Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. #1
    Super Member DARK HORSE's Avatar
    Join Date
    Sep 2009
    Posts
    2,537
    Post Thanks / Like
    Are California Car Dusters safe to use?
    Are California Car Dusters safe to use on the paint of my black car. Can they scratch the paint. Does anyone use these?? I have a black car and I can detail it, put it in the garage and two hours later have dust all over it. The duster seems to work great for removing the dust off my clean car. Is it safe for the paint?? Anyone else use these or have an opinon? Also any opinons on using DP waterless auto wash for spot cleaning and bug removal of a maintained clean car??
    Signature Car Care... Authorized CQuartz Finest Installer
    http://www.signaturecarcare.com/
    "May the shine be with you" Uncle Stu
  2. #2
    Super Member RTexasF's Avatar
    Join Date
    Jun 2006
    Location
    North TX
    Posts
    2,582
    Post Thanks / Like
    Re: Are California Car Dusters safe to use?
    I have never had a problem with one..........EVER. Follow the directions to the letter (getting it ready) and learn to lightly swipe the car not rub the duster into the finish. More than ten years with zero problems. Use it as a duster not a wiper. Keep in mind it is for dust or pollen, nothing more.
    Rick....now in North Texas
  3. #3
    Junior Member
    Join Date
    Aug 2009
    Location
    Los Angeles
    Posts
    50
    Post Thanks / Like
    Quote Originally Posted by RTexasF View Post
    +1. I've seen a lot of opinions on this, but I too, have not had problems. I let the dreds lightly glide over the finish, sometimes shaking the CD out after one pass, say on the hood, etc. I usually use the CD the following morning, when the paint is nice and cool, and yes, my daily driver is usually garaged/car port at night.
    IMO, the key is to know when you have enough buildup to warrant an actual washing. Some also have issues using a CD on black or dark blue paint and I'll let them respond about that.
    "Opportunity may knock only once, but temptation leans on the doorbell." ~ Author unknown.
  4. #4
    Super Member
    Join Date
    Mar 2009
    Posts
    1,268
    Post Thanks / Like
    I've never seen a problem on black lacquer paint or clear coated black. As long as the car is well waxed, the wax will protect the paint from any micro marring which could occur by removing light dust with a light swipe. it is a lot quicker than using just a qd as well, because with a qd, you would need maybe 3-5 towels to do the whole car, but with the car duster method, followed with a qd like Griot's Garage Speed Shine, it is the fastest and easiest way to restore the car to a show car shine, with only 1 or 2 towels, tops. Lets face it, regular qd use can be expensive, so if you use the duster first, you will be saving yourself some money as well as time.
    Now, if you had a black car that was perfect in every way, with soft paint, then you would use a waterless wash every time the car got dusty, because you would be that obsessed about not taking any chance whatsoever in getting even the slightest marring, even on your fine wax job. That would only be for a Concours car that never gets driven anyway.
  5. #5
    Regular Member
    Join Date
    Aug 2009
    Posts
    125
    Post Thanks / Like
    just waxed the car, and someone scratched it, some are not so deep, but a couple appear to go thru the clear coat. only problem is that i dont have an orbital, and will have to do it by hand. any recommendations as to what product might remove these?
  6. #6
    Super Member
    Join Date
    Mar 2009
    Posts
    1,268
    Post Thanks / Like
    Quote Originally Posted by molarman View Post
    If the scratches go through the clear, the only thing that will fix that is paint. Either repaint the panel, or clean the scratch with mineral spirits and fill with clear touch up paint, and then sand and polish the touch up paint part flush with the rest of the paint.
  7. #7
    Super Member Rsurfer's Avatar
    Join Date
    Jan 2007
    Posts
    14,094
    Post Thanks / Like
    Quote Originally Posted by Blackthornone View Post
    This is in the wrong thread, but why would you recommend a clear instead of a matching touch up paint?
  8. #8
    Super Member
    Join Date
    Mar 2009
    Posts
    1,268
    Post Thanks / Like
    Quote Originally Posted by Rsurfer View Post
    Because he said the car was clear coated and that the scratch was in the clear coat. He did not say that the color was missing. The clear coat is what is on top, and therefore that is the surface that must be matched.
  9. #9
    Super Member Matt's Avatar
    Join Date
    Aug 2008
    Location
    Auckland, NZ
    Posts
    1,275
    Post Thanks / Like
    I know some people on here like them, but I would NEVER let a California Car Duster touch my paint, if you're so careful when washing and drying about not creating swirls, then why would you take a duster then rub it on a DRY and DUSTY surface.
    You may as well dry your clean car after washing with a waterblade or old T-shirt if you're using a Cali Duster.
  10. #10
    Super Member Gary Sword's Avatar
    Join Date
    Nov 2006
    Location
    Southwest Florida
    Posts
    4,168
    Post Thanks / Like
    I would never use one on my paint.
Similar Threads
  1. Who Uses a California Car Duster ? Are they safe ?
    By alexramsey in forum Ask your detailing questions!
    Last Post: 12-09-2017, 06:48 PM
  2. Where are the California Dusters At?
    By hoyt66 in forum Auto Detailing 101
    Last Post: 05-01-2012, 12:51 PM
  3. How safe is the California duster??
    By dinkydow in forum Auto Detailing 101
    Last Post: 09-16-2006, 09:31 AM
  4. Dusters - California VS OXO.
    By supercharged in forum Auto Detailing 101
    Last Post: 05-17-2006, 04:36 AM
  5. california water blade...safe?
    By Kelso in forum Auto Detailing 101
    Last Post: 05-06-2006, 06:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
