Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 8 of 8
Thread: New motorcycle
  1. #1
    Newbie Member
    Join Date
    Aug 2008
    Location
    Xenia Ohio
    Posts
    29
    Post Thanks / Like
    Question New motorcycle
    I just picked up a "new" bike this week. 1987 Honda Rebel with 1300 miles on it. Paint is decent on it with a couple of small scratches/chips on the tank. Aluminum is dull and the factory clear coat is turning yellow. Chrome has a few small rust spots. Overall very good shape for 24 years old.
    What is the best method for removing the factory clear coat on the aluminum parts?
  2. #2
    Super Member tuscarora dave's Avatar
    Join Date
    Aug 2009
    Location
    Etters PA
    Posts
    5,403
    Post Thanks / Like
    Re: New motorcycle
    Have you tried polishing the clear coat to see if there is a reduction or overall removal of the yellowing effect? I would try polishing it first.
    I have removed the clear on aluminum motorcycle parts by sanding it off with several different grades of paper and then polishing up with several grades of jewelers rouge on a wheel style buffer (bench grinder type) but this takes forever to do even the smallest part and leaves the aluminum unprotected so it oxidizes and turns white in a short period of time unless re coated with clear automotive paint.
    In my experience, I think it is not worth all the work. Just something to think about.
  3. #3
    Newbie Member
    Join Date
    Aug 2008
    Location
    Xenia Ohio
    Posts
    29
    Post Thanks / Like
    Re: New motorcycle
    I haven't tried anything on it yet. I have been too busy riding it. The clear coat is missing in spots and turning yellow in others. Was thinking of removing the remainder and respraying with a high temp clear.
  4. #4
    Newbie Member
    Join Date
    Aug 2008
    Location
    Xenia Ohio
    Posts
    29
    Post Thanks / Like
    Re: New motorcycle
    Trying to upload a pic
    Attached Thumbnails Attached Thumbnails New motorcycle-p1020927-jpg
  5. #5
    Newbie Member
    Join Date
    Sep 2011
    Posts
    5
    Post Thanks / Like
    Re: New motorcycle
    I thing you tried poliching as well then Removing scraches/chips on the tank.
    Thanks
  6. #6
    Junior Member
    Join Date
    Aug 2011
    Posts
    31
    Post Thanks / Like
    Re: New motorcycle
    Quote Originally Posted by michaelg View Post
    I agree on that. If you already tried polishing your bike will look more better....
  7. #7
    Super Member
    Join Date
    Mar 2009
    Posts
    325
    Post Thanks / Like
    Re: New motorcycle
    To answer the question, "What is the best way to remove the old clear coat" I'll tell you what I did with parts off my Yammy XS650. Pulled the piece, applied Easy Off oven cleaner, let sit for a bit (but not until dry) agitated with a green scratchy pad and rinsed with water. Might take a couple of tries but this did it for me and I did several pieces quick. Sand to desired surface texture and polish or re-spray with clear.
  8. #8
    Newbie Member
    Join Date
    Sep 2011
    Posts
    5
    Post Thanks / Like
    Re: New motorcycle
    Quote Originally Posted by 4wheelsonline View Post
    Hello sir,
    Yes, you have trie and then see result.
    Used Trucks For Sale - Ford, Dodge, Chevy, Toyota, GMC, International Truck Trader
Similar Threads
  1. New motorcycle, what to use?
    By jmart24 in forum Motorcycle Care
    Last Post: 02-10-2020, 01:24 PM
  2. First Motorcycle
    By dcjredline in forum Show N' Shine
    Last Post: 06-06-2015, 08:16 AM
  3. Another Motorcycle B4 & After
    By MshawnBauer in forum Show N' Shine
    Last Post: 01-23-2014, 10:51 PM
  4. Motorcycle Scratches on New Motorcycle.
    By jhkunkel in forum Auto Detailing 101
    Last Post: 03-02-2012, 06:21 PM
  5. New Motorcycle
    By suprachica79 in forum Off-Topic
    Last Post: 04-23-2011, 09:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
