Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Regular Member superd's Avatar
    Join Date
    Feb 2010
    Posts
    104
    Post Thanks / Like
    Best way to remove Ice from windows
    What is a safe way to remove ice from a windshield without scratching the glass? Winter is almost here and I need to get prepared, my SUV just turned into a daily driver.
    Which will come first.........BOBO's or time to leave work?
  2. #2
    Super Member SeaJay's's Avatar
    Join Date
    Aug 2010
    Location
    Billerica, MA
    Posts
    3,070
    Post Thanks / Like
    Re: Best way to remove Ice from windows
    I would say a good ice scrapper and you should be fine. I've never had a problem scratching my glass using an ice scrapper. I'm sure someone will comment with their solution without using an ice scrapper, but by far I would think that this is the easiest method, unless you put de-icer in a spray bottle and use that.
    Also...I think it's going to be time to leave work that wins this one! At least for me...I have an hour left unless I decide to leave early...which I may just do.
  3. #3
    Junior Member
    Join Date
    May 2009
    Posts
    49
    Post Thanks / Like
    A good plastic ice scraper with a smooth edge. Do not use anything that has a metal edge.
  4. #4
    Super Member Dubbin1's Avatar
    Join Date
    May 2009
    Posts
    3,845
    Post Thanks / Like
    What works for me is leaving the car in the garage
    I don't scrape ice, I have a remote car starter and leave the defroster and fan set to high when I get out.
  5. #5
    Super Moderator Meghan's Avatar
    Join Date
    Mar 2006
    Location
    Florida
    Posts
    15,036
    Post Thanks / Like
    Quote Originally Posted by superd View Post
    I have two good answers for your two questions, one, move to Florida, no ice allowed.... two depends if you leave before 5pm? I see BOGOs arriving around 430pm'ish
  6. #6
    Join Date
    Aug 2010
    Location
    Billerica, MA
    Posts
    3,070
    Post Thanks / Like
    I forgot about the automatic starter. That saves me a ton in the winter. Also is nice to jump into a toasty car/truck when it's 10 degrees outside.
    Meghan - Not all of us have the option to move some where warm! Trust me if it was that easy I would have done it a long time ago! I hate the winter!
  7. #7
    Join Date
    Feb 2010
    Posts
    104
    Post Thanks / Like
    Quote Originally Posted by Meghan View Post
    Meghan I'm bored and was hoping to pass the last hour or so at work getting paid to place my orders!! Does autogeek offer a Florida package in the "winterizing" section? My wife has been pressuring me to move to Flordia for the past year, what's the attraction? Perfect weather, the ocean, attractive women, autogeek? The order of importance, and content, are up for debate.
  8. #8
    Join Date
    Aug 2010
    Location
    Billerica, MA
    Posts
    3,070
    Post Thanks / Like
    Yeah you are on the wrong end of a loosing battle there! I've been getting harassed to sell my house and move to Florida or Hawaii....If it happens it's going to be Florida...much cheaper to move to and no 16 hour flights!!
  9. #9
    Join Date
    Feb 2010
    Posts
    104
    Post Thanks / Like
    Quote Originally Posted by Dubbin1 View Post
    Good thinking! I park inside at home, but when I come out from work it would be easy to use.
    Quote Originally Posted by SeaJay's View Post
    I'm still mad at my parents for not raising me in a warm ocean climate! I agree with you, Florida would be the place to go.
  10. #10
    Super Member Wax Gorilla's Avatar
    Join Date
    Jul 2009
    Posts
    448
    Post Thanks / Like
    Water warmed between 12 and 16 degrees hotter than the ambient temperature and poured from the top of the glass down slowly. All Tempered Vehicle Glass will survive this. If you heat the water to 35 degrees hotter than ambient temperature you are playing roulette. Also always warm the glass from the inside by either heating the cars interior or using a defrost cycle. All of the above does not work once the ambient air is at 35 degrees or lower. If below freezing use a mix of warm water 3 parts to 1 part rubbing alcohol.
Similar Threads
  1. I used opti-seal on my windows, how to remove?
    By MrOneEyedBoh in forum Auto Detailing 101
    Last Post: 02-03-2014, 07:38 AM
  2. How do I remove streaks from windows?
    By Wiserphil in forum Ask your detailing questions!
    Last Post: 06-19-2013, 09:24 AM
  3. How To Remove Water Spots on Windows - Pinnacle Style
    By Nick McKees37 in forum How to Articles
    Last Post: 12-11-2012, 01:44 AM
  4. Replies: 4
    Last Post: 01-04-2011, 09:35 AM
  5. Remove swirl marks in windows?
    By WRAPT C5Z06 in forum Auto Detailing 101
    Last Post: 12-12-2010, 05:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
