Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 10 of 10
  1. #1
    Newbie Member
    Join Date
    Jun 2011
    Posts
    4
    Post Thanks / Like
    Low Pressure/Weak Flow From Spigot/Hose. Cheap Fix? Fire Hose Nozzle?
    I live in Manhattan so I don't really have a place where I can wash my car.
    My solution was to wash my car whenever I visit my gf at her old house.
    I bought a light duty hose and a nozzle from home depot.
    I turned on the spigot and immediately noticed a weak flow of water before I even connected the hose. I believe this is due to the old piping since the flow of water is her bathroom and kitchen is also weak.
    I started to spray down my car and it didn't do much for the wheels. If I let the water/pressure build up for about 10 seconds, I would get about 3 seconds of decent pressure.
    Question:
    1. I was wondering how I can increase pressure/output of water so I can effectively clean my car.
    2. Would a fire hose nozzle help a little bit?
    3. Can I just buy a cheap $6 fire hose nozzle from Walmart/Home Depot? I don't want to keep spending money since she might be moving in a few months.
    Thank You!
  2. #2
    Super Member BobbyG's Avatar
    Join Date
    Dec 2009
    Location
    Southeast, MA
    Posts
    13,211
    Post Thanks / Like
    Re: Low Pressure/Weak Flow From Spigot/Hose. Cheap Fix? Fire Hose Nozzle?
    Since this is your first post, To Autogeek Online!
    Typically city water pressure is high and the volume is consistent. It appears that the water pressure in your girl friends home is low just about everywhere. I would suspect that somewhere between the street valve and the houses main line in is the root cause of the issue.
    A firehouse nozzle is exactly what not to do. Most of these nozzles require both high pressure and water volume to perform properly.
    Options
    Is the street valve wide open?
    Is the pipe clear from the street to the house?
    Is there a valve inside that's partially closed or functioning incorrectly?
    Find the problem and correct it at the source.
    Place a pump and tank combo in the basement that would act as a pressure booster and a storage tank. Keep in mind that if when the sorted water is depleted you'll need to wait for the tank to refill and pressurize.
    The hose is more than likely not the issue here and $6.00 won't buy you much of a hose.
    BobbyG - 2004 Millennium Yellow Z06 Corvette
  3. #3
    Super Member A4 1.8tqm's Avatar
    Join Date
    Apr 2009
    Location
    Edmonds, Wa.
    Posts
    1,932
    Post Thanks / Like
    Yeah, my first thought was the street valve. Sometimes they are awkward to get at, I could imagine some lazy worker only turning it just enough to open then saying eff it, good enough.
  4. #4
    Super Member ScubaCougr's Avatar
    Join Date
    Oct 2010
    Posts
    558
    Post Thanks / Like
    Since the pressure is low throughout the house, start at the main shutoff at curb or basement. If that is fully open, I'm betting on pipes narrowed with decades of scale. (especially if cast-iron)
    You could get proficient at a 2-bucket rinseless wash which can be done in 5 gallons of water, or even waterless if you keep your car very clean. Either/both may be less frustrating than troubleshooting plumbing --in a rental--
    Mike at www.GreatReflections.biz
    Vancouver, WA's convenient Mobile Detailer comes to you!
  5. #5
    Super Member
    Join Date
    Aug 2010
    Location
    New Jersey
    Posts
    15,150
    Post Thanks / Like
    I have just two words to say to you...PRESSURE WASHER. As long as you've got a couple GPM coming out, that should boost you up. That's a cheaper/faster fix than a plumber to change out a crappy curb valve or stuck gate valve somewhere--which is of course the right way to do it.
  6. #6
    Super Member oldmodman's Avatar
    Join Date
    Sep 2007
    Posts
    2,563
    Post Thanks / Like
    I had a friend that had really low water pressure at a house he was renting. He put a pressure gauge on the last faucet and was only getting 15 psi.
    So he went to the front of the house and spotted a pressure regulator. He got a wrench and turned it up to 50psi which is a fairly normal pressure. He went back to the backyard faucet and now he had no flow. He had blown up the really old, rusted iron pipes under the house.
    So he turned the pressure back down and called the landlord.
    To quote the landlord "I knew those old pipes were going to blow one of these days"
    And the house was re-pipes with copper. Lots of pressure now.
  7. #7
    Super Member ScottB's Avatar
    Join Date
    Mar 2006
    Location
    South Florida
    Posts
    18,803
    Post Thanks / Like
    Quote Originally Posted by Setec Astronomy View Post
    I too thought one of those Karcher Pressure washers might be just the ticket, under 100.00 bucks.
    Scott
  8. #8
    Super Member Bunky's Avatar
    Join Date
    Jun 2007
    Location
    Hillsborough, NC
    Posts
    6,201
    Post Thanks / Like
    Quote Originally Posted by killrwheels@autogeek View Post
    Mark has a new one !! (hint).
    Al
    The Need to Bead
  9. #9
    Super Member IID's Avatar
    Join Date
    Sep 2010
    Location
    Northwoods
    Posts
    2,195
    Post Thanks / Like
    Excellent recommendation for the OP's issue!
    Team Flex PE14-2 150(Serial#0005)/3401/3403/XFE 7-15
  10. #10
    Newbie Member
    Join Date
    Jun 2011
    Posts
    4
    Post Thanks / Like
    Thank you everyone. I believe the pressure washer would be the best bet, but as of now, I'm going to save that $100 or so and wait until she moves.
Similar Threads
  1. Replies: 13
    Last Post: 10-13-2013, 06:24 PM
  2. Fire Hose Nozzle
    By Rsurfer in forum Product Reviews
    Last Post: 05-19-2012, 11:12 PM
  3. Fire Hose Nozzle
    By CEE DOG in forum Product Reviews
    Last Post: 10-18-2010, 09:38 AM
  4. Fire Hose Nozzle -- Broken?
    By Christopher in forum Auto Detailing 101
    Last Post: 06-23-2010, 09:48 PM
  5. Fire Hose Nozzle
    By SJSHARKS_2009 in forum Off-Topic
    Last Post: 03-05-2010, 09:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
