Dislikes: 0
Super Member
Re: Headlight Restoration-new UV sealant idea
Originally Posted by keifer75
ok this may be a dumb question, but is the urethane only cut with the mineral spirits to make it more thin and spreadable? the reason I ask is because when I shopped for supplies I noticed the have the urethane in a spray can form. I was wondering if this would make it easier to give the headlights a more even coat of protection. Any input would be greatly appreciated!
The mineral spirits just helps to spread the urethane easier on the light, and helps to even it out as it is applied, I never end up with streaks, runs or haziness with the wipe on method. I have never tried any spray. I would think that the wipe on is quicker than the spray on, you won't have to mask much off with the wipe on or remove the lenses. I am also doing longevity tests with this wipe on method. If you were gonna spray the lenses, maybe an actual clear cote would work better, I think they are available in rattle cans. But I have never tried it before. Maybe find some junk lenses and test it out.
yea some junk ones would be a good test. thank you for the input
Super Member
Longevity test- On going- 3 months after restoration
Here are some photos of the first headlight restoration that I did just over 3 months ago. They were very hazy to begin with until I did the restoration and they were restored to like new condition. Today, they still look good, there is still high gloss, no haziness, no yellowing, no cracking, no visible breaking down of the sealant. So the restoration is still holding up after the 3 month longevity test in Kansas summer weather. I will do another observation in 3 months. This car has very minimum maintenance. Also, my work van will be hitting its 3 month test, and I am sure it will have the same results. This makes me wonder, if I only put wax on the lights, and did not use the UV sealant, would they still look the same as they do now? I doubt it. But this test is not over, so anything is possible.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Super Member
Thanks for the update hotrod! I used this technique on my work car as well however i only did one headlight with the urethane....the other one I used an actual hard coat that i received from a supplier. So I will be able to compare how the 2 hold up to each other!
Super Member
Was the hard coat method sprayed on or wiped on? Rattle can or air brushed(if sprayed)? Can you tell any difference in gloss yet? Is one of the lights glossier than the other? Keep us updated.
Maybe someone can try this method with one headlight treated with UV Sealant urethane, and the other treated with wax or their favorite paint sealant. And see how long it lasts without reapplying any sealant protection.
Super Member
The hard coat that I used is a liquid that you apply the same way as your technique. My sales rep told me they found it best to use a small microfiber wrapped around a foam applicator. so i did that with both the urethane and the headlight hard coat. The hard coat was really watery compared to the urethane. almost like rubbing alcohol. It also dried really fast unlike the urethane that was tacky still after 10 minutes. However I personally liked applying the urethane better since to me it went on smoother. I will post pictures in a few days when i have some time to upload them on the computer so you can compair the two!
And there will be NO maintenance on them as well. I work for the railroad so that is my work car that rarely get washed, never gets waxed and is out side all day in a rail yard with LOTS of dust and raildust flying around!
So this will be a good test of durability
Super Member
Since the weather is getting colder out, in my area atleast. I was told to turn the headlights on high beams to help dry the urethane quicker, or use a heat gun. But so far I have not needed to try this yet.
Regular Member
last post was a bout 3 mon ago... are these bad boys still holding up? i have been wondering about this for a while now.
Super Member
Yeah, they are still holding up, no visible signs of deterioration. I will try and post pics of these lights next week. Its my sisters car so I will snap a few pics and post them when I see her again. We have been having pretty nasty winter weather lately. So we will see if they hold up to the road salt and the other junk they spray on the slick roads. Note: these lights have not been cleaned in 3 months. So check back next week for the update.
Super Member
Similar Threads
By geoguy in forum Show N' Shine
Last Post: 08-11-2016, 12:55 PM
By RobertJ34 in forum Auto Detailing 101
Last Post: 05-30-2014, 09:02 AM
By ShineTimeDetail in forum Show N' Shine
Last Post: 06-08-2012, 09:47 AM
By websdown in forum Auto Detailing 101
Last Post: 02-03-2012, 02:19 PM
By truckbutt in forum Auto Detailing 101
Last Post: 08-21-2011, 08:57 PM
Members who have read this thread: 3
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
25 | 26 | 27 | 28 | 29 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 | 2 | 3 | 4 | 5 | 6 |
Bookmarks
