Thanks Thanks:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Super Member
    Join Date
    Jul 2016
    Posts
    3,328
    Post Thanks / Like
    Claying with wash/clay mitt and soap as lube?
    Ive read mikes show car shine book and know from experience, when you clay with soap as lube you don't end up with the same glossy paint you get when claying a dry car with real clay lube.
    Is this still true with say the new Blackfire clay wash mitt? What would be the best soap to use a lube when claying at the wash process?
  2. #2
    Super Member
    Join Date
    Oct 2017
    Location
    Boynton Beach, FL
    Posts
    219
    Post Thanks / Like
    Re: Claying with wash/clay mitt and soap as lube?
    I use ONR as a clay lube 1:128, the same ratio as when doing a RW.
    2021 Alfa Romeo Giulia Ti
    2017 Honda CTX700
    IG- alfaromeogiulia.palmbeach
  3. #3
    Super Member TTQ B4U's Avatar
    Join Date
    Jan 2016
    Location
    Central Ohio
    Posts
    5,438
    Post Thanks / Like
    Quote Originally Posted by fightnews View Post
    Don't believe it even matters. What you're seeing in terms of benefit from clay lube is simply that like a detail spray it has gloss/lube components to it. It's only temporary if you even see a difference. IMO I use soap with clay mitts as they provide far more solution to wash away the contaminants and are just as slick if not more so. The entire point is moot however as once you clay you really should polish.
    2019 Pearl White Accord 2.0T Touring (mine)
    2023
    Snowflake Pearl White CX-30 Turbo Premium Plus(wife)
    2010 Urban Platinum Metallic CRV EX-L & 2014 Mica Black Metallic Toyota Corolla S (kids)
  4. #4
    Super Member Desertnate's Avatar
    Join Date
    Aug 2013
    Location
    St Louis metro (Illinois)
    Posts
    5,805
    Post Thanks / Like
    Quote Originally Posted by TTQ B4U View Post
    Exactly my thoughts.
    I use traditional clay, but also use my wash soap as a lube. I find it is not only easier and faster, but also provides a more consistent lubrication base for my clay compared to a detailing spray. Either way, polishing would off set any results regardless of what is used as the clay lube.
    OP: Mike Phillips doesn't even always use a dedicated clay lube. In several of the season two Competition Ready episodes, he uses the SONAX claying pad with the Sonax Window Cleaner as his clay lube.
    The important part is finding something that will allow the pad or clay to do it's job with minimal marring to the paint.
    Drop by to see the latest at The Car Geek Blog
  5. Likes TTQ B4U liked this post
  6. #5
    Super Member
    Join Date
    Jul 2017
    Location
    RI
    Posts
    531
    Post Thanks / Like
    Quote Originally Posted by ChrisT View Post
    ONR rinseless dilution is 256:1, half that of the clay lube dilution. Are you actually RW with 128:1?
  7. #6
    Super Member Cruzscarwash's Avatar
    Join Date
    Oct 2015
    Location
    Desert of California
    Posts
    2,425
    Post Thanks / Like
    I generally use my wash soap as lube. I wash with MF towels so after the first pass to remove the majory of grime, I flip my towel to get any left overs, then clay the panel, ring out the towel and the remove anything else left and dry, move to the next panel and repeat until the whole car is done. depending on my end goal. I polish next or move to a spry sealant or wax etc.
  8. #7
    Super Member
    Join Date
    Oct 2017
    Location
    Boynton Beach, FL
    Posts
    219
    Post Thanks / Like
    Quote Originally Posted by JCDetails View Post
    Good catch. I think I was still asleep when I posted that. I use 2oz to a gallon for clay lube and 1oz to two gallons for rinseless.
    2017 Honda CTX700
  9. #8
    Super Member
    Join Date
    Jul 2017
    Location
    RI
    Posts
    531
    Post Thanks / Like
    Ah ok. That makes sense. Was worried because I’ve heard Yvan say that stronger dilutions are no bueno for rinseless.
    My understanding is:
    RW: 256:1 (one oz to two gallons)
    QD: 128:1 (one oz to one gallon)
    CL: 64:1 (two oz to one gallon)
    Joe Catanzaro
    JCDetails (RI Based Mobile Detailer)
    http://jcdetails.com
  10. #9
    Super Member
    Join Date
    Oct 2017
    Location
    Boynton Beach, FL
    Posts
    219
    Post Thanks / Like
    I have no idea about using ONR as a QD as I use a CarPro formulation. But this thread suggests 8oz to a gallon:
    Onr as a clay lube
    2017 Honda CTX700
  11. #10
    Super Member
    Join Date
    Jul 2017
    Location
    RI
    Posts
    531
    Post Thanks / Like
    Onr as a clay lube
    That is correct, I am mistaken. QD ratio is much higher.
Similar Threads
  1. Review - BF Clay mitt and Lube
    By Audios S6 in forum Product Reviews
    Last Post: 10-20-2017, 11:57 AM
  2. DP Rinseless Wash clay lube
    By Dan_335i in forum Ask your detailing questions!
    Last Post: 04-27-2014, 10:08 PM
  3. Clay lube or QD... What is best for claying?
    By Blake's Mobile Detailing in forum Ask your detailing questions!
    Last Post: 02-09-2010, 09:40 PM
  4. Replies: 11
    Last Post: 11-16-2009, 07:26 AM
  5. Clay Lube vs. a QD for Claying?
    By Waxmax in forum Auto Detailing 101
    Last Post: 08-20-2006, 06:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
