Re: Need recommendations for a detail spray (QD) that has UV protection
Here's my take....
Trying to add any "substantial amount" of UV protection using a spray detailer, waterless wash, rinseless wash etc., is really useless.
Instead, get the car/paint clean with one of the above and the use this,
Patented UV Protection - Optimum Car Wax - by Dr. Ghodoussi at Autogeek.com
Even if you spray it onto the panels that are most affected by the sun i.e. the hood, roof and trunk lid, you'll be doing more to provide some level of "substantial protection" then you'll ever hope to leave behind on the surface using one of the other options discussed.
My two cents...
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
Newbie Member
Just bought some last week mike!
detailer
Originally Posted by
Colehep
detailer
Good stuff... easy to use...
Products that are easy to use make using them “often” easier.
Super Member
I have been using Car Wax and Optimum No Rinse Wash and Wax as a rinseless and mixed as a QD which also has Car Wax. Every little bit counts.
Dave
SNP209
Another viable option worth looking into, Optimum No Rinse Wash & Wax. Mix it up 1:16 for a detail spray and 1:256 for a rinseless wash. Contains same patented UV protection found in Optimum Car Wax.
https://www.autogeek.net/no-rinse-wash-and-wax.html
"Optimum Polymer Technologies promises to deliver the convenience of a rinseless car wash with the cutting-edge protection of advanced UV inhibitors and high-grade carnauba wax."
What about Foam Cannon.. can you just foam cannon and wipe dry ? I got the spray but this looks like another option I may use if i get the paint a little extra dirty.
Bookmarks
