM
Members who have read this thread: 8
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
