Dislikes: 0
04-10-2015, 05:59 AM
#451
Re: Collinite #845: The Definitive How-To Guide For This Legendary Wax
i tend to apply with a DA on pair with a red foam pad.
a little goes a looooooong way
04-15-2015, 08:50 AM
#452
Super Member
I purchased #845 earlier this spring and just got around to using it for the first time as an LSP on my son's '07 dd. Followed Nick's tutorial and it couldn't have gone smoother. Used a PC 7424 XP with a LC 5.5 blue flat pad. Thin, thin, thin was the key. This bottle will last me a long time!
David
04-21-2015, 01:00 PM
#453
Junior Member
I also just used this for the first time this past weekend. Put it on with my HF DA and used a blue LC 5.5 pad. Very impressed with the ease of use and how my wifes Cherokee turned out.
06-16-2015, 05:57 PM
#454
Regular Member
Hello,
I've taken so much from AGO these past few weeks, I suppose it's time to give back.
Used Collie #845 a couple of weeks ago....
TEMP: 75 degrees/60% Humidity
Application: Hand, Foam
Garage
1 week prior: 2 Bucket Wash/Clayed/Paint Corrected.
Used UQD to wipe light dust prior to application.
Plopped Collie in an Ice Bucket filled with warm/hot water for 10-15 min then shook the bejeezus out of her...then shook it some more. Transferred about 3 ounces, per Nicks recs, to a Meg's self cleaning bottle. Closed the parent bottle tightly and I'll see her in another 3 years LOL.
Special Note: I'm degreed in Biochemistry and Direct Sunlight reacts havoc with some Bio-molecules. Am I saying not to put the bottle in Direct Sunlight to heat it up....Nope; but why even play around when warm water does the trick.
Was Paranoid with the wax from reviewing thousands of post on various forums (you guys know what I mean ) so I called Collie Customer Service, The 3 Biggies:
1. Properly Prepared Paint
2. Thin Thin Thin
3. Quality Microfiber for removal <--- He Stressed this. He also advised after your done removing, to go ahead and go over it again slowly/deliberately with a New MF.
Eagle Edgeless MF is by far the best, just MHO.
Watched a U tube video where a Professional Detailer was going on and on about 845 and preached THIN. Then proceeded to apply it Peanut butter style with a Microfiber Applicator, LOL.
What does "THIN" actually mean for cryin out loud?
So go ahead and put it on thin.
Had the Collie by my side and just spritzed the applicator with distilled water and put 3 pea sized drops on the Applicator. Did a quick serpent on half the hood and spread it out "Thin". I only needed two pea sized drops for each section on the rest of the car.
After the hood and 1/4 panel, I did the finger test but she smeared. Waited for 20 minutes and she looked liked it hazed but it still smeared....so "Got It". Did the rest of the car, then finger tested the hood...still smeared. Let her sit in the garage for another 90 min or so then....she WIPED RIGHT OFF, No Problems. Total roughly 2 hours.
She looked pretty good....I wasn't prepared for the Eye Popper when I check her in the Morning.......WOW!!! Is all I can say. Oh and she wiped off of everything (Trim ect)
So I said 1 scoop was pretty good; hmmm, how bout 2 scoops? Remebered them saying 12-18 hour cure time then layer; so away I went. This time "Primed" the Applicator with a little Collie the squeezed it all the way through and used 2 pea sized drops for each section.
I'm retired military (old soldier) and remember quite vividly "SPIT SHINING" my boots thousands of times; Procedure: IPA Strip, Polish, Wax.....sound familiar? The KEY ingredient....ICE WATER!!! So feeling pretty cocky @ this point, threw that spray bottle of distilled water into the freezer Took it out a little early cause I didn't want a Brick and while I removed the wax spritzed that Ice Water on her. She shined up like a New Penny but I knew to prepare myself for the next morning...I could hardly sleep lol. Well, you see her in the pics above and they don't do her justice let me tell ya. The neighbors were doing the "Double Take"...one that was driving by nearly crashed (No Joke).
I know "SHINE" comes from Polishing...@ least 95-98% and wax/sealants protect...who you gonna leave that last 2-5% too?
Grab some Collie with Confidence and don't look back.
From the shell and feel of my car, she may be able to withstand a limited engagement Thermo-Nuclear War.
Update: she got a quick downpour on her before I hit the garage yesterday...and the water that didn't bead in tiny droplets literally JUMPED off the car!!
Hope it helps
"The first gulp from the glass of natural science will turn you into an atheist, but at the bottom of the glass God is waiting for you." --Werner Heisenberg (Pioneer of Quantum Mechanics, Nobel laureate Physics)
06-30-2015, 06:49 AM
#455
Junior Member
06-30-2015, 10:18 AM
#456
Super Member
Man, this post makes me want to go home and put more 845 on my car! Great post very well written and entertaining to read!
I'll definitely be reading more of your posts!
07-02-2015, 08:35 PM
#457
Super Member
About to drink the "collinite" juice! Before jumping in---does this stain black trim?
Tom
07-02-2015, 10:43 PM
#458
I'm going to be moving in a month and will have to store my stuff in a storage unit. This stuff should be fine right?
07-03-2015, 02:59 AM
#459
Super Member
I stored mine in an unheated/uncooled garage for around 5 years and when I got it back out, as soon as I warmed up the wax to application temperature, it was good to go. I wouldn't recommend this practice, I just forgot about it while I was in the "Flavor of The Month Club."
A little note about applying thin ... about 4 pea sized drops will do the entire hood or roof or two side panels (with the PC). It goes on SO thin that I have to watch very closely where I move the buffer, at some angles, it's the only way to tell if I've applied wax in that area, by visually seeing the buffer pass over every square inch, sometime going over a single panel more than once. Because of this I always apply two coats, to make sure I've covered everywhere.
07-03-2015, 10:54 PM
#460
Super Member
Can I use this on black trim as well or do I need to tape off the trim?
Tom
Similar Threads
By Calendyr in forum Auto Detailing 101
Last Post: 05-19-2018, 08:04 AM
By Mike Honcho in forum Auto Detailing 101
Last Post: 06-15-2017, 08:52 AM
By Nick McKees37 in forum How to Articles
Last Post: 03-08-2014, 10:33 AM
By jdmj0 in forum Auto Detailing 101
Last Post: 04-01-2013, 05:02 PM
Last Post: 03-22-2012, 09:55 AM
Members who have read this thread: 8
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
