Dislikes: 0
McKee's 37 Product Support
Aztec Hot Rod Hot Water Carpet Extractor How-To + Review
Early this morning I had the opportunity to test out an Aztec Hot Rod Hot Water Carpet Extractor on some floor mats that had not been cleaned in quite some time. The floor mats were covered in various stains that appeared impossible to get out.
If you're not familiar with it already, the Aztec Hot Rod is a hot water carpet extractor that's designed to deep clean carpet using the power of hot water. The Aztec is ideal for professional detailers because of its ease of use, effectiveness, and most importantly, the fact that it's portable and doesn't require a lot of space in your detailing rig.
Even if you're not a professional detailer and just want an effective means of deep cleaning the carpet in your car and home, the Aztec is a great investment.
Here you can see the driver's side floor mat prior to cleaning. As you can see there is dirt, oil, and grease that has accumulated over time.
The machine itself is very easy to use and requires very little time to set it up. All you have to do is fill the solution tank with warm water, turn the machine to the heating position, and about 10 minutes later you're all set and ready to go with hot water. Next you flip the switch to the vacuum position and you're all set.
To aid in the cleaning process the Aztec Hot Rod also includes a 32oz bottle of ready to use Detailer's Pro Carpet Extractor Pre-Treatment. This pre-treatment is effective on various types of stains including grass, oil, coffee, food, grease, etc. It doesn't contain any harsh chemicals, will not stiffen fabric, and can also be used with a scrub brush to break up some of the more tougher stains prior to using the carpet extractor.
Once the water tank has finished heating up, flip the switch to the vacuum position and go to work. It's as simple as spraying the pre-treatment on the surface (agitating where necessary), pulling the trigger to release the hot water over the area, going back and forth over the stain until it disappears, and you're all finished.
Here is how the floor mat looked once finished. It took less than 15 minutes to clean all four floor mats and it required very little agitation from the scrub brush.
When used in conjunction with a good scrub brush and a high quality upholstery cleaner, there are very few stains the Aztec can't handle.
Aztec Hot Rod Hot Water Extractor
Re: Aztec Hot Rod Hot Water Carpet Extractor How-To + Review
nice write up there nick mats look so much better
Super Member
Now that it's all nice and clean, do you suppose that lessens the risk that the accelerator pedal might get stuck under it?
Super Member
Aztec makes the best extractor in the whole wide world
“Hard times create strong men, strong men create good times, good times create weak men, and weak men create hard times.”
Thanks. What impressed me the most, besides the cleaning ability, was the fact that it took very little time to do all four mats.
Super Member
Does AGO now have a used Demo unit for sale at a discount?? J/K
2013 Ford F-150 XLT 4X4 Kodiak Brown Metallic
2004 Chevy Cavalier Burnt Orange Metallic
Regular Member
Nick,
Any idea of its durability? I read that it comes with a 3 year limited warranty, do you have more info into that?
We've had the mytee lite II for three years now and it's close to sleeping with the dirt. It has not held up as well as my thousand dollars would have liked, and getting it worked on is near impossible.
Super Moderator
Originally Posted by TMD
Nick,
I can tell you we do not see these come back to us, and when we have had any issues with Aztec they have been more then great about dealing with them. Their customer service is wonderful. As for more info about that this was taken from the Aztec Paperwork you would get from the manufacturer.
As our customer, you are aware that the design and construction of this
product are both innovative and unique. Since this is true, in order to
troubleshoot our equipment, we rely heavily on returned defective or
failed parts so that we can examine the causes of failure.While this may
at first seem to be an inconvenience, ultimately you benefit from safer,
better designed machine components. Please give us the opportunity to
serve you better by following these RGA (Return Goods Authorization)
rules.
1. We maintain the serial number, date of shipment or sale, and
customer name on each piece of equipment sold. If you were the
purchaser, please reference that information on your request for
replacement or repair. If you purchased the equipment through a
dealer, please include the company name, the date, and the serial
number of the product.
2. Ask for an RGA number when you are ordering the replacement
part. Return the failed part within 14 days, freight prepaid, exactly
as it was at the time of failure. Our inspection and evaluation will
attempt to determine the probable cause of failure.
3. If our inspection reveals that the failed part was defective, we will
credit your account for the entire amount of the part including
your cost of return freight, but not packaging expense. When
incomplete parts are returned for credit, their condition or state
of incompletion will be assessed against the credit claim.
4. We will not accept freight collect returns or returns that do not
indicate the RGA # on the packing list.
Your satisfaction is extremely important to us. We intend to be
reasonable on any matter that is related to our warranty service or
other wear-related problems which our customers feel need
attention. Please help us to help you. Before assuming that a part is
defective, check the repair manual to see if the problem might be
something that you or one of your employees might be capable of
correcting. If it is not, follow the above policy and depend on us to
respond quickly and responsibly.
HOT ROD/HOT SPOTTER WARRANTY
The spotter is warranted to be free from defects in material and workmanship. The warranty is limited as
follows:
Component Term of Warranty
Rotational molded parts 3 years
Pump 1 year
Vacuum motor 1 year
Heating element 1 year
The warranty does not apply to certain consumable or wear parts such as:
Motor carbon brushes Bearings
Hoses & hose fittings Filters & gaskets
The warranty does not apply to damage or failure caused by abuse, misuse, neglect, disassembly,
alteration, unauthorized modification or repair, lack of proper maintenance, theft or damage by freight
carriers. The warranty applies to parts, labor, and ground freight only.
In order to obtain parts warranty, the following procedures must be followed:
1. Customer must call the Distributor for an RGA (Return Goods Authorization) Number.
2. The defective part must be returned via ground freight prepaid to the Distributor with an RGA
number accompanied by a copy of the origianl purchase invoice. We are not responsible for the cost of
packaging inbound freight, nor inbound freight damage. Pack machine carefully.
3. Only the Distributor or its authorized dealers may make warranty repairs on Hot Rod/Hot Spotter
products. Others do so at their own risk and expense.
This warranty limits the Distributor’s liability for defects in workmanship or materials to replacement of
defective parts only. The Distributor will not be liable for incidental or consequential damages arising
from the use of any of its products, whether defective or not.
The need for proper maintenance and care for this product cannot be overstated. Poor maintenance,
neglect or abuse can prove to be very expensive. Never leave your machine in a truck or other outside
storage area where there is a potential for freezing.
1. Pumps carry a 1 year warranty. However coverage may be denied if there is evidence of the use of
chemicals in the solution tank, fiber/hair build-up in the pump chamber, or water damage to the
electrical portion of the pump.
2. Vacuum motors carry a 1 year warranty. Motors showing any of the following signs of abuse will be
excluded from coverage:
a. Signs of moisture in or on the fan/motor chamber area. (This means that if water or foam
has been sucked through the motor the warranty is voided.)
b. Dirty motors, where failure has been caused by inadequate filtrating.
c. Motors where excessive wear indicates that the motor has been used to the full extent of
it’s normal life expectancy, regardless of the date code stamp.
Your have purchased a quality product. Each of its components has been tested and approved for use.
It is unlikely that you will ever have a warranty claim if you properly maintain this machine.
This warranty is non-transferable.
Regular Member
Regular Member
something about that mytee 2 is just screaming for attention
Similar Threads
By Court M3 in forum Hot topics & Frequently Asked Questions
Last Post: 01-02-2017, 09:01 PM
By Court M3 in forum Auto Detailing 101
Last Post: 07-05-2012, 04:19 PM
By Nick McKees37 in forum Product Reviews
Last Post: 03-14-2012, 08:35 PM
By Koast in forum Auto Detailing 101
Last Post: 08-19-2009, 07:41 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
25 | 26 | 27 | 28 | 29 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 | 2 | 3 | 4 | 5 | 6 |
Bookmarks
