Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Super Member Rsurfer's Avatar
    Join Date
    Jan 2007
    Posts
    14,094
    Post Thanks / Like
    Re: how to polish ?? Plastic ??
    Quote Originally Posted by JMak97008 View Post
    When you use something like M205 on tail lights or head lights, do you need to recoat them with a UV protectant?
    Yes, when you polish, you are removing the factory UV protectant. I've found Dlux to be an excellent UV protector.
  2. #12
    Super Member Eldorado2k's Avatar
    Join Date
    Nov 2015
    Location
    Los Angeles, California
    Posts
    13,765
    Post Thanks / Like
    There’s different levels of polishing though.. And you can improve the look of your headlights by giving them a quik polishing by hand without removing the factory UV coating. [especially effective if your lights are fairly new and just need very minor cleaning] In this case, you’d simply be adding a layer of protection on top of the layer of factory coating which is still there.
    If you were to do a more aggressive level of polishing/restoration then you’d be looking at re sealing on a level nearing that of the original coating that was originally on the headlights. And even then, completely removing the original coating can range from fairly easy to next to impossible even with aggressive sanding. [i.e. Corvette headlights]
  3. #13
    Super Member TTQ B4U's Avatar
    Join Date
    Jan 2016
    Location
    Central Ohio
    Posts
    5,438
    Post Thanks / Like
    Just as an FYI, I work in the optical industry and Zeiss is one manufacturer of the equipment that applies the UV Coatings to headlight lenses. Thicknesses vary but can range from 20-80 microns or roughly 1-3 mils.
    2019 Pearl White Accord 2.0T Touring (mine)
    2023
    Snowflake Pearl White CX-30 Turbo Premium Plus(wife)
    2010 Urban Platinum Metallic CRV EX-L & 2014 Mica Black Metallic Toyota Corolla S (kids)
  4. #14
    Regular Member
    Join Date
    Jan 2011
    Posts
    122
    Post Thanks / Like
    Another good one is Optimum Hyper polish, great on glossy or smooth matte plastic trim.....
  5. #15
    Super Member luckydawg's Avatar
    Join Date
    Jan 2016
    Posts
    1,117
    Post Thanks / Like
    Quote Originally Posted by TTQ B4U View Post
    Can you get a discount on some Zeiss glass???
  6. #16
    Super Member Calendyr's Avatar
    Join Date
    Jun 2013
    Location
    Montreal, Quebec
    Posts
    3,996
    Post Thanks / Like
    Polishing will not remove enough clearcoat to need a re-coating. On the other hand, adding a coating or sealant is always a great idea to help protect the piece you polished. So I would certainly recommend you do even if it is not needed as such.
  7. #17
    Super Member mwoywod's Avatar
    Join Date
    Apr 2016
    Posts
    881
    Post Thanks / Like
    Whether I'm polishing fiberglass golf cart bodies, polycarbonate/acrylic winshields, smooth porous plastic trim on cars, rubber trim, hard plastic A B & C pillars, taillights, headlights, vinyl windows, or wood veneers on the interior, the best product I've found is HD Polish+
    It's the best value and most versatile finishing polish on the market and even though it uses SMAT abrasives like M205 it finishes better than most DAT finishing polishes without being oily. There are SO many different forms of plastic on a vehicle and IME HD Polish+ is so amazing on these surfaces it could easily be marketed as a dedicated "Plastic Polish"
  8. Thanks luckydawg thanked for this post
    Likes AZpolisher15, mumps liked this post
  9. #18
    Super Member UncleDavy's Avatar
    Join Date
    Aug 2017
    Location
    Taunton, MA
    Posts
    1,586
    Post Thanks / Like
    I am glad that I found this thread. I am looking to polish the black exterior pillars on the Ford Explorer and I was considering a dedicated plastic polish. With the Memorial Day sale I am looking at purchasing a bunch of things. I just added the HD Polish+ to the shopping list. Thanks for the recommendation.
  10. #19
    Super Member DaveT435's Avatar
    Join Date
    Jun 2012
    Location
    Arlington Texas
    Posts
    3,982
    Post Thanks / Like
    I would recommend putting the most scratch resistant coating you know of on it when you are done, or never touch it with anything air dry only. I assume it's the same plastic as between the windows on my wife's F-150. That stuff scratches so easy, it's crazy!
    2015 F-150 Crew Cab Lariat
    2016 Chevrolet Camaro 2SS
  11. Likes UncleDavy liked this post
  12. #20
    Join Date
    Aug 2017
    Location
    Taunton, MA
    Posts
    1,586
    Post Thanks / Like
    I used the HD Polish + on the plastic pillars of the Ford Explorer and I was happy with the results. However I used a power drill with a wool pad and I now have swirls instead of scratches. I will go over it again with my Porter Cable but the scratches are gone. One pillar had an abrasion that I thought would never come out but it is now gone.
  13. Likes PaulMys liked this post
Similar Threads
  1. Removing wax/ polish from plastic.
    By kgj1119 in forum Auto Detailing 101
    Last Post: 11-16-2020, 04:46 PM
  2. What would you use to polish this plastic?
    By Eldorado2k in forum Auto Detailing 101
    Last Post: 01-14-2017, 05:08 PM
  3. Meguires: PlastX, Plastic Polish, Plastic Cleaner
    By AZpolisher15 in forum Auto Detailing 101
    Last Post: 12-15-2015, 10:41 PM
  4. Polish or wax excess on plastic?
    By superdave99gt in forum Auto Detailing 101
    Last Post: 11-10-2014, 03:29 PM
  5. Meguiars clear plastic cleaner, clear plastic polish
    By Bulla2000 in forum Auto Detailing 101
    Last Post: 05-06-2007, 07:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
