Dislikes: 0
Regular Member
Contact Cement??
After only about 3/4 of my very 1st polishing job, my orange LC flat pad came unglued almost completely (Velcro & foam).
Do you guys know if I can reattach these materials using contact cement? Any other suggestions are welcome, thanks
Accomplishment and success are often the result of commitment and perseverance rather than skill or talent.
Super Member
Re: Contact Cement??
what speed and machine were you using? I have those pads and they look brand new after 3 cars
How about a hot glue gun spread kinda thin?
I told my wife that a husband is like a fine wine; he gets better with age. The next day, she locked me in the cellar.
~Tim
Super Member
Call LC and they will send you a replacement
“Hard times create strong men, strong men create good times, good times create weak men, and weak men create hard times.”
Super Member
I think a good contact cement would be a good choice to try. I'd try a water based product as the solvent based product may eat the foam itself.
3M also has some decent spray adhesives that might work too.
BobbyG - 2004 Millennium Yellow Z06 Corvette
Regular Member
An old PC 7335 at 6 speed...I was thinking hot glue may be to "stiff"? I dunno.
Thanks
Regular Member
Thanks Bobby, I was actually thinking to use one of those 3M spray cements for upholstery...I've seen my wife use it to glue foam to fabric for some sofa she did...I guess I may just give it a try...
Thanks Flash...I just think that some how it's my fault because being my 1st polishing job I feel I did not use it correctly or something...yeah I know, I have issues
Super Member
Maybe just chalk it up to experience. Not sure gluing it is worth it. Cut it into pieces and use it for application sponges.
Regular Member
That is a good tip also, thanks.
I may just give it a try and glue it if it does not work out, well I'll be cutting some applicators...
Super Member
I doubt it was your fault. You probally got a batch of those pads from last year that had cheap glue. They were falling apart on lots of ppl
Regular Member
Oh, did not know that...I may contact LC then, thank you for the heads up
Similar Threads
By kiwi007 in forum Customer Comments
Last Post: 12-01-2017, 09:18 PM
By poyo150 in forum RUPES BigFoot Oribital Polishers
Last Post: 06-05-2017, 11:16 AM
By NIGHT500 in forum Customer Comments
Last Post: 07-29-2016, 09:20 PM
By david b in forum Off-Topic
Last Post: 12-14-2015, 04:44 PM
By Kevin D. Hannum in forum Ask your detailing questions!
Last Post: 09-17-2015, 08:33 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
