Re: Loss of clarity with coating?
Originally Posted by BudgetPlan1
That just sounds like too many cooks in the kitchen but interested to see how it turns out.
When I first started messing about with coatings i wss topping them with all sorts of waxes and QD's...Wolfgang Fuzion, Dodo Purple Haze, Pinnacle Souveran, WG Detail Spritz, WG Deep Gloss Sealant and Spritz, Kenotek Showroom Shine and a few more. Eventually I just ended up with s surface that acted like a wax...not very self cleaning and attracted dust.
After I gave up on that I went into SiO2 overload; wash coated car with Gyeon Bathe+, follow that with Gyeon WetCoat, finish with Gyeon Cure or similar. Eventually I did start to lose clarity and have since become kinda a minimalist.
Car is now coated, added a carnuaba/glass coating hybrid wax from the same 'collection' every 3 months or so, topped occasionally with a booster from the same collection.
Good to know only thing is I noticed the loss of clarity as soon as I coated it with nothing on top. My eyes can see it and now I see it in that picture so I'm just going to buff the coating off
What u use pa stuff?
Super Member
I wholeheartedly agree that simple is best. I don't top my coatings either. However, what do you use as a drying aid or post-wash spot remover...or do you at all?
I have no shade/cover for washing and even on the smallest car washed as quickly as possible, I'll get a few spots. Drying aids or an as-needed wipe down is a necessity for me. Right now, I'm pretty happy with Kenotek on my McKee's 37 coating and I liked McKee's 37 High Gloss Detailer (supposedly a complimentary product to the coating) as well. Ultimately, I'm looking for a product that leaves as little behind as possible. Right now I'm using QD sprays as I feel they leave far less behind than spray waxes. What little they do leave probably doesn't last more than a few days.
Originally Posted by fightnews
Just wanted to bump the picture, I don't know if its just the coating brand but it definitely looks worse. Even the guy at work could clearly see it
I might even bang out Friday to buff it off
Super Member
I was messing about with some coatings on a hood to try some different methods/tools once last summer; although I *thought* I did a complete prep wipedown (Gyeon Prep) when I pulled the car out into the sun I could see some haziness which it turned out from being poor post polishing prep. While in garage, surface looked free and clear the Prep had not completely removed all residue from surface, which I then coated over with somewhat hazy results in sun. Just a thought...
I PM'd ya on what stuff I use currently...
I use the Booster product from the coating family collection as a drying aid...
Here's another 1 with the exact lighting
Edit: Just wanted to add that it has nothing to do with the lsp on the uncoated car. I have 100 other pics with all different combinations of lsp and they are all comparable. I only chose that pic because the lighting and angle were the closest to the coated pic
Dang that coating was 80 bucks too plus 30 for the polish
Super Member
Definitely a loss of clarity..plain to see. Was the coating the Blackfire Surface Coating?
No the pinnacle black label diamond paint coating V2. I'm taking friday off from work so I can spend the weekend buffing it back to normal.
Do u guys think menzerna 3500 will get the coating off? It's been on a little under 2 weeks
Super Member
Nope, I disagree. The lighting is not the exact same and the tell tale signs are 1st of all visable on your wheel... It's blinding bright coming off the wheel which indicates the brightness [or whatever the correct term] is set too high, causing it to look sort of like this, except even brighter in your pic.
Under normal camera conditions it should look more like this, even in direct sun.
I oughta know, because when I took that pic a while back, I was purposely trying to highlight the gloss on the tires, but it just didn't look natural so I toned down my brightness, which is what you should've done.
It's also visible on small areas such as the exterior drivers side rear view mirror [look at the triangle shaped part closest to the door] notice the slight difference in shade between the 2 pics, and again it's slightly visable on the roof racks black trim... And especially noticeable on the chrome door handle. 1 pic it's so bright it's blurry, and on the right side pic it's clear and natural.
You're doing a good job of convincing yourself though...
Yeah ok bro, to bad i noticed it without the pics hence why I made the thread. Its obvious you must be blind if you cant see it. Youre just trying to argue for arguement sake, i didnt need the pics to be able to see it i only posted them for the forum.
Of course it's not an exact match the pics are months apart.
Super Member
The plastic trim along the rocker panel looks slightly darker on the right vs. left side... Again due to lighting conditions not being exactly the same or IMO ideal.
Similar Threads
By Hammondc in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 08-31-2016, 04:55 PM
By BTLew81 in forum Off-Topic
Last Post: 05-20-2014, 07:15 AM
By wildjyoung in forum Off-Topic
Last Post: 03-14-2012, 12:06 PM
By CEE DOG in forum Off-Topic
Last Post: 06-14-2011, 12:01 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
