Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Super Member Mike Moore's Avatar
    Join Date
    Dec 2009
    Location
    Sunny South Florida
    Posts
    967
    Post Thanks / Like
    Process - Glaze, Paint Sealant, Wax?
    Newbie question:
    What is the correct procedure?
    Glaze
    Paint Sealant
    Wax
    or
    Paint Sealant
    Glaze
    Wax
    On a black vehicle, I am using Poorboys's SSR2, SSR1, EX-P, Black Hole Glaze then wax.
    Is this the correct order?
  2. #2
    Super Member bmw5541's Avatar
    Join Date
    Jul 2009
    Location
    Flanders, NJ
    Posts
    334
    Post Thanks / Like
    Re: Process - Glaze, Paint Sealant, Wax?
    Quote Originally Posted by merlin View Post
    Newbie question:
    Glaze
    Paint Sealant
    Wax
    or
    Paint Sealant
    Glaze
    Wax
    You would do:
    Glaze
    Sealant
    Wax
    However, there are many sealants that will not adhere to the paint if you use a glaze. I would skip the glaze, and clay, polish, seal, wax.
    I hope this helps.
  3. #3
    Super Member Matt S.'s Avatar
    Join Date
    Jan 2007
    Location
    Florida
    Posts
    1,909
    Post Thanks / Like
    "Glaze" has become a vague term in that some are pure with no cleaners, and some do contain cleaners and/or light abrasives. PB Black Hole contains cleaners, so you want to use that FIRST, before the sealant and wax.
    bmw5541's process is correct, but in this case, EX-P won't have a problem bonding to Black Hole. So, you can wash, clay if necessary, use SSR2, SSR1, Black Hole, EX-P, then a wax of your choice,
  4. #4
    Junior Member
    Join Date
    Nov 2006
    Posts
    65
    Post Thanks / Like
    I've always done machine polish (PO106FF), sealant (Wolfgang Deep Gloss Paint Sealant) and topped it with souveran.
    I was wanting to use the Menzerna Glaze for a car with light swirls (too many paint corrections over the last 3 years, so don't want to keep removing clear) use the WDGPS, and then top it with Fuzion wax on a blue M3. Does this sound like a decent plan?
  5. #5
    Mike Phillips
    Guest
    Quote Originally Posted by bmw5541 View Post
    You would do:
    A lot of people post statements like that but there's never any proof to back it up? In fact statements like that are all over detailing forums kind of like the old comments,
    You need heat to break the abrasives down
    which area also wrong.
    I have yet to walk out into a garage and a coating of paint sealant that has slipped-off the car and piled up on the ground surrounding the car because it didn't bond to the paint.
    A person should always follow a manufactures instructions because they are the ones that made their products. I wrote a very detailed explanation of the whole bonding topic on MOL and it's still over there and in the last 5-6 years no one has ever challenged it.
    The link to that thread can be found in my reply on page 2 of this thread,
    http://www.autogeekonline.net/forum/...-sealants.html
  6. #6
    Join Date
    Dec 2009
    Location
    Sunny South Florida
    Posts
    967
    Post Thanks / Like
    What is the wait time between Black Hole Glaze , EX-P then wax?
  7. #7
    Mike Phillips
    Guest
    The Black Hole Glaze is said to clean the surface, (not abrade it), and then fill in minor imperfections and is also referred to as a wax on the webpage for the product.
    32 oz. Poorboy’s World Black Hole Show Glaze for Dark Vehicles
    In addition to disguising blemishes, Poorboys Black Hole Show Glaze for Dark Vehicles cleans the paint. Swirls can be more noticeable when they’re filled with grime, so this special formula lifts out dirt and then fills in swirls with glaze. In just one quick step, your vehicle will be swirl-free and incredibly glossy!
    And it also says it's a wipe on wipe off product and a wax...
    Poorboys Black Hole Show Glaze for Dark Vehicles is a wipe on, wipe off product. Spread the wax on with a soft, clean foam applicator.
    The sentence below is at the bottom of the page...
    Poorboys Black Hole Show Glaze for Dark Vehicles makes it easy to maintain a show car perfect shine all the time! Wipe it on, wipe it off, and enjoy the shine.
    If applying by machine it reads like you're supposed to let it dry...
    If applying by machine, set your polisher to a low speed and work until a shine begins to appear. Allow it to dry to a haze and then buff off with a clean, soft Cobra Microfiber Towel.
    So it reads like it's a cleaner/wax; as such after you remove the dried residue, you can then apply the EX-P, again from the webpage for the product...
    Then apply Poorboys Black Hole Show Glaze for Dark Vehicles to improve gloss. Finally, top the paint with Poorboys World EX Sealant with Carnauba.
    The EX-P is a paint sealant and it reads like you can apply it immediately after you remove the Black Hole Glaze.
    Poorboy's EX-P Pure Sealant: Poorboy’s EX-P is revolutionary in the world of paint sealants. poorboys paint sealant, car paint sealant, clear coat
  8. #8
    Join Date
    Dec 2009
    Location
    Sunny South Florida
    Posts
    967
    Post Thanks / Like
    After applying the SSR2, SSR1, Black Hole Glaze, EX-P process...
    Should I wait 12 hours and then apply a second coat of EX-P sealant?
    Is the wait time 12 hours after that before applying wax?
    I'm thinking about using Collinite 915 then 845.
    Should I wait 12 hours between each coat of wax?
    BTW - I just finished the SSR2, SSR1, Black Hole Glaze, EX-P process and it looks pretty darn good so far.
    (Applied one coat Black Hole and then one coat EX-P)
  9. #9
    Join Date
    Dec 2009
    Location
    Sunny South Florida
    Posts
    967
    Post Thanks / Like
    Thanks for the assistance...I found this info on the Poorboy's forum.
    "There is no cure time for White Diamond or Black Hole.
    You can apply these more than once but I wouldn't exactly call it layering even though the shine will get deeper and it may hide a little more with each application.
    EX-P like most sealants will give its best shine and durability if left to cure for 24-72 hours without getting wet. 2-3 coats will get the most out of EX-P.
    Natty's is basically cured about an hour after application.
    The exception would be Natty's Red which sets up best after a day or two"
    Wish I'd have found this first...I would have worked in another coat or two of Black Hole before the EX-P.
  10. #10
    Junior Member
    Join Date
    Nov 2006
    Posts
    65
    Post Thanks / Like
    Quote Originally Posted by Malu59RT View Post
    anyone?
Similar Threads
  1. Help me find a Glaze with fillers for this process...
    By Jester7677 in forum Auto Detailing 101
    Last Post: 07-11-2017, 05:50 AM
  2. WG 3.0 Deep Gloss Paint Sealant over Klasse Sealant Glaze?
    By BuffaloBill in forum Wolfgang Car Care
    Last Post: 11-07-2015, 06:09 PM
  3. Does a glaze interfere with a paint sealant?
    By gp99 in forum Ask your detailing questions!
    Last Post: 10-13-2015, 07:33 AM
  4. Detailing process after sealant question.
    By Teebs in forum Hot topics & Frequently Asked Questions
    Last Post: 02-23-2013, 05:27 PM
  5. Body Shop Safe Glaze on Fresh Paint - #7 Show Car Glaze
    By Mike Phillips in forum How to articles
    Last Post: 12-12-2012, 09:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
