Dislikes: 0
Re: McKees 37 Hi Def Paint Sealant
thanks for the advice. I do have spray wax. I've got BLACKFIRE Midnight Sun Carnauba Spray Wax & Prima Hydro Wax As You Dry Spray 16. I have tried using them in the past & didn't like working with either one. I don't think it's the products. it must be my technique, but I'll try it again. thanks,
hmardown
Originally Posted by hmardown
pilotpip
let me throw this out there. and by the way, I'm trying to avoid removing to much clear coat. my truck is black & I can't keep chasing down every swirl mark or light scratch(and you know there's many). how about claying then using my rupes white pad with ultra fine compound & then using McKee's Hi-Def sealant ? I don't need to remove every swirl, but I'll probably remove quite a few. and then using the hi-def sealant should mask a few. what's your opinion on this plan of attack ? the dodge ram paint is soft & not hard to remove swirl marks. I just think I'm doing to much correcting & worried about the clear coat getting on the thin side. I'd probably use the white pad for the sealant to. I read somewhere that the rupes white pad & ultra fine compound is pretty safe to use. thanks,
hmardown
Sounds good. I think you have less to worry about using a polish or AIO than you think in regards to clear coat. Take your time, and do a test spot to see if you get the results you like. Like I said, 360 is a great product with a good mix of durable protection and light correction. It was the first thing I used with my PC, and I keep going back to it because I like the end result and ease of use. My routine is to use 360 with an LC orange or white thin pro pad (dependent on how the panel looks) in the spring. Regular 2 bucket washes, and McKee's fast wax as a drying aid through the summer. If the weather is nice, or I feel like making it look really good I'll throw a coat of DP Max wax on it, but Fast wax is almost as good. Today I got it ready for winter with a quick wash, clay, and a coat of Hi-Def. It lives outside and will get an occasional rinseless if not too dirty or 2 bucket if the weather cooperates.
My wife's explorer is black metallic. We bought it used and the paint was pretty badly swirled. I tried using blackfire's total polish and seal, then 360 and didn't get it where I wanted it. It will need to be 2 or three stepped to get it looking good. Once that's done, I'll put it on the the same rotation as the truck. Finding the time with two young kids is my biggest challenge which is why I like AIOs so much. I can do both vehicles in a weekend with AIO.
One last thing, in regards to the post above this one. So far you've mentioned about 4 or 5 different brands. All are good, but stick to just one as you start. Most product lines are designed to work together. Some items from different brands, do not. It's not fun to put the time and effort in and not be happy with the results as I found out last January.https://www.autogeekonline.net/forum...-together.html
Super Member
Dear Forum Members,
In my original post I indicated "...However, I am very interested in it's durability as that is a very important characteristic of a sealant IMHO. As such, I will be applying it to a friend's car within a week or two. This is a car that gets washed once a year (no kidding) and never garaged making it the PERFECT candidate for a durability test. The last time the test subject was washed was Christmas week 2016 at my house. Since I work with this friend I will get to monitor the durability over time as I see the car almost every day."
So I got around to this friend's car yesterday after shoveling some snow (hate snow!). This is a 2007 Volvo and it is, literally washed once a year. My friend took it to the swirl tunnel to save me some effort. I clayed the car and then proceeded with a compounding (GG6, Meguire's UC and orange LC ThinPro's). The car corrected and finished very nicely - all things considered - and felt very smooth; ready for Hi Def. I applied it in approx. 40 degree weather and let it sit for approx. 1 hour as sunlight wouldn't prevent any longer curing time. As mentioned in the original post, it wipes off so effortlessly you feel guilty. The resulting slickness is very impressive as is the shine. To end the day, my friend uttered "until next year". I asked him what he meant and he said "well now I don't have to wash it for another year.". I laughed and cried at the same time! He is thrilled that his car looks so much better - all free of charge.
So now it's time to sit back and observe. I see the car several times per week at work, so it won't be hard to do. I'll report back over time on this real-world torture test.
ScottH
Post Thanks / Like - 1 Thanks, 0 Likes, 0 Dislikes
Diner thanked for this post
Super Member
Dear Forum Members,
I wanted to update on the performance of McKees 37 Hi Def Sealant. I applied it to my wife's car in preparation for winter. That was a few weeks ago, and low and behold my attempt to keep my wife and her A4 off the salted streets in NJ yesterday failed. She came home with it covered in salt. Why couldn't she walk to the store? It was only a mile away? LOL. I even offered to go for her.
So today despite the 12 degrees temps, I powered washed it with warm water and no soap. There was no way I was leaving salt on it for any appreciable time. Result: I was AMAZED at how easily the dried salt came off the paint. Absolutely amazed! Without any foam or soap, the salt just flew off the paint and the water beaded up like crazy. I then pulled the car into our garage to prevent freezing (garages now heated with 240v Cadet 4000). The heater is able to bring the garage up 30 degrees more than the outside temps. So in this case the garage was a little over 40.
I then did a McKees rinseless wash now that the vast majority of the salt was off. The car was a breeze to clean and felt surprisingly slick considering. Topped it off with Pinnacle Crystal Mist and headed inside.
Temps are expected to remain between 5-15 this coming week with moderation 7-8 days from now. I would normally use that warming cycle to apply an LSP again for good measure but to be honest, it won't be necessary. I am sure another wash is all it will need.
Very impressed thus far with Hi Def Sealant and it could conceivably be one of the few products whose durability claims match real world.
Happy New Year AG friends,
ScottH
ScottH
Post Thanks / Like - 2 Thanks, 1 Likes, 0 Dislikes
Super Member
Originally Posted by ScottH
Dear Forum Members,
ScottH
ScottH
That's great to hear man, keep us updated
Sent from my Pixel using Tapatalk
Post Thanks / Like - 1 Thanks, 1 Likes, 0 Dislikes
Super Member
I use HI Def paint sealant when I know the person will not be maintaining their car properly. That way next time I need to do their car, I'm not too worried about the condition of the paint. Quick finishing polish and then reapply the sealant, it's really great stuff.
2016 Mazda 3 Sports GT
2015 Lexus IS250 F Sport
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
Hey Scott...have you considered using a McKee's Spray, or is it just that you have the Pinnacle Crystal Mist on hand, or is it superior in your view?
Super Member
Can anyone give a comparison between this and WG DGPS? Sounds like this is a little easier to remove and should be just as durable, but mostly I wonder about how it looks. DGPS has the typical sealant reflective shine. Does this have more of a carnauba glow?
Super Member
2018 Ford F150 - Ruby Red Metallic
2019 Honda Odyssey - Obsidian Blue
Post Thanks / Like - 0 Thanks, 3 Likes, 0 Dislikes
Super Member
Hi. Great question. Yes this was a case of having Pinnacle Crystal Mist on hand and wanting to use it up. Had it for about a year and like to rotate products so they don't get too old. Crystal Mist is in my opinion one of the finest spray detailers available, so I considered it a great topper after the rinseless wash described above to the extend Hi Def. I also have McKees 37 Fast Wax and PoliCoat wax which I will use as soon as the Crystal Mist is used up.
Happy 2018 to you,
ScottH
Similar Threads
By fightnews in forum Auto Detailing 101
Last Post: 09-06-2017, 11:30 AM
By dewoof01 in forum Product Reviews
Last Post: 04-28-2017, 05:50 AM
By Justin at Final Inspection in forum Show N' Shine
Last Post: 04-03-2017, 07:31 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
