Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Administrator Jason's Avatar
    Join Date
    Mar 2006
    Posts
    354
    Post Thanks / Like
    Foamaster Foam Wash Gun
    Our latest find is the Foamaster Foam Cleaning Gun with brass fittings.
    The idea behind a foam gun is to minimize the amount of rubbing and scrubbing necessary to clean the vehicle by pre-soaking it with frothy foam.The foam starts loosening and lubricating the paint immediately. As you work your way down and around the vehicle with a mitt or sponge, you don’t have to use as much force to remove dirt and debris. It’s already loose and just needs slight agitation to release it from the paint surface.
    This gentle touch substantially decreases the risk of micro-marring because the paint is covered in a foamy layer of lubrication. Used in combination with a premium car shampoo, the Foamaster is a guaranteed safe way to wash your vehicle.
    We compared several guns and found that the Foamaster is the best for car washing. It creates a substantial amount of foam by forcing water through the nozzle where it mixes with the diluted car shampoo that is in the gun’s reservoir. The foam is richer, thicker, and sticks to the vehicle longer than soap applied by hand because the dilution ratio of the soap is higher.
    Many detailers we talked to use the Foamaster as they wash with a mitt or sponge, instead of as a pre-soak, or sometimes in addition to a pre-soak. This technique involves spraying the foam directly in your mitt’s path. The foam is its frothiest upon contact so this method ensures a thick, sudsy layer of foam between the mitt and the paint surface. If you use this technique, just take care to avoid hitting the nozzle on the paint as you disperse the foam. Since you’re using both hands, this takes a little coordination. Practice makes perfect!
    The Foamaster’s nozzle mechanisms is constructed of brass, giving it excellent, long-lasting performance and durability. The handle, foaming tip, and reservoir lid are all made of heavy duty plastic, and the reservoir itself is chemical resistant polyethylene. This industrial grade foam gun is used by more detailers and enthusiasts because it’s built to last.
    Multi-ratio Stem - The multi-ratio stem gives you five settings so you can adjust the dilution ratio of your shampoo. The chart below shows you the shampoo (oz.) to water (gal.) ratio based on the position of the stem.
    Features
    Accurately mixes and sprays foaming chemicals
    Foam generating wand creates a thick, clinging foam
    Detach handle for a powerful spray rinse
    For cleaning, degreasing or disinfecting when a foam is desired to increase surface contact time
    Easy to fill wide mouth, chemical resistant polyethylene quart or half gallon bottle
    Built-in screen filters out sediment before it reaches your vehicle
    *If you are going to use the Foamaster on your vehicle, use it exclusively for your vehicle to avoid cross contamination.
    Operational Specifications
    Water Pressure - 40 to 90 psi (for maximum accuracy 40 to 60 psi)
    Output - 1-1/2 gallons per minute
    Spray Pattern - Foaming attachment provides a fan spray, removes for a solid stream. Deflectors are available for fan spray patterns for non-foaming chemicals.
    Anti-siphon - Protects water supply by preventing soapy water from siphoning back into the hose. (Note: a slight discharge of water from base of handle when water is turned off is normal and indicates anti-siphon is functioning properly.)
    Customized Ratios - Can be set from 1oz. per gallon to 12 oz. per gallon. (Note: this range is affected by the viscosity of the chemical.)
    I recommend using Pinnacle Bodywork Shampoo in the Foamaster Foam Wash Gun. This shampoo is super-sudsy when used in a bucket; just imagine how much foam it produces when distributed with a foam gun! As always, use a paint-safe wash tool such as a Pinnacle Chenille Wash Sponge or a Sheepskin Wash Mitt.
    After each use, rinse the nozzle and foaming mechanism with clean water to remove any soap residue. This will prevent soapy build-up inside the nozzle and on the brass mechanisms. With regular cleaning, the Foamaster will give you years of trouble-free performance.
    The Foamaster Foam Wash Gun has the features you want and the durable construction you need. Protect your vehicle from micro-marring and wash-induced scratches with the Foamaster!
    "The true spirit of conversation consists in building on another man's observation, not overturning it." Edward G. Bulwer-Lytton
  2. #2
    Super Member GearHead_1's Avatar
    Join Date
    Mar 2006
    Location
    Utah
    Posts
    505
    Post Thanks / Like
    I really like my foam gun. I'm also looking forward to trying some of the new top secret formula along with it. Any word on this new shampoo?
    When it comes to a persons worth, money is a lousy way to keep score.
    - GH
  3. #3
    Super Member ScottB's Avatar
    Join Date
    Mar 2006
    Location
    South Florida
    Posts
    18,803
    Post Thanks / Like
    Quote Originally Posted by GearHead_1
    Who told you about this ???? (joking) I havent even had an opportunity to "test" the unconfirmed newest soap that is supposedly PH balanced a perfect 7, while providing loads of foam and lubrication to make the Gilmour Guns a must have for 2006. Shoot with the Poorboys Suds ... it was nice and slippery already.
  4. #4
    Join Date
    Mar 2006
    Location
    Utah
    Posts
    505
    Post Thanks / Like
    C'mon now! This isn't the only detailing board I'm on.
    I'm just letting the powers that be know that I'm available for product testing and that I've just placed an order. Wink, wink.
    - GH
  5. #5
    Newbie Member stingray's Avatar
    Join Date
    Mar 2006
    Location
    California
    Posts
    17
    Post Thanks / Like
    Cool Foam Gun
    If a strong pressure of water can't remove the dirt & water spots how can this gun do it?
  6. #6
    Join Date
    Mar 2006
    Location
    South Florida
    Posts
    18,803
    Post Thanks / Like
    Quote Originally Posted by stingray
    The foam gun allows you to presoak the finish, and remove some surface contaminents (dust, dirt) that are sitting on top of the finish. The soap provides better lubrication to move these off the finish while the foam encapsulates them. This should reduce some marring seen from forceful water that could be pushing the dirt into or against the finish while trying to remove it.
    It, foam gun, is not removing worked on dirt and the grime that has attached to the paint however. You will still need to wash each panel with the foam gun and a nice sheepskin mitt to remove this. I would also highly suggest using one bucket of clean water (minimum) to clean out your mitt after each panel. As the mitt can also pull dirt into it and away from the finish also.
    I find the foam gun exciting for its ability to get into areas that are commonly missed by most detailers. With the addition of additional canisters and possibly lids, we could see where could quickly switch from car soap, to APC (for wheel wells and undercarriage) and back as necessary. I have asked Jason to consider stocking these addtl items.
  7. #7
    Matt
    Guest
    Attached Thumbnails Attached Thumbnails Foamaster Foam Wash Gun-1502-jpg   Foamaster Foam Wash Gun-1507b-jpg
  8. #8
    Join Date
    Mar 2006
    Location
    Utah
    Posts
    505
    Post Thanks / Like
    Quote Originally Posted by Matt
    Exactly what I'm looking for. I've found the Meguiar's Gold to be a pretty good foamer too.
    - GH
  9. #9
    Junior Member 5000XD's Avatar
    Join Date
    Mar 2006
    Location
    Suriname, south america
    Posts
    57
    Post Thanks / Like
    Oke this is the next thing I'll buy
  10. #10
    Super Member joe.p's Avatar
    Join Date
    Mar 2006
    Location
    Chicago
    Posts
    2,661
    Post Thanks / Like
    Matt anything new on the Foam Soap?
Similar Threads
  1. Foamaster foam gun sale!!!!!!!.....!!!!
    By Elliot@Autogeek in forum Sales & Promotions - For forum members and non-forum members
    Last Post: 01-03-2019, 02:31 PM
  2. Replies: 5
    Last Post: 10-25-2014, 04:21 AM
  3. Foamaster Foam Cleaning Gun
    By ediddy in forum Auto Detailing 101
    Last Post: 12-26-2012, 04:28 PM
  4. DP foamaster foam gun?
    By andrew b in forum Ask your detailing questions!
    Last Post: 12-14-2011, 04:20 PM
Members who have read this thread: 1
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
