Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
  1. #1
    Super Member Bill1234's Avatar
    Join Date
    Apr 2012
    Location
    New York, NY
    Posts
    2,647
    Post Thanks / Like
    Claying every time you wax?
    I was on another forum and really was trying to be reasonable but someone else asked if it was necessary to clay every time you are going to apply an LSP I totally understand the point of the baggie tes however, if you are going to apply a new lsp definitely why not clay? I was also argued it would damage your clear coat doing it that often. I feel like if you use enough lubrication, that should not matter too. Basically feeling that if you would need to apply a new coat, it should not be done before claying
    Thoughts?
    Bill 1234
    2004 audi a6 quattro (traded).
    2015 Ford Escape 2.0l ecoboost 4WD
  2. #2
    Super Member
    Join Date
    Nov 2016
    Location
    KY
    Posts
    1,065
    Post Thanks / Like
    Re: Claying every time you wax?
    My opinion, without any scientific evidence, is that clay is an abrasive, regardless of how much lube you use. For me, if I clay, I polish. I think marring is inevitable if you use clay. I think a synthetic clay may mar less.
    Kirk Harrod's Mobile Detailing, Frankfort, KY
    Official Detailer of Camarofest 8 & 9
    No one has detailed more Camaros.
  3. Likes Joel1979 liked this post
  4. #3
    Super Member Eldorado2k's Avatar
    Join Date
    Nov 2015
    Location
    Los Angeles, California
    Posts
    13,662
    Post Thanks / Like
    I don't always clay before applying sealant. I feel that if the paint passes the baggie test it's fine enough to seal after a thorough bucket wash.
    However every once in a great while [like after 1yr. or more] I'll clay even though it really doesn't need it. That's what I just did to the Kia. However I messed up and clayed it last Sunday evening and it got late and condensation kicked in... Combine that with a busy week and I wasn't able to lay down lsp until today. I didn't really like that, but things aren't always perfect.
    I used the Pinnacle Ultra Poly Clay. I could see it pick up the occasional blackhead on the paint, but overall the paint was clean enough to not show much of anything as far as grit on the claybar.
    If the vehicle was any other color besides white, I would've went straight to lsp.
    Nothing wrong with claying as long as you use plenty of lube and aren't 1 of those people who claim they marr their paint every time they clay. I personally never marr my paint.
  5. Likes Texchappy liked this post
  6. #4
    Super Member
    Join Date
    Nov 2016
    Location
    KY
    Posts
    1,065
    Post Thanks / Like
    My 2016 Camaro paint mars when you blow on it!
  7. Likes DogRescuer, Gray Bishop liked this post
  8. #5
    Super Member Kamakaz1961's Avatar
    Join Date
    Aug 2013
    Location
    Tustin, CA
    Posts
    4,389
    Post Thanks / Like
    I will not clay if I know my ride is clean and it's been only a week or 2 for the 2nd or 3rd coat.
    If you are adding a new type of LSP, I will clay (my case Nanoskin Blue) and then use a dedicated wax remover or an ultra fine polish and polish the car. My polishing will be very minimal, just enough to remove the LSP. If there are areas that do need polishing I will just do that. If I feel my ride doesn't need a light polishing then the dedicated wax remover will suffice.
    So I am in your camp if you are going to use a new and completely different LSP from the current one you have then I do the aforementioned above. Even if this is OVERKILL I could care less....I ENJOY and HAVE FUN doing this procedure. It's my stress relief!
    CJ
    2013 Mustang GT w/Track Pack 6-Speed Manual
    Save the Manual!
  9. Likes Paul A. liked this post
  10. #6
    Super Member TMQ's Avatar
    Join Date
    Mar 2015
    Location
    Germantown, Md
    Posts
    2,243
    Post Thanks / Like
    "Claying every time you wax?"
    No...
    Claying once a year is plenty.
    If you make a scratching sound when rubbing the paint or fail the baggie test, then yes. It would take a year or more to get that bad. So once a year is plenty.
    Tom
    Mr Tommy's
    Wash, Buff, Wax
    Website: mrtommyshine.com
  11. Likes Gray Bishop liked this post
  12. #7
    Super Member ScottH's Avatar
    Join Date
    Nov 2015
    Location
    Northern NJ
    Posts
    895
    Post Thanks / Like
    Also consider how often you wax. If you wax once a month it is very unlikely your car will need to be clayed each time.
    ScottH
  13. #8
    Join Date
    Nov 2015
    Location
    Posts
    13,662
    Post Thanks / Like
    Quote Originally Posted by KirkH View Post
    What kinds of different clay have you tried on it?
  14. #9
    Super Member
    Join Date
    Nov 2016
    Location
    KY
    Posts
    1,065
    Post Thanks / Like
    Quote Originally Posted by Eldorado2k View Post
    I use the very best. English made Bilt Hamber soft.
  15. Likes SWETM liked this post
  16. #10
    Join Date
    Nov 2015
    Location
    Posts
    13,662
    Post Thanks / Like
    If it's the best, then why does it marr your paint?
    Have you tried this? It's supposed to be ultra fine grade.
Similar Threads
  1. Should you polish after claying every time?
    By flakpyro in forum Auto Detailing 101
    Last Post: 07-06-2018, 08:20 AM
  2. How to save time claying your car - Remove contamination during the wash process!
    By Mike Phillips in forum Ask your detailing questions!
    Last Post: 04-18-2016, 08:13 PM
  3. first time claying, first time waxing
    By LazyGhost in forum Auto Detailing 101
    Last Post: 02-01-2013, 11:38 PM
  4. Claying to Polish time
    By zephed666 in forum Ask your detailing questions!
    Last Post: 06-19-2012, 06:52 PM
  5. First time claying
    By BradMO in forum Auto Detailing 101
    Last Post: 11-10-2010, 08:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» March 2024
S M T W T F S
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
