Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Newbie Member jonathanss's Avatar
    Join Date
    Dec 2015
    Location
    Indonesia
    Posts
    25
    Post Thanks / Like
    2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus
    Hello again from Indonesia,
    Yesterday I did a full body correction of a Nissan X-Trail or perhaps Rogue in American Market. From my experience, nissan's black color usually is sticky paint. Trial and Error on the X-Trail, it is confirmed that the paint is sticky and also soft. Therefore the best combination I used was Rotary + Menzerna PF2500 + Finishing pad.
    Before the correction step:
    2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus-20171209_072706-2-jpg
    Nasty isn't it? was a "loyal servant" of cheap robotic Carwash.
    And here are the after correction pics:
    2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus-20171210_084902-jpg
    2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus-20171210_084911-jpg
    2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus-20171210_084931-jpg
    2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus-20171210_084953-jpg
    Before - After of the same panel :
    2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus-img_20171210_084242-jpg
    Details:
    I did a rinseless wash first using ONR to save time. After that, I clayed the whole car. Next, Using the combo of menz pf2500 + finishing pad, I put 700RPM first to spread the polish first. I gradually step up the speed until 1800RPM (about 3 pass on 1800RPM) then I also gradually step down the RPM back to 700RPM --> 7-8 passes in total.
    Last but crucial, I topped the car using CarPro Essence Plus. Based on previous cars and on waterbeadings/sheetings behavior, CarPro Essence Plus can withstand Jakarta's harsh weather for about 5-8 months...not bad.
    Happy detailing, guys!
  2. Likes Bruno Soares, kalvintong liked this post
  3. #2
    Junior Member
    Join Date
    Jan 2018
    Posts
    39
    Post Thanks / Like
    Re: 2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus
    2 step
    step 1: Rotary + menzerna 2500 + finish pad
    step 2: Rotary + Carpro pluss + finish pad
    ??? it's right ?
  4. #3
    Join Date
    Dec 2015
    Location
    Indonesia
    Posts
    25
    Post Thanks / Like
    Quote Originally Posted by kalvintong View Post
    2 step
    ??? it's right ?
    For the first step, yes it is. However the second step i preferred to apply the carpro essence+ manually using a cheap foam pad from turtle wax.
  5. #4
    Junior Member
    Join Date
    Jan 2018
    Posts
    39
    Post Thanks / Like
    When I put my rotary over 1500 rpm. Pad so hot. Very hot on the surface. Foam pad become soft. It not cut swrils in the paint. I usually set set speed 2- 2.5 (900 -1.200 rpm) on my rotary. Move slowly. I will try your experience in next car. Toyota Camry black paint
  6. #5
    Super Member Sizzle Chest's Avatar
    Join Date
    Apr 2011
    Location
    Naples, FL
    Posts
    5,896
    Post Thanks / Like
    Very nice results!!
    Scott Harle
    Autodermatology
    #autodermatology
  7. Thanks jonathanss thanked for this post
  8. #6
    Join Date
    Dec 2015
    Location
    Indonesia
    Posts
    25
    Post Thanks / Like
    Of course the pad will be hot, so does the panel. But, did you put extra pressure on it? Whenever I use rotary, I just make sure the pad angle is perpendicular on car surface and not pressing it too much (pad only kiss car surface).
    What usually I did with Rotary buffer either compounding and polishing: 2 passes of 600-700 rpm (lowest rpm that available in your rotary buffer), 2 passes of 1000 or 1200 rpm, 2-3 passes of 1500 or 1800 rpm, 2 passes of 1000 rpm, and the last one: 2 passes of lowest RPM again.
  9. Thanks kalvintong thanked for this post
    Likes kalvintong liked this post
  10. #7
    Junior Member
    Join Date
    Jan 2018
    Posts
    39
    Post Thanks / Like
    Tks for share Mr. Jonathan 2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus-img_8910-jpg
    2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus-img_8913-jpg
    2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus-img_8914-jpg
    2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus-img_8912-jpg
    Last night. When I comeback my home. I saw this in the road. Like your car polish..2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus
  11. #8
    Join Date
    Dec 2015
    Location
    Indonesia
    Posts
    25
    Post Thanks / Like
    Another black nissan with nasty swirls.
    Do you live in Vietnam? Looking at the license plate numbering
  12. #9
    Junior Member
    Join Date
    Jan 2018
    Posts
    39
    Post Thanks / Like
    Yes, Im in Viet Nam, ho chi minh city.
  13. #10
    Junior Member
    Join Date
    Jan 2018
    Posts
    39
    Post Thanks / Like
    Hi Jonathan.
    I am very grateful for the method he has guided
    This is Toyota Camry
    Before
    2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus-org_dsc05176-jpg
    After (right)
    2015 Black Nissan X-Trail (Rogue) + CarPro Essence Plus-img_9039-jpg
    I did the camry last week. After changing your method of polishing. With flex rotary.
    I test spot 1: with menzerna 2500 (medium cut polish) + foam pad 2 (scale 1-5)
    Pad Scale:
    1: heavy cut
    2: medium cut
    3: (soft) polish
    4: (soft) finish
    5: apply sealant/ wax
    Detailing Kingdom (Malaysia)
    Speed 1: 2 pass
    Speed 3: 2 pass
    Speed 4: 3-4 pass
    Speed 1: 2 pass
    Total: 7-8 pass (do not add speed 1)
    90% swirls removed. But under swirls is RIDS
    I test spot 2: keep your method but change the compound ( menzerna 2500 -> Menzerna PG1000)
    70-75% defect removed.
    This is soft black paint. Next step. I use Chemica Guys BlackLight with apply wax pad - speed 3 to finish this process
Similar Threads
  1. Nissan Rogue midnight edition
    By PA DETAILER in forum Off-Topic
    Last Post: 04-17-2018, 07:55 AM
  2. Replies: 7
    Last Post: 07-12-2016, 08:33 PM
  3. Black G8- Testing Carpro Essence
    By Justin at Final Inspection in forum Show N' Shine
    Last Post: 12-21-2015, 07:41 AM
  4. 2008 black nissan rogue
    By Denami in forum Show N' Shine
    Last Post: 06-18-2015, 06:36 PM
  5. 2012 Nissan Rogue
    By outlander in forum Auto Detailing 101
    Last Post: 12-14-2011, 11:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
