Dislikes: 0
Re: The benefits of a light paint cleaner, cleansing lotion or pre-wax cleaner
looks like prev wax has to be removed by polish or cleaner to stick to paint - isn't it?
can wax cleaner eliminate clay step for lazy?
Cleaning the paint before applying a new coat of wax or paint sealant insures the surface is clean and free from any kind of surface contamination and impurities. This will maximize the clarity, depth and gloss and create a fresh base for the new protection ingredients to bond to.
Not really as claying is the most effective way to remove above surface bonded contaminants. using a polish or paint cleaner by hand can remove some of any built-up above surface bonded contaminants, but using detailing clay is the most effect way to remove above surface bonded contaminants.
Here's two related articles...
How to use a hand applied abrasive polish or paint cleaner by hand
Junior Member
Thanks Mike. I got a new car recently and I used the Wolfgang Paintwork Polish Enhancer and the Deep Gloss Paint Sealant. I did the same on a couple of my friends' cars and it's about time to do it again. I've found that a little DGPS goes a long way, as I've used much more of the Wolfgang Polish than the DGPS. I'm very impressed with both products.
Super Member
seen to much marring of paint by clay ever use it if a polish is not going to follow
Super Member
Mike, I just tried the Pinnacle Lotion today after M205 and thought it left the paint slicker than just the M205 alone. I did however do an IPA wipedown after M205 and prior to the lotion....was that a wasted step? I also did another IPA after the lotion...probably another wasted step. LSP was 845 FWIW.
Now sorry if i ask something thats already been answered but, like the Meguiar's 5 step process the second step says to clean (paint cleaner) and the third step says to polish and the wax? Im sure this has been asked many times so can someone send me a link to better understand what process should be taken? And should it be done every time? Again sorry I'm a detail oriented person that has to dissect everything. (that could be a good thing)
Originally Posted by nesto
Now sorry if i ask something thats already been answered but, like the Meguiar's 5 step process the second step says to clean (paint cleaner) and the third step says to polish and then wax?
That's correct for the Meguiar's system because they offer non-abrasive polishes that the primary purpose of which is to simply add gloss and clarity.
Most polishes contain abrasives, but with a non-abrasive polish you could add another step that doesn't including any abrading or cleaning effect.
I actually wrote the original "The 5-Step Paint Care Cycle" article, Mike Stoops re-wrote it and updated it with pictures of new products after I left Meguiar's. He's actually re-written a few of my articles and he's done a really good job but some of his articles are actually articles I originally wrote.
When I went to work for Meguiar's the second time in 2002 starting out as the "Corporate Write", I took it upon myself to write "The 5-Step Paint Care Cycle" because they didn't have anything or at least any "article" that explained it in detail. They had a graphic picture and some copy around products used for each of the steps but they didn't have a thorough, complete article that explained the idea of maintaining your car's paint via 5-steps.
I still have the original version I wrote because when Mike Stoops re-wrote my article he removed a lot of the original content, which made it much shorter and less in-depth as my curse is being a long copy writer and I tend to go into a lot of depth. Most people don't want the depth, just the short answer. (Sorry, again it's a curse to be a long copy writer).
Back to your question, in the early days, when we only had single stage paints, after cleaning or abrading the paint, (I have an article on MOL on the topic of "cleaning" as Meguiar's defines it), the next step would be to apply a pure or non-abrasive polish, which would be absorbed into the permeable or porous single stage paint and create depth and richness of color. IT would also act to create a glossy finish, all characteristics "Car Guys and Gals" like to see in their car's paint.
With modern clear coats, the paint is dramatically less porous, or impermeable, and so the polishing oils found in products like #7 Show Car Glaze, #3 Machine Glaze, #5 New Car Glaze, #81 Hand Polish, Deep Crystal Polish, (These are all non-abrasive, pure polishes), will tend to be topical, that is sitting on the top surface of the paint, not penetrating into the paint.
So some people don't see any benefit to applying a pure, non-abrasive polish after the cleaning step especially in light of the fact that today, modern "light polishes" leave the paint looking flawless and a pure polish don't tend to build-on or increase the achieved results.
Also, something people forget is a brand new car with brand new factory paint already looks GREAT, it's really hard to make a dramatic change in before and after by simply applying a non-abrasive polish or even a wax or paint sealant for that matter. That's one of the cool things about modern paint technology, it' looks good right out of the booth.
In the old days, after spraying a solvent-evaporation paint like single stage lacquer or enamel, especially with lacquers and the spray gun technology used back then, it WAS easy to make the paint look better by either machine buffing, or wetsanding and then machine buffing. In some cases, if you go back far enough they would hand-rub the paint to increase the gloss, clarity and richness of color of a single stage lacquer paint job and that's where the term,
"Hand Rubbed Lacquer Paint"
came from... Note how you never hear the term,
"Hand Rubbed Basecoat/Clearcoat Paint"
That's because modern clear coats tend to be harder, in fact so much harder that it's really hard to rub one out like you would the old school way with a soft lacquer paint... but I digresss...
See these articles,
The practical differences between single stage paints and a clear coat paints
The Lesson White Paint Teaches Us
And see this article for some in-depth information on #7 Show Car Glaze and how it works with single stage paints.
The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints
Excerpt... (it's really long with lots of pictures)
Originally Posted by Mike Phillips
This is key...
Saturation Application --> The First Application
This is a mostly unknown technique and that is to let the first application penetrate and soak into the paint for up to 24 hours before wiping the product off. The idea being to really apply the product wet and work it in really well and the walk away.
The idea is to allow the heavy concentration of oils to penetrate and seep into the paint for maximum saturation before removing the product and continuing with the process. In this case I finished applying the first application of #7 around 9:00 pm and then left the #7 to soak in until the next day. I started wiping the product off then next morning right about 10:00am.
Some will argue if this works or not buy my experience is that with a porous single stage paint it does in fact help. One thing for sure it can't hurt.
Paper Test for Capillary Action
If you place a few drops of #7 onto a piece of paper and then monitor it over a few days you will see the oils in the #7 migrate or seep away from the actual drop of product. It does this through capillary action and the same thing can work to your car's paints' advantage if it's a single stage lacquer or enamel paint.
I placed a few drops about the size of a nickel on a piece of standard printer paper around 3:00pm.
The next day I took these pictures at approximately 10:00am, (19 hours later), note how the oils in the drops of #7 have migrated outward via capillary action.
Feeder Oils penetrate or feed the paint
This same effect can take place in a single stage paint but not only will the oils travel horizontally, they will also travel vertically, that they will penetrate downward "into" your car's paint and this is where the term feeder oils comes from as the oils penetrate into or feed the paint. The result is they will condition the paint restoring some level of workability as compared to just working on old dry paint, and they will also bring out the full richness of color, something that will showcase the beauty of your car's paint.
So to bring this back to the idea of polishing a second time if you were using two products that both abrade the paint, this is done all the time for example using Wolfgang Total Swirl Remover which is a type of polish followed by Wolfgang Finishing Glaze which is type of "lighter" polish but it would not fit the definition of their non-abrasive, pure polishes.
BUT, everyone knows that following a the first polishing step with a lighter polish, (that abrades the paint even if just a little bit), does result in a nicer looking finish.
The the 4th Step, "Protection" or "Protecting" is their step for applying a coating of wax or paint sealant to lock in the shine and provide long lasting protection from the elements and anything that would come into contact to harm the paint.
I'm sure this has been asked many times so can someone send me a link to better understand what process should be taken? And should it be done every time? Again sorry I'm a detail oriented person that has to dissect everything. (that could be a good thing)
Great question actually, I'm not sure I've re-written for this forum my original "The 5-Step Paint Care Cycle" for this forum, it's always difficult to plagiarize myself.
In a nutshell,
The Multiple-Step Paint Care Cycle
Step 1 - Wash and dry the car
Step 2 - Inspect the paint for Above Surface Bonded Contaminants
Step 3 - If your physical inspection of the paint reveals a rough or textured surface then using detailing clay to clay the paint
Step 4 - Inspect the paint for swirls and scratches, if discovered then remove through polishing.
Step 5 - Remove swirls and scratches. If you have to use an aggressive product to remove the Below Surface Defects, then you'll want to do a second polishing step with a less aggressive product to maximize gloss and clarity and ensure no hazing from the aggressive step remains int the paint.
Step 6 - The second polishing step I just mentioned above
Step 7 - Protection - Apply a coat or two of your favorite wax or paint sealant.
Step 8 - Maintenance - This is where you use Spray Detailers and Spray-on Waxes to maintain the results you achieved by all the above in-between a normal car wash and a regular coat of wax or paint sealant.
Clear as mud?
How often to you repeat any of the steps above?
Simple, wash and dry the car, or use a waterless wash, rinseless wash, or spray detailer to get the paint clean and free from any loose dirt. The reason for this is because to figure out how often you have to do any of the above you have to INSPECT the paint.
- Inspect with your sense of touch to see if you need to clay the paint.
- Inspect visually with your eyes in bright light for swirls and scratches.
Both of these must be done with the car clean, thus the washing and drying step.
I have a very in-depth article on this in the works...
Great questions.... sorry I missed this when you originally posted it... been kind of busy the last few months with behind the scenes projects and the work that goes into them... I touch on that here,
Autogeek's How-To Features on My Classic Car with Dennis Gage
Back to your questions... whether or not the IPA wipe-down steps were a waste of time or not depends upon the purpose behind them. If you're checking to make sure you've 100% removed the defects with your paint correction process, then probably not.
Some people wipe down each square inch of the paint and inspect 100% of all the paint as they work around the car. If you have confidence in your skill level, then theoretically, if you inspect your "Test Spot" and find you're process together with your skill and ability is removing all the defects, then theoretically, if you duplicate this process over the rest of the paint you'll continue getting the same results thus wiping and inspecting is not needed and just takes up more time and can dull or mar the paint.
If you're wiping the paint with IPA to remove any residual polishing oils so the wax or paint sealant will better bond to the paint then I have an article on this topic an each person has to decide for themselves the process they want to use...
Miscible and Immiscible - Wax and Paint Sealant Bonding
Thanks Mike!! I look forward to reading that article.
Nice writeup informative.
"American by birth Southern by the Grace of God"
Similar Threads
By 65vw in forum Ask your detailing questions!
Last Post: 09-11-2015, 12:14 PM
By emmjay in forum Ask your detailing questions!
Last Post: 06-11-2015, 12:38 PM
By MinnBobber in forum Ask your detailing questions!
Last Post: 08-10-2012, 05:10 PM
By Ztandem in forum Auto Detailing 101
Last Post: 09-09-2010, 01:05 PM
By sullysdetailing in forum Product Reviews
Last Post: 12-09-2009, 05:55 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
