Recently had my driver's front fender painted.
My body shop guy is great and doesn't buff out his work, instead he challanges me to make it better if I chose.
He always sprays extra Clear so I can play if I wish.
So the fender had some minor orange peel only visible to me.
Wet sanded 1500 grit followed by 2000 grit.
Since was small area used my Girot's 3" and ThinPro Orange pad to remove the sanding marks.
Looked OK after 5 section passes.
Couple days later noticed some dull areas from different angles.
Pulled out the Nano and yellow polishing pad and Yellow Polish to spot correct.
Looked OK.
Week later washed ONR and still see some dull areas.
Ok so far about 1 hour correction time and stiil not fixed.
Time to break out the Porter Cable and 5" Pads.
4 passes Orange LC Cutting pad and Optimum II Compound.
5 passes Blue LC Pad and Optimum Hyper Polish.
Total time 30 minutes and perfect correction.
Lesson learned, stick with proven methods and don't try to take short cuts (some call it experience).
Bookmarks
