Junior Member
Wolfgang products question's Deep Gloss Paint Sealant
I want to try Wolfgang Deep Gloss Paint Sealant
I want to make sure I do the steps right
I washed the car clayed it and used there
Wolfgang Total Swirl Remover and
Finishing Glaze
I got it just the way I want it do I put Wolfgang Deep Gloss Paint Sealant
right on or is there a step I'm missing
and can I top over the Deep Gloss Paint Sealant with wolfgang füzion estate wax
or should I just wax the car and not Paint Sealant as I wax the car every 4 weeks
Junior Member
Re: Wolfgang products question's
Sounds about right to me. Those are the steps I took. Rinse, wash, clay, rinse, WG TSR, Finishing glaze, and then, finally, the WG DGPS. I took another step, after curing, and applied a nice thin coat of wax.
Super Member
Re: Wolfgang products question's Deep Gloss Paint Sealant
I would do an IPA wipe down to remove any oils from the polish. Nice article from Mike Philips on the dilution ratio.
https://www.autogeekonline.net/forum...n-results.html
Or if you want to stay in the Wolfgang family try Wolfgang Perfect Finish Paint Prep. Have tried this and it does just fine, nice scent also.
https://www.autogeek.net/wolfgang-pe...aint-prep.html
Good luck, sounds like you are in the right track.
Super Member
Originally Posted by
joe061990
Paint Sealant
Finishing Glaze
Paint Sealant right on
•IMO:
-Since you’ve “got it just the
way you want it”...
-You have now completed all of
the steps that’s needed to be per-
formed prior to the application of
this Sealant:
-It’s time to go ahead and put on
a coat of WDGPS.
joe061990
•IMO:
-After allowing the WDGPS ~12-24 hours
of cure-time...adding another coat of the
WDGPS would be more beneficial than
covering-up its Sealant characteristics
with a coat of Wax.
-By going that route:
An additional benefit will be that
you would not have to apply a coat
of Wax to the vehicle every 4 weeks.
"Be wary of the man who urges an action in which he himself incurs no risk."
~Joaquin de Setanti
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
Junior Member
So I don't need to use the Wolfgang Perfect Finish Paint Prep before applying Wolfgang Deep Gloss Paint Sealant
Super Member
joe061990
The directions on my bottles of WDGPS
does not include having to use/perform
this product/step prior to its application.
So, IMO:
No; that’d be “working backwards” (~M.P.)...
~Joaquin de Setanti
FUNX650
•IMO:
with a coat of Wax.
Exactly what I just did and results were outstanding.
Bookmarks
