Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    Super Member
    Join Date
    Jun 2009
    Posts
    210
    Post Thanks / Like
    Re: Detailing a jet ski
    Quote Originally Posted by Lasthope05 View Post
    Jet ski's and boats dont have clearcoats. They have gel coats which is basically pigmented epoxy resin. The paint looks dull because of the fact that the gel coating has oxidized similar to how single stage paints oxidizes.
    Is that on top of the color? Or is it a single stage type of paint? When I polished our Seadoo, there was no color transfer on to my pad... I guess it could just be because I was using a finishing polish.
  2. #12
    Super Member Gary Sword's Avatar
    Join Date
    Nov 2006
    Location
    Southwest Florida
    Posts
    4,168
    Post Thanks / Like
    On my jet skis the haul is gel coated fiberglass but there are a lot of parts that are single stage painted plastic. It would take much to go through the single stage paint with an aggresive compound so one needs to be careful.
  3. #13
    Super Member Lasthope05's Avatar
    Join Date
    Aug 2007
    Location
    Philadelphia, PA
    Posts
    1,113
    Post Thanks / Like
    Quote Originally Posted by CTS-Veo View Post
    No it is not on top of the color it is similar to how SS paint is with the color and gelcoating mixed together.
    Quote Originally Posted by Gary Sword View Post
    Yup your right. Only the haul is gelcoated and there is no particular reason to be careful except around trim since the coating is fairly thick.
  4. #14
    Regular Member
    Join Date
    Nov 2006
    Posts
    124
    Post Thanks / Like
    Quote Originally Posted by Meghan View Post
    Gary is right with salt water doesnt really matter what you do, salt water always wins. Not sure if you are using it in fresh or salt but either way there are things you can do to protect it. 303 is one of the best for the UV protection, but there is a lot you can do to restore the faded areas. Just needs a good polishing, and there are several sealants that do hold up better in the water, I like the Collinite Double Coat and or the Klasse twins.
    2001 Wave Runner- Fuzion Style
    Is this the collinite you are talking about Meghan?
    18 oz. Collinite Super DoubleCoat Auto Wax #476, carnauba wax
  5. #15
    Super Member sullysdetailing's Avatar
    Join Date
    Mar 2009
    Location
    South Florida
    Posts
    1,963
    Post Thanks / Like
    Quote Originally Posted by krouchchocolate View Post
    Has anyone ever detailed a jet ski before?
    Also I just recently purchased a used jet ski, but the front of the jet ski is partially faded from staying out in the sun for too long. Is there anything I can do to restore the "gloss" back into it?
    The black part right under the yellow part is where it is dull. Next to the TX numbers.
    I would attack it like polishing any other boat. Use a rotary, compound, polish, seal it.
    The salt water can do so pretty bad damage to your PWC or boats. After you remove all of the oxidation, take it out of the water and wax it regularly.
    Shawn
    Sully's Detailling LLC - South Florida
    www.autogeek.net
  6. #16
    Super Moderator Meghan's Avatar
    Join Date
    Mar 2006
    Location
    Florida
    Posts
    15,036
    Post Thanks / Like
    Yes it is
  7. #17
    Mike Phillips
    Guest
    Are you working by hand or by machine and if machine, which type?
    Always match the product to the surface being treated, so
    • Treat paint like paint
    • Treat gel-coat like gel-coat
    The exception would be it's usually okay to use Automotive products on Marine craft but you don't want to use any kind of Marine compounds on Automotive paints as they tend to be a lot more aggressive, this is why it's safest to use Marine product for Marine craft and Automotive products on Automotive paints.
    It's both the hardness and thickness factors characteristic to gel-coats that come into play as pointed out and the thinness factor when it comes to automotive paints.
  8. #18
    Regular Member
    Join Date
    Nov 2006
    Posts
    124
    Post Thanks / Like
    Quote Originally Posted by Mike.Phillips@Autogeek View Post
    I will be working it with the Porter cable 7424(not sure if this was the model) with the edge 2000 pad kit.
    Which marine products would you recommend to polish the oxidized area?
  9. #19
    Mike Phillips
    Guest
    On my 1976 Starline Deville, everything I tested worked great although some of it was for automotive use.
    1967 Starline Deville - Extreme Makeover
    The 3M Marine Line worked well and it's a dedicated line for Marine Products. From page 2 of the above thread.
    Quote Originally Posted by Mike Phillips
    Someone asked me about the 3M Marine Line so I've taped off a section on the back of the boat to demonstrate the 3M Marine Rubbing Compound with a 8" Wool Cutting pad on the Flex Lightweight Rotary Buffer.
    Note that I've removed anything off the rear deck that can be removed without too much work to enable me to do the best job of restoring this 42 year old gel-coat. Plus then I can clean up the holes a little and the thread for all the stainless steel screws and re-assemble everything nice and clean.
    Here's the results from the compounding step.
    I spent a lot of time compounding each square inch, I applied and removed 3 applications of compound with the wool pad. After that I used a yellow foam cutting pad and it seem to dull down the finish, so I re-buffed the entire area again with the wool cutting pad.
    Here's the results, the gel-coat is very glossy but if you look at the second picture, it's also very hazy and this haze is the swirls left by the abrasives in the compound and probably also the fibers of the wool pad. You can see that after polishing the DOI is going to increase.
    DOI = Distinction of Image. That is how clearly you can see the details of a reflected image.
    In keeping within a system approach I'm going to use the 3M recommended Marine Finess-it II Glaze with a 3M Polishing pad.
    Started with a 3M foam polishing pad (Per Manufactures instructions)
    While it was working okay the 8" size pads are just too big for the shape and design of the back upper surface of this boat. So I switched over to the 5.5 Hydro-Tech Tangerine Foam Polishing and kid you not, this is a smooth polishing combo that quickly removed all the haze and brought the gel-coat up to a very high gloss.
    Next I applied the 3M Marine Liquid Wax and because I prefer to apply all my LSP's by machine I used the Griot's Garage ROP on the 3.0 speed setting with a Meguiar's W-8006 foam polishing pad.
    After applying the wax I came back to my office, uploaded the photos and posted this update. I'm going to go back out to the AG Garage and start cleaning up, I'll take a picture to show you just how much of a mess buffing out just one corner of this boat made and here at work we try to leave the garage cleaner than when we found it. (It's always clean so that's not saying much).
    Maybe read through the entire Starline Deville thread, you might pick up a few pointers...
    Also, Meguiar's makes an Oxidation Removal Kit and dedicated products, let me know which line you want to use and I'd be happy to make a recommendation.
  10. #20
    Regular Member
    Join Date
    Nov 2006
    Posts
    124
    Post Thanks / Like
    Mike,
    Thanks for all your help man! Are the meguiar's or the 3m the type of marine products I can find locally at my auto parts store, or would you have to order them online?
Similar Threads
  1. September 3-Day Detailing Bootcamp Class - the MOST hands-on car detailing classes on Planet Earth!
    By Mike Phillips in forum 3-Day CAR Detailing Bootcamp Classes - Info & Dates
    Last Post: 08-24-2020, 11:58 AM
  2. September 3-Day Detailing Bootcamp Class - the MOST hands-on car detailing classes on Planet Earth!
    By Mike Phillips in forum PICTURES: 3-Day CAR Detailing Bootcamp Classes
    Last Post: 08-17-2020, 03:25 PM
  3. Replies: 24
    Last Post: 07-06-2017, 02:18 PM
  4. Flex 3401 Detailing Classes - Show Car Detailing and Production Detailing
    Last Post: 12-05-2014, 05:04 PM
  5. Year 2 in Detailing - How to Make Money Detailing - B & B Detailing - Nashville TN
    By Bates Detailing in forum How to make money detailing cars
    Last Post: 01-10-2013, 12:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
