Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
  1. #11
    Super Member Rsurfer's Avatar
    Join Date
    Jan 2007
    Posts
    14,093
    Post Thanks / Like
    Re: Microfiber questions/advise needed
    Quote Originally Posted by GrantLagasse View Post
    So by separating finishing and polishing you mean I should use use something different for the two AND wash them separately?You can use the same detergent, but wash separately to prevent cross contamination. How about wax towels and sealant towels? Can I wash them together?Same as the above answer.
    What's your process on bucket washing? Soak, wring, repeat, and rinse in clean water?Something similar?Yes, unless you are using a heavy detergent for extra soiled towels..then I would rinse until the water is clear.
  2. #12
    Join Date
    Jan 2007
    Posts
    14,093
    Post Thanks / Like
    Quote Originally Posted by VISITOR View Post
    two piles. one for the good microfiber (paint) and the other for the tatty (wheels, interior, etc.) tasks...
    Wheels and interior in the same pile? Maybe wheels and door jam towels.
  3. #13
    Super Member
    Join Date
    Oct 2016
    Posts
    208
    Post Thanks / Like
    In my mind, I have always wondered about the towel separation idea. Not so much the greasy/dirty wheel/engine cleaning vs. the paint type, but the compound vs. the polish vs. wax type (i.e. the "good" (touches paint) vs. the "grungy" (exposed to grease/mud)). I have no issue regarding the separation of good vs. grungy;
    The reason used for separating the various "good" towels is product transfer. That is the part that I have an issue with. If the detergent/soap/cleaner is good enough to get whatever product is in the microfiber to start with, then that product has been dissolved and is in the wash water. No matter what product, it has been dissolved. That is basic detergent/soap/cleaner action. The part that I don't get is why then, it would magically be more likely to be deposited on a towel that was used for a different product (as in a compounding towel and a wax towel), and not onto another towel that used the same product, and how likely it is for it is for cross contamination vs. how likely it is to contaminate a towel that used the same product.
    What I am saying is, if the detergent/soap/cleaner is doing a good enough job of cleaning a microfiber towel that was used with first product (polish, compound, or wax), it is as likely to not contaminate other towels in the wash that used a second product, or at least to the extent that it wouldn't be any more prone to contaminate the towel with the second product any more than it would be prone to contaminate other towels using the first product. If the detergent/soap/cleaner isn't good enough to dissolve the first product, it will not only not clean the product out, all of the towels would be contaminated.
    Conclusion is, the essential factor in this is how good is the detergent/soap/cleaner that is being used, and is it getting all of the product out, or not. If it is, the possibility of cross contamination between "good" towels is overstated and probably nonexistent. So separation of "good" towels is unnecessary if the detergent/soap/cleaner is doing it job. If it isn't, then find another detergent/soap/cleaner.
  4. #14
    Super Member VISITOR's Avatar
    Join Date
    May 2007
    Posts
    9,721
    Post Thanks / Like
    Quote Originally Posted by Rsurfer View Post
    if the tatty towels are really dirty, you can always run them under water (or soak them in a bucket) and clean as much debris out as possible before washing them. if they get to that point where i feel they aren't safe to use again, they get tossed. i don't over complicate things and just get them wash/dried and ready to use again.
  5. #15
    Super Member
    Join Date
    Jul 2016
    Posts
    3,328
    Post Thanks / Like
    You should seperate towels BUT how about this. Wash the glass towels in the sink then throw them in with the other towels.
  6. #16
    Super Member DogRescuer's Avatar
    Join Date
    Apr 2013
    Location
    Hurt, Va
    Posts
    1,801
    Post Thanks / Like
    I agree separating towels into
    1 paint safe + glass towels
    2 not paint safe
    But why are you guys separating glass towels that seems overkill? Just not understanding.
    Steve
    -The Titanic Was Built By Professionals But The Ark By Amateurs-
    "Boanerges"
  7. #17
    Super Member Eldorado2k's Avatar
    Join Date
    Nov 2015
    Location
    Los Angeles, California
    Posts
    13,752
    Post Thanks / Like
    Quote Originally Posted by DogRescuer View Post
    2 not paint safe
    I put my glass towels in with my wash mittts.
  8. #18
    Join Date
    Apr 2013
    Location
    Hurt, Va
    Posts
    1,801
    Post Thanks / Like
    Gotcha. Because I ONR any nasty funk off glass first my glass towels never get nasty.
    Steve
    "Boanerges"
  9. #19
    Join Date
    Nov 2015
    Location
    Posts
    13,752
    Post Thanks / Like
    I do the same... Except my method is D114 and the squeegee.
  10. #20
    Join Date
    Apr 2013
    Location
    Hurt, Va
    Posts
    1,801
    Post Thanks / Like
    Yes I do the squeegee also but still learning how not to make a bigger problem on the front and rear interior glass.
    Steve
    "Boanerges"
Similar Threads
  1. New here... reading done... advise needed
    By Stockton2007 in forum Auto Detailing 101
    Last Post: 10-05-2017, 02:47 PM
  2. Replies: 18
    Last Post: 02-04-2015, 09:54 PM
  3. Advise needed
    By Lightscapes in forum Hot topics & Frequently Asked Questions
    Last Post: 01-30-2013, 11:51 AM
  4. Rotary advise needed
    By drivemax in forum Auto Detailing 101
    Last Post: 10-13-2010, 06:58 AM
  5. Help / advise needed getting out swirls
    By SNKBYTE in forum Auto Detailing 101
    Last Post: 11-19-2008, 01:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
