Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Super Member Cruzscarwash's Avatar
    Join Date
    Oct 2015
    Location
    Desert of California
    Posts
    2,425
    Post Thanks / Like
    Mckees 37 new formula paint coating
    I finally tried out the NEW coating formulation and all I have to say is ..what the hell did McKees do!!!
    It's AWESOME!!!!
    so as some of you know I pretty much only use mckees paint coating as my coating of choice due to the fact I work outside in the sun in high heats.
    This new formula was not only easy to apply (not a big fan of the new applicator pad, so I used my old one) it was easy to see high or missed spots. It also covered up orange peel in my paint which you can see in the pictures I attached. My car needs to be repainted so not worried about the orange peel.
    Most of you know I suffer from very hard water and waterspots are an everyday thing for me and I have yet to find any product that can prevent spots from forming if not removed after the first 24 hrs. No coating from cquartz to Dr Beasley or gyeon has helped in anyway.
    I normally have to Chemically remove the spots and then Reapply what ever LSP it is I'm using and basically repeat each week or whenever I finally get to wash my own car.
    The working time for this new formula was better and I tried to stretch it to do large panels but in my heat it still was not a good idea so I had to stick to very small sections of about 6x6 to 10x10 MAX.
    As some have said the slickness of the original is gone and it does not have that same glassy feel but also does not have the rubber feel of other coatings. Overall I will continue to use this and am very happy with my initial impressions of the new coating, now to see how long it last and how well it protects.
    Sent from my Pixel using Tapatalk
  2. #2
    Super Member
    Join Date
    Sep 2015
    Posts
    6,281
    Post Thanks / Like
    Re: Mckees 37 new formula paint coating
    Can't beat it for the price.Even if it gets you 4 strong months of good durability that you can see than its a no brainer.
  3. #3
    Join Date
    Oct 2015
    Location
    Posts
    2,425
    Post Thanks / Like
    Quote Originally Posted by GSKR View Post
    Idk if I'd go as far as that. I get that much protection from sealants with much less effort then mckees coating. I've gotten 9 months out of the original formula so hopefully this does better
  4. #4
    Join Date
    Oct 2015
    Location
    Posts
    2,425
    Post Thanks / Like
    Well lessons learned. I didn't flush the Pump after I did this review and when I went to go use it again it was clogged and crusted over.
    I also forgot to wash my applicator so now that is ruined as there is a thing hard layer stuck to it.
  5. #5
    Super Member The Guz's Avatar
    Join Date
    Jun 2013
    Location
    LA, CA
    Posts
    8,719
    Post Thanks / Like
    Quote Originally Posted by Cruzscarwash View Post
    Good to know. Thanks.
    Contact Nick after the hurricane and maybe he can hook you up with a new applicator.
  6. #6
    Newbie Member
    Join Date
    Mar 2016
    Posts
    11
    Post Thanks / Like
    It's AWESOME!!!!
    Looks like you forgot to clean your wheels.
  7. #7
    Join Date
    Oct 2015
    Location
    Posts
    2,425
    Post Thanks / Like
    The Salt Air ate them away so I kind of disregard them now.
  8. #8
    Junior Member
    Join Date
    Oct 2016
    Posts
    99
    Post Thanks / Like
    Maybe someone can help me in this thread. I am currently applying coatings from Feynlab and was previously using CQuartz. How is it that these coatings are so much more "difficult" to use than the mckee's or wolfgang which appear to be more of a wipe op wipe off deal?
    Hopefully Rich can shed some light on this because it has had me wondering for months now. Is it that the easy to apply coatings are "weaker" than the easy to use ones? "Less chemical resistance, lower duration, etc".
  9. #9
    Super Member
    Join Date
    Apr 2013
    Posts
    1,266
    Post Thanks / Like
    The first version didn't make it through winter for some and apparently didn't have any silica because the new formula claims it does.
    The first version you could wipe off high spots very long after application. Guessing they didn't cure the same way ceramic or glass coatings did because they were not the same make up. Really all these LSPs are technically "coatings" cause you are coating paint with them. It's just jargon with no real definition of what has to be an ingredient
    Find one you like try it and report back results.
  10. #10
    Super Member
    Join Date
    Feb 2012
    Location
    Pingree Grove IL
    Posts
    281
    Post Thanks / Like
    I ordered the McKee's coating set last year around this time...
    How do I know if i have the newer formula for the paint coating ?
    Was going to apply it to my Dad's Durango next week
    Gav Details on YouTube:
    www.youtube.com/c/GavDetails
Similar Threads
  1. Mckees paint coating vs pinnacle black label paint coating?
    By fightnews in forum Auto Detailing 101
    Last Post: 09-16-2017, 07:51 PM
  2. Mckees New Paint Coating
    By RandyD in forum Auto Detailing 101
    Last Post: 09-08-2017, 12:28 PM
  3. McKees 37 Hydro blue Sio2. Topping McKees paint coating
    By dewoof01 in forum Product Reviews
    Last Post: 04-28-2017, 05:50 AM
Members who have read this thread: 1
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
