Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Mike Phillips
    Guest
    How to use the SONAX CC36 Ceramic Paint Coating
    SONAX History
    In 1903, Franz Hoffmann, the great grandfather of Manfred Hoffmann extracted Neuburg siliceous earth in Neuburg, Germany. This very fine mineral was used as a polish in many household cleaning products including a silver polish called SONA.
    After the second world war another branch for manufacturing products was added to the company. The brand SONA was registered to protect the household line of products and the brand name SONAX was registered to protect car care products. The letter “x” was added to the end of SONA as a synonym for the word “wax” as the early SONAX products for their automotive line were primarily car waxes.
    You can red the entire history of the SONAX company here.
    Fast forward to the year 2016 when SONAX introduced their ceramic paint coating at the U.S. 2016 SEMA show in Las Vegas. I've had the good fortune to visit the SONAX headquarters in Neuburg, Germany and tour their manufacturing plant and even better, met with their chemists. They are the real deal. While many Americans may be new to the SONAX brand, one way I use to give people an idea of how big and how popular SONAX is in Europe goes like this,
    SONAX is the Meguiar's of Europe
    I think it's safe to say that here in the U.S. Meguiar's is a trusted and popular brand of car care products and that's because they have a LONG history of providing high quality products that do what they say they'll do and that's perform at a high level no matter what the category. The same thing applies to SONAX products. They formulate all their own products, manufacture them and bottle them. This hold true for their new ceramic paint coating, it is their own in-house chemistry and formulations.
    Recently I used the CC36 Ceramic Paint Coating on a modern muscle car, a 2012 Dodge Challenger SRT8 392 Hemi Yellow Jacket. You can read about this project and see the CC36 ceramic coating results here,
    Review: - LC HDO Foam Pads - Makita PO5000C - Supercharged Dodge Yellow Jacket
    When I detailed that car and by the word detail I mean I did a multiple-step show car detailing process, I was under a tight time constraint and unlike my normal practice, I did not take a lot of pictures. Currently I have another show car in the garage that is very different than the Yellow Jacket. They are both MOPARS and they both have Hemi Engines, only this current product is from 1956 and was built by the late famous custom car builder, Richard Zocchi. We actually had this car here for one of our 3-day detailing classes back in 2014. Here's the link to the write-up for that class.
    Richard Zocchi Kustom 1956 Dodge Lancer - Detailing Class at Autogeek
    Since that class I'm sad to say this car was in an accident and hit in the front end by another car. It's since been repaired and repainted and the good news is the quality of the rebuild and repaint are incredible. The shop, a buddy of mine usually does the wetsanding and the initial compounding step and then lets me take over the polishing and finishing steps. So the car arrived here with holograms from the compounding step which give me the perfect condition paint to showcase tools, pads and compounds and polishes and also the SONAX CC36 Ceramic Paint Coating.
    Below are the steps to follow to chemically strip car paint to remove residual polishing oils and other substances after compounding and polishing and then how to apply the 2-step coating.
  2. #2
    Mike Phillips
    Guest
    Re: How to use the SONAX CC36 Ceramic Paint Coating
    Continued....
    Hologram Scratches
    These are holograms instilled into the paint by a rotary buffer and a wool pad. Because this car is painted in light colors, it's not only harder to see the hologram scratches but it was challenging to capture them with a camera. The important point being that all colors of cars can have holograms scratches it's just lighter colors make them more difficult to see.
    Here you can see the pattern which looks like fat lines of scratches in the paint running in a back and forth pattern.
    It's usually easier to see holograms outside with bright overhead sunlight
  3. #3
    Mike Phillips
    Guest
    Step 1 - Do any paint correction and polishing before applying the coating
    The thing about a coating is it's going to seal the paint like a car wax or synthetic paitn sealant only it's going to
    Last a lot longer
    Protect longer
    Create a very glassy appearance
    Resist dirt better than a car wax or a synthetic sealant
    Wash faster as dirt will release easier
    Dry faster as water will try to leave the surface
    That said, a ceramic coating will not remove swirls, scratches, water spots or oxidation. You must remove these types of paint defects first. For our demo car, we'll need to remove the holograms, which are a specific type of scratch pattern instilled into the paint by the use of a rotary buffer, wool pad and usually a cutting compound. Holograms are common when cars are repainted as the body shop will sand the paint and then compound and polish the paint but do both of these step using only a rotary buffer. To ensure holograms are removed, the final machine polishing step is best performed by an orbital polisher.
    The word holograms means a specific scratch patern inflicted into paint using a rotary buffer
    The discussion about holograms comes up all the time in the car detailing world. The word holograms means,
    a specific scratch pattern inflicted into paint using a rotary buffer
    The pattern of swirls you see are actually scratches and the pattern you see in the paint mimic the direction a rotary buffer was moved over the surface.
    Sometimes people will refer to micro-marring caused by the abrasive technology and/or the pad used on an orbital polisher as holograms. But these scratches are not holograms but micro-marring. It is true that on darker colored paint you can see a pattern in the paint that mimics the way an orbital polisher was moved over the surface but even so, this pattern and these scratches are not the same as the scratches instilled by the single rotational direction of a pad spinning against the paint when using a rotary buffer.
    One reason it's important to distinguish between the two types of scratch patterns is so that everyone in our industry is on the same page when discussion paint defects. While a Ford Truck and a Chevy Truck are both trucks, they at the same time they are very different merely because they are built by very different companies.
    Hologram Scratches
    FLEX tools - SONAX products - Lake Country Pads
    There are a lot of tool, products and pads on the market, here's two of those options that I'll use for this project. If you can find anyone else in the cyberworld that writes how-to articles for tools, pads and products, feel free to read those too.
    Pictured below are the FLEX 3401, FLEX XFE7 and the FLEX 3" Mini Polisher
    SONAX CutMax Compound with Lake Country Force Hybrid Foam Cutting Pads
    SONAX EX 04-06 Polish with Lake Country Force Hybrid Foam Polishing Pads
    SONAX Fine Cut Polish with Lake Country Force Hybrid Foam Finishing Pads
    The compounding step
    For this first step I tried to document how long it took to compound the paint on just the roof to remove the holograms. Most of the time when buffing out a car you start at the highest point and work downward. When I do show car work, I'll tend to knock out the roof all the way through the process, that is compound, polish and the seal before moving to the hood and trunk lid. Then I'll work through the entire process for the hood and trunk lid. The reason why is because often times show cars or SIVs (special interest vehicles), are cool and cool means classics, customs, muscles cars or streetrods and these types of vehicles are LARGE. In order to reach all the way out to the center of the roof I'll have to lean against the side panels. In order to reach all the way out to the middle of the hood or trunk lid I'll have to lean on the fenders.
    If I compound these panels first and then move to the veridical panels, later when I go back to polish the horizontal panels I have to lean on the vertical panels again. If I've already compounded the vertical panels and then lean on them again I RISK putting scratches back into them. I call this,
    Working backwards
    I never work backwards in the paint polishing process, only forwards and I teach this same practice in all my classes. So when doing show car work on cool cars I knock out the roof all the way through the process and the move down and knock out the hood and trunk lid all the way through the process. After these horizontal panels then I tackle the vertical panels. This is my technique, you can use it if it works for you or develop your own method to the madness. Been there done that a long time ago and I don't work backwards.
    I almost always go full-out when compounding paint with a FLEX 3401
    Why?
    Sometimes there's just something to be said for speed
    One pad per panel
    You will do your best work the fastest when using foam pads to use one pad per panel. The exception is when working on LARGE panels then sometimes it's better to have 2 pads per panel. As foam gets wet, (that's normal), it's cutting performece drops off. This means you will be less effective, (remove defects less effectively), and it will take you longer.
    It's 1:20 when I start compounding the roof.
    First section is compounded, moving on to the second section. The roof is so large I will divide it into 6 sections. 3 sections on the driver's side and 3 sections on the passenger side.
    Second section is compounded, moving on to the third section on the driver's side of the roof.
    Driver's side is compounded....
    Took me 10 minutes for 3 sections or about 3 minutes per sections. This speed is possible when using a gear-driven 8mm stroke orbital polisher and this is why I say,
    "With a FLEX 3401 you can POWER through a detail job"
    Time for the passenger side....
    Switching to a clean, dry pad....
    Fourth section is done, moving onto the fifth section....
    Fifth section is done, moving on to the sixth and last section for the roof.
    The roof is all compounded. I left the compound on so you could see it.
    It's now 1:45pm so the passenger side took about the same amount of time.
    Don't go too deep on me, remember I have to move my extension cord around plus my roll-around cart, plus grab my camera and take pictures so there's some fluff time in-between al of this stuff. I'm mostly trying to give newbies a sense for how long this type of work takes if you don't goof-off and stay busy.
    Here's the hood compounded, if you look carefully I wiped off compound residue to show how large the sections were that I worked....
    In this same shot as above, I drew lines to show you the approximate size of the sections I worked. With a gear-driven orbital polisher you can tackle larger sections than you cold with a free spinning orbital polisher AND still work effectively. When I use the word effectively I mean remove defects, not leave them behind....
  4. #4
    Mike Phillips
    Guest
    Continued....
    First polishing step
    I'm going to machine polish the paint twice. Why? Because this is the real deal. That is this is a real show car and I'm doing show car quality paint polishing.
    For this step I'm using the SONAX EX 04-06 and softer foam polishing pads. I will duplicate the same pattern I used for the compounding step and the same amount of section passes, that is 8 section passes. The primary difference between this step and the compounding step is after the first 3-4 section passes I'll reduce downward pressure and increase my arm speed. At this stage of the game all I'm dong is removing any marring or haze from the aggressive compounding step. Normally this dullness is INVISIBLE on light colors and unless you chemicals strip the paint but trust me... anytime you are aggressive with scratch-sensitive paints you need to do a follow-up step if you're doing show car quality work.
    I will also turn the speed down one setting. The holograms are gone so I don't need as much speed, downward pressure or slow arm speed. I'm "polishing" now, not compounding. There's a difference.
    It's about 1:52
    Starting on the driver's side front and then I'll repeat the same pattern I used for the compounding step.
    Done. The roof is now completely polished.
    It took about the same amount of time but some of my co-workers came into the garage and I helped them to load up our Competition Ready Van with tools, tables, products for this Sunday as we will have a booth at the West Palm Beach Cars & Coffee car show. If you're in the area, stop on by from 9:00am to 11:00am and say "hi". I'll be there demonstrating machine polishing techniques.
    Look at how clear and reflective the clearcoat is now....
  5. #5
    Mike Phillips
    Guest
    Continued...
    The second polishing step
    Next I'm going to re-polish the entire roof using a much softer pad and a much finer cutting polish from SONAX. The goal is to maximize gloss and clarity or as some like to say,
    squeeze as much shine out of the paint as possible
    The way I explain it is
    Taking your car's paint to its maximum potential
    It's about 2:26
    The FLEX XFE7 aka the Finisher
    For this step I'm going to switch over to a free spinning orbital polisher the FLEX XFE7. This tool offers a 15mm orbit stroke length and is a LOT less aggressive than its gear-driven cousin the FLEX 3401. For show car polishing I find I get best results when it comes to orbitals to finish out with free spinning tools.
    For this final polishing step I want fast OPMs but I don't need to go full out so I'm using the 5 speed setting....
    I'll repeat the same process used for the compounding and the first polishing step, that is work 6 sections starting on the front of the driver's side and working my way around the roof.
    I'll make 6-7 section passes with just a little downward pressure and a much brisker arm speed. At this stage of the game it's all about creating a perfect surface.
    Driver's side is done now I'm starting the passenger side...
    Finishing the passenger side....
    The second polishing step is done and the towels on the trunk lid indicate to me that I have also carefully wiped off all the polish residue.
    It's now 2:50 - the second polishing step took me approximately 20 minutes for actual machine work. Remember, don't go deep on me. As I move around the roof I also have to move my extension cord and I also move my roll-around car. And if you look in the background on the work bench you'll see a bottle of PowerAid almost empty.... it's important to stay hydrated.
    Next up.... time to chemically strip the paint....
  6. #6
    Mike Phillips
    Guest
    Continued.....
    How to chemically strip your car's paint to prep it for a ceramic paint coating
    Next up, I need to remove any polishing oils or any other residual substances off the paint so the coating can form a proper bond.
    This isn't as scientific as it might seem and remember, we just compounded and polished the paint twice so the surface is incredibly smooth and there's really not anywhere for the polishing oils to hide. Whatever oils or other substances did not get wiped-off when I wiped the polish off after the last polishing step is miniscule.
    Minuscule = means not very much
    The two step wipe method
    First wipe - The first wipe will or at least should remove the majority of any residues off the paint.
    Insurance wipe - The second wipe is a term I coined called the Insurance Wipe. This second wipe using a clean, dry microfiber towel is to remove any trace oils or other substances you may have missed with the first wipe or you may have left behind via cross-contamination with oils removed onto your towel.
    I like to start by dampening my microfiber towel with the product I'm using to chemically strip the paint. there's a number of these product on the market, the BLACKFIRE Crystal Coat Paint Prep works great and smells good too. A lot of times my favorite product is simply whatever is closets to my hand. That's a joke, all it means is if it's by me I like it otherwise I would have to walk out of the garage to get a product and that's more work.
    Then I spray an ample amount of product onto the paint itself, basically wiping the 6 same quadrants I buffed.
    I took a break in between the last polishing step and the chemical stripping step. My co-worker Elliot was taking some of the below pictures and I asked him to snag one of the clock....
    Moving around to the driver' side. (I started on the passenger side)
    Wipe carefully - it's important to NOT put scratches back into the paint at this stage of the game....
    I used 4 microfiber towels to chemically strip just the roof...
    How to apply the SONAX CC36 Ceramic Paint Coating
    There's two parts to the CC36 system, there's the Basecoat and the Glosscoat. When you buy the kit it also comes with included SONAX applicators that are marked with a 1 and a 2 and these correspond with the numbers 1 and 2 on the cans to make the system goof-proof.
    For this project I'm using the Lake Country Coating Applicators as this is the applicator that I have a LOT of and I'm going to be using these in the upcoming Autogeek Roadshow Classes where I need a lot of applicators for all the students to use. At this time SONAX doesn't offer or sell separate applicators so this is my work-around for the classes and before I teach this in a class I'm going to dial in my process on this old 2-door Dodge.
    Start by misting a little of the Basecoat directly onto the face of the applicator to moisten it and thus lubricate it so it will more easily glide over the paint.
    This is the tricky shot - capturing the spray mid-air
    (good job Elliot )
    Then spray some onto a section of paint. Here's a tip... hold the can higher than you see me holding it in the picture and you'll disperse a little bit of product over a larger section and this will help you to spread and coat the section better, faster and easier.
    WRONG WAY
    First I'm showing you the wrong way to move the LC Coating Applicators over the paint. Don't hold it like you see me holding it and try to move it from side to side as it will tend to tip over on itself. (when you do it you'll see what I mean)
    RIGHT WAY
    The right way to move the applicator is to move the length of the applicator from side to side. The length of the face of the foam pad keeps it from tipping over on itself.
    Move the applicator in a crosshatch pattern over an area about 20" squarish or so... don't try to tackle to large of an area as the coating will be trying to flash dry and this makes it hard to spread. This is true for all coatings by the way. You only apply to small areas and the wait about a minute or less and wipe off.
    After applying to a section, wait about a minutes and then wipe any high spots, or excess residue off. I like to wear microfiber gloves when I do this to help me grip my microfiber towels and to ensure I don't touch the paint with my skin potentially contaminating the process.
    What I'm doing in the below pictures is tilting my head and using the overhead light - looking for high spots (excess residue), on the surface so I can wipe it off. If you don't do this and miss a spot it will dry on the paint and be difficult to remove.
    Here I've moved to the other side of the roof and repeated the first step, applying the Basecoat.
    It was 3:45pm when I finished wiping off the first step of the coating, the step 1 Basecoat. Now I need to wait for 1 hour before applying the step 2 Glosscoat.
  7. #7
    Mike Phillips
    Guest
    Continued....
    I got busy in the office probably answering someone's question on the AutogeekOnline.net car detailing discussion forum so Elliot and I didn't get back out to the garage until 1 hour and 20 minutes had passes, which is fine.
    Step 2 - Apply the Glosscoat
    Now that over an hour has passed I basically repeat the basecoat step only now I'm applying the Glosscoat.
    Same technique as before, mist a little onto the face of the foam coating applicator....
    Mist a little onto the paint....
    Spread the coating over a section of the hood using a crosshatch pattern....
    Move to the other side and repeat the steps....
    Wait approximately 1 minute and the wipe off the excess and any high spots....
    That took me about 13 minutes....
    Done
    The roof is now done. It was compounded, polished twice, chemically stripped, coated with the CC36 Step 1 Basecoat and then coated with the CC36 Step 2 Glosscoat.
    That is a show car finish!
  8. #8
    Mike Phillips
    Guest
    Continued....
    On Autogeek.com
    For any of the other tools, pads and products, call any of our Customer Care staff and cite this thread and they can help you to get everything you need to do a professional job of applying a ceramic paint coating to you show car... or to your everday car....
    1-800-869-3011
  9. #9
    Super Member The Guz's Avatar
    Join Date
    Jun 2013
    Location
    LA, CA
    Posts
    8,719
    Post Thanks / Like
    Great how to on CC36.
  10. #10
    Newbie Member
    Join Date
    Sep 2017
    Posts
    2
    Post Thanks / Like
    Great looking results Mike!
    A concern comes up when I watch/read those jobs since I live in a dusty area, our climate -almost year round- has fine dust flying around. Should this worry me when performing such ceramic coatings or sealants/waxes? Are there any solutions for such climates?
    Regards,
    Ali
Similar Threads
  1. Sonax CC36 ceramic coating questions
    By jdeday in forum Auto Detailing 101
    Last Post: 11-14-2018, 05:56 PM
  2. Review - Sonax CC36 Ceramic Coating
    By The Guz in forum Product Reviews
    Last Post: 06-22-2018, 07:10 PM
  3. SONAX CC36 Ceramic Coating
    By bryanviper in forum Auto Detailing 101
    Last Post: 04-24-2017, 03:24 AM
  4. SONAX CC36 Ceramic Coating Now Available
    By The Guz in forum Auto Detailing 101
    Last Post: 03-13-2017, 09:30 AM
  5. SEMA 2016 Video: Sonax Profiline Ceramic Coating CC36
    By Mike Phillips in forum Company & Forum News Headlines
    Last Post: 01-14-2017, 04:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
