Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Super Member Calendyr's Avatar
    Join Date
    Jun 2013
    Location
    Montreal, Quebec
    Posts
    3,996
    Post Thanks / Like
    Re: Is it possible to remove touch up paint?
    Lacquer Thinner worked like a charm to remove the clear and base. Thanks a lot for the tips.
  2. Thanks Diner thanked for this post
    Likes The Guz, SWETM liked this post
  3. #12
    Join Date
    Jun 2013
    Location
    Montreal, Quebec
    Posts
    3,996
    Post Thanks / Like
    Quote Originally Posted by 2black1s View Post
    Even though the manufacturer recommends acetone for thinning the paint I would use lacquer thinner if you have it available. Either acetone or lacquer thinner will thin out just about any kind of paint but lacquer thinner is a bit slower drying and that can give you more working time before the touch-up paint starts to flash. In most cases the additional working time is a plus.
    Lacquer thinner is also available in different drying times from faster to slower. Acetone is not. For touch-ups with lacquer type paints I have always found the slowest lacquer thinner (or even a lacquer retarder) to be the best reduction agent.
    On another note, I like using 2-part enamels or urethanes for touch-ups. They are not as quick and simple as lacquers but in most cases will result in a higher quality repair. The only exception is that I would use lacquer for touching up a lacquer paint job... But there are not many of those around in today's world.
    How do you match the colors?
  4. #13
    Super Member 2black1s's Avatar
    Join Date
    Jan 2015
    Location
    Simi Valley, CA
    Posts
    1,783
    Post Thanks / Like
    Quote Originally Posted by Calendyr View Post
    By paint code... Have it mixed at automotive paint store or body shop.
  5. #14
    Super Member MarkD51's Avatar
    Join Date
    Oct 2012
    Location
    Sheboygan Wisconsin
    Posts
    3,130
    Post Thanks / Like
    Thanks for this info. I know Acetone is a quite nasty product
Similar Threads
  1. How to safely remove/undo touch up paint
    By Matsui in forum Auto Detailing 101
    Last Post: 06-16-2018, 02:36 AM
  2. remove scratch in touch screen panel
    By c3bolz in forum How to Articles
    Last Post: 05-25-2016, 12:27 AM
  3. How to remove touch up paint blob?
    By Elliott.lwy in forum Auto Detailing 101
    Last Post: 05-31-2013, 06:55 PM
  4. How to remove touch up paint
    By kimandbrad21 in forum Ask your detailing questions!
    Last Post: 10-04-2010, 11:04 PM
  5. how to remove old touch up paint?
    By str8venom99 in forum Auto Detailing 101
    Last Post: 05-19-2010, 09:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» March 2024
S M T W T F S
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
