Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
Thread: The Final Wipe
  1. #21
    Mike Phillips
    Guest
    Re: The Final Wipe
    ***Update***
    I added a video to the first post of this thread. In the video I demonstrate the final wipe technique...
  2. #22
    Junior Member
    Join Date
    Jun 2012
    Posts
    62
    Post Thanks / Like
    Re: The Final Wipe
    I always use Meguiar's mist&wipe quik retailer is that a bad idea?
  3. #23
    Mike Phillips
    Guest
    Re: The Final Wipe
    Quote Originally Posted by Coakley Carwash View Post
    Depends upon your point of view...
    If you just waxed your car and you want to leave as much wax on the paint as possible you don't want to
    A. Keep wiping and wiping - this won't add more wax, what's the opposite of adding?
    B. Introduce a liquid and wipe - this won't add more wax, what's the opposite of adding?
    In a perfect world, you wipe of the majority of the wax then you give the paint a "Final Wipe" and then you stand back and admire the results and let some time go by for any and all protection ingredients to fully set-up, cure, cross-link, bond, adhere, stick, (whatever term applies best), and THEN if needed, do any touch-up wiping.
  4. #24
    Regular Member Joz132's Avatar
    Join Date
    Feb 2011
    Location
    Chicago, IL
    Posts
    131
    Post Thanks / Like
    Re: The Final Wipe
    Quote Originally Posted by Mike.Phillips@Autogeek View Post
    Just the thought of her heavy metal bracelet that close to the paint makes me uncomfortable.
  5. #25
    Mike Phillips
    Guest
    Re: The Final Wipe
    Quote Originally Posted by Joz132 View Post
    Have no fear... myself and a number of guys were on hand to make sure no harm came to the bracelet...
    Seriously, when I was having Swirl Girls model the cars we were all very careful around the cars the "we" all just polished out. I'm pretty good at NOT undoing hard work.
    Notice how Tina keeps protects the paint between here bracelet and the paint with her finger.
  6. #26
    Join Date
    Feb 2011
    Location
    Chicago, IL
    Posts
    131
    Post Thanks / Like
    Re: The Final Wipe
    I have no doubt that you and the girls were careful, Mike - I was half joking about the bracelet.
    Although, the topic does serve as a good refresher to be mindful of things such as:
    rings, watches, belt buckles, zippers and metal snaps on cargo shorts.
  7. #27
    Mike Phillips
    Guest
    Re: The Final Wipe
    I was full joking...
    (about making sure no harm came to the bracelet)
    Agreed.
    In all the classes I've taught and for all the cars I've buffed out personally, I make it a practice to dress appropriately and remove anything that could damage paint.
    Believe it or not, my normal clothes of choice to buff out a special interest vehicle would be mid-top Nike's with an air-cushion sole, shorts for obvious reasons and a large, soft cotton t-shirt that covers down far enough to cover the belt loops on my shorts. The reason being is that for a lot of cars at some point you have to lean on a side panel like the front fender in order to reach out and machine sand, buff or wax the middle of the hood.
    You don't want to instill scratches into the paint as you're doing this so a soft t-shirt will usually work well enough. There are other options like aprons too...
    Another option is to do all the steps to panels like the hood first so any marring the vertical panels accidental get are removed after all the horizontal panel work is finished.
  8. #28
    Newbie Member
    Join Date
    Aug 2012
    Posts
    13
    Post Thanks / Like
    Re: The Final Wipe
    Mike,
    I am so glad I found this forum. Being a guy who strives to do it correctly, you write and display it better than anyone anywhere... keep on keepin on brother!!! I also have many co-workers and friends who look to me as their local car care/finish expert, so I ensure to give you props when I practice your techniques and then disseminate them to the masses... consider me one of your disciples!
    I have a 2005 LS430 with RIDS, now I have the confidence to try and knock them out! Thanks for the boost in confidence.
    -John
  9. #29
    Mike Phillips
    Guest
    Re: The Final Wipe
    Quote Originally Posted by Viper6 View Post
    Mike,
    Thank you for the kind words... I have two passions in life,
    Polishing the paint on cool cars
    Showing other people how to polish paint (on any car)
    So my passion drives my writing, photography and the classes I teach...
    Sounds good... sounds like we do the same thing, help others to get what they want...
    "You can have everything in life that you want if you will just help enough other people get what they want"
    -Zig Ziglar
    -John
    RIDS can be tricky when working on factory paint because the paint is thin and hard. So be careful...
    Also, check out my article here, it pretty much sums up how I think when it comes to car detailing and I think it speaks for a lot of other detailers too...
    The Mindset of a Professional Detailer
  10. #30
    Regular Member Roikins's Avatar
    Join Date
    Oct 2014
    Location
    Hallandale Beach, between Miami and Fort Lauderdale
    Posts
    127
    Post Thanks / Like
    Re: The Final Wipe
    Awesome tip!!! Thank you Mike for sharing it, never thought about it!!
    Only thing I remembered, in Thursday garage makeover you teached me
    that folded microfiber cloth sharp sewed edges should be in your hand and the soft folded edges should be sliding over the cars paint. At the photos where it shows how the white microfiber is placed over the hood,the red sewed edge is sliding over the hood
    Sorry if it's looks like I want to be a smart a...s Just remembered what you teached me and I am happy for all the knowledge you have given me for all this time!!
    Thank you very very much!!!
Similar Threads
  1. Best final panel wipe towel.
    By Kody in forum Ask your detailing questions!
    Last Post: 12-30-2015, 01:15 PM
  2. Meg's Final Inspection instead of Panel Wipe?
    By nubaseal in forum Ask your detailing questions!
    Last Post: 08-22-2014, 01:47 PM
  3. Which MF towel for the "final wipe"?
    By MrOneEyedBoh in forum Auto Detailing 101
    Last Post: 06-01-2013, 11:22 PM
  4. Alcohols for final wipe down?
    By MarkD51 in forum Auto Detailing 101
    Last Post: 11-27-2012, 11:49 AM
  5. Mike, used your "Final Wipe" technique and...
    By Don M in forum Ask your detailing questions!
    Last Post: 06-15-2011, 01:07 AM
Members who have read this thread: 4
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
