Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
  1. #1
    Junior Member
    Join Date
    Apr 2011
    Location
    Minnesota/North Dakota
    Posts
    64
    Post Thanks / Like
    Boat Detailing! Couple Questions...
    Yea, i know this isn't auto detailing, but I couldn't find a boat detailing area haha.
    Anyways, might be detailing a couple boats here, and was wondering if anyone else has done them. I have hand polished, but never swirl removed. I know that the gel coat is soft and supposed to glide over the water, so you probably want a fairly light pad (for a boat obviously) or do you go aggressive, then light similarly to auto detailing??
    Seems a little less intensive than a car from the videos I have watched, but on a much larger thing.
    Any tips/pointers would be great. Thanks!
    2008 Infiniti G35S 6MT Sedan
  2. #2
    Mike Phillips
    Guest
    Re: Boat Detailing! Couple Questions...
    I would say gel-coats tend to be fairly hard, especially modern gel-coats as technology is always changing. I've worked on some pretty old gel-coat hulls and they always seem to cut a littler easier than anything made in the last 20 years or so...
    If you look at Marine compounds, they also tend to be a lot more aggressive than automotive products and there's a number of reasons for this...
    If you're just trying to remove light oxidation you might be able to get away with a DA Polisher with a foam polishing or cutting pad and strong cleaner/wax.
    If you're trying to chop off heavy oxidation and staining then the fastest way to do it is with a wool pad on a rotary buffer with an aggressive cutting compound.
    Sometimes wetsanding is the best option, I sanded down the sides of my hull to remove years of oxidation and faded gel-coat, came out pretty good.
  3. #3
    Junior Member
    Join Date
    Apr 2011
    Location
    Posts
    64
    Post Thanks / Like
    Ok, i learned a lot from that!
    Will any old car pad work for a boat? Say lake country orange pad and maybe some medium marine polish?
    Might give this a try this weekend on my buddies boat and see how it turns out.
    Thanks a lot!
  4. #4
    Mike Phillips
    Guest
    Quote Originally Posted by WannabeG View Post
    Thanks a lot!
    You can always test and check your results and make sure you're getting the results you want before buffing out the entire boat.
    If the boat is oxidized you're going to want to use an aggressive foam buffing pad or a Surbuf pad with an aggressive compound or an aggressive cleaner/wax.
    The XMT #4 actually works really well on oxidized gel-coats as it's kind of like liquid sandpaper.
    Be sure to wax the gel-coat at a minimum afterwards, polishing can help too, especially if the boat has a color to the gel-coat.
    Check this out...
    1967 Starline Deville - Extreme Makeover
    All done...
    Lots of this...
Similar Threads
  1. a couple of detailing biz questions
    By ConeArrow27 in forum How to make money detailing cars
    Last Post: 03-13-2014, 10:38 AM
  2. a couple of OC/Detailing questions.
    By wallace03 in forum Auto Detailing 101
    Last Post: 06-25-2012, 09:27 PM
  3. Detailing a 04 Cady tomorrow and have a couple questions.
    By ShineTimeDetail in forum Auto Detailing 101
    Last Post: 12-08-2010, 11:16 PM
  4. Couple of questions regarding detailing a 350z
    By Quick5Oh in forum Auto Detailing 101
    Last Post: 11-10-2009, 09:45 AM
  5. Kind of new to detailing, couple questions
    By aflyvietguy in forum Auto Detailing 101
    Last Post: 05-29-2008, 04:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
