Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 9 of 9
  1. #1
    Regular Member
    Join Date
    Oct 2009
    Posts
    136
    Post Thanks / Like
    Flex PE8 vs cheap rotary
    have owed a Porter Cable 7424 for many years and just picked up the Flex 3401. Love the 3401. I mainly detail by own car and truck but every once in awhile will work on a friends vehicle as I enjoy seeing the improvement. I have 6.5", 5.5" and 4" pads for the PC and Flex. I've been looking at the small rotary polishers that can accept 1,2 and 3" pads in order to get into those small, hard to reach places (such as around mirrors and many areas on the front and rear bumpers). I was considering picking up a cheap Harbor Freight rotary and some small backing plates and pads but these machines tend to be large and the speed control does not seem to be that good. Still, they run around $40 and I'd only be using it for very limited polishing. So I'm also looking at the Flex PE8. I know this machine has been around for several years but there does not seem to have been much talk about it. Perhaps because it has limited uses.
    Is it worth the purchase for limited non-professional use or could I get by with a cheap rotary and good backing plates and pads?
  2. #2
    Super Member FUNX650's Avatar
    Join Date
    Dec 2010
    Location
    Ohio, USA
    Posts
    21,057
    Post Thanks / Like
    Re: Flex PE8 vs cheap rotary
    Quote Originally Posted by tcope View Post
    "I'm not rich enough
    to buy cheap stuff."
    ~Dad
    I'd go with the very versatile
    Flex PE8 Kit & some extra pads:
    "Be wary of the man who urges an action in which he himself incurs no risk."
    ~Joaquin de Setanti
  3. #3
    Regular Member
    Join Date
    Oct 2009
    Posts
    136
    Post Thanks / Like
    Quote Originally Posted by FUNX650 View Post
    I would be buying the backing plates, pads and extension but I could save about $20 and passing on the green and black pads as well as the towels and prep solution. But yes, basically the same thing.
    BTW - those pads.... VERY expensive. I'm guessing since there is not a large market. I'm almost temped to take some of my old 4" CCS pads and cut them down. I could get 1 3" or several 1-2" pads out of them. Don't get me wrong, I'm not trying to be overly cheap... it's just that the PE8 would not see much use so I don't want to dump a lot of money into it.
  4. #4
    Super Member Rsurfer's Avatar
    Join Date
    Jan 2007
    Posts
    14,094
    Post Thanks / Like
    I believe Car Pro makes a punch for the 1", 2" and 3" pads.
  5. #5
    Join Date
    Dec 2010
    Location
    Ohio, USA
    Posts
    21,057
    Post Thanks / Like
    a large market.
    out of them.
    Quote Originally Posted by Rsurfer View Post
    And CarPro USA just happens
    to have that Kit on sale too!
    ______________________________________
    ~Joaquin de Setanti
  6. #6
    Super Member
    Join Date
    Oct 2016
    Posts
    208
    Post Thanks / Like
    The Forensic Detailing channel on Youtube has a very detailed review of the PE8 (and the PE14-2).
    Lake Country is showing Hybrid Force pads in 1" and 3", in the CCS pads at 3", Hydrotech at 3" and 2", and HDO orbital pads at 3.5".
    You can get pads from Flex as well.
    I would get the backing plates for whatever sizes you wanted from Flex.
  7. #7
    Regular Member
    Join Date
    Oct 2009
    Posts
    136
    Post Thanks / Like
    Had kind off a crappy week so I broke down and bought the PE8. Well, that and I got a good discount so it ended up being cheaper than the PE8 with just a few pads. Looking forward to giving it a try.
    Stamping out my own pads? Yeah, not really an option at an additional $200 investment. Might just use some scissors and have a go at some older pads.
    Still kind of worried about the speed of the PE8. From what I see, should be used on setting 1 or 2 only.
  8. #8
    Super Member
    Join Date
    Oct 2016
    Posts
    208
    Post Thanks / Like
    That was a good buy. Sometimes things work out for the best.
    The speed of the PE-8 have been brought up before. The actual RPMs are a little bit high.at a minimum of 1300. And, like you, I do have concerns about burning paint. The thing to keep in mind is that the pads are smaller diameter than what would be used for regular sized DAs (those using either 5.5" or 6.5" pads). This means that the edge speed of the 3" pad used on a PE8 is roughly half of pad speed of the pads on the regular polishers. THe 2" pad is roughly a third, and the 1" pad is one fifth. While that is an academic exercise, and fairly obvious, it also directly affects the amount of heat that is generated by the pad. If paint is to be damaged by hear from a rotary polisher, it will be damaged by the edge of the pad (the highest moving part of the pad, and the one generating the most friction).
    All that comes down to the PE8, running at 1300 RPM using its biggest pad (3") will generate the same heat as a full sized rotary using a 5.5"-6.5" pad does at 650 rpm. With a 2" pad, it would be equivalent to a full sized rotary running at about 430 RPM. I am assuming a linear relationship between heat generation and speed of rotation; I cannot recall if it is linear or square law. Even in the worst case scenario, a PE8, used sensibly, should not create excessive heat.
    The Forensic Detailing review of the PE8 did bring up the point that the speed may have been chosen to ensure that the pads are effective, a 3" pad at say 800 RPM is not really going to cut very much. The other point that he brought up is that it may have been required to keep the airflow through the motor adequate to prevent overheating. In order to keep the unit size small, and still use a powerful 800W motor, they probably only went with a single reduction gear set, and is probably also the reason it doesn't have a variable speed trigger.
  9. #9
    Junior Member Red Lehr's Avatar
    Join Date
    Apr 2013
    Location
    New Athens,IL.
    Posts
    85
    Post Thanks / Like
Similar Threads
  1. Replies: 23
    Last Post: 01-23-2019, 04:45 PM
  2. The Flex PE14 Rotary Polisher - The rotary I grab first...
    By Mike Phillips in forum Ask your detailing questions!
    Last Post: 09-08-2015, 11:48 AM
  3. Replies: 9
    Last Post: 10-17-2013, 05:20 AM
  4. A great cheap Rotary accessory
    By glen e in forum Auto Detailing 101
    Last Post: 01-04-2012, 09:19 PM
  5. Thinking of buying a cheap rotary, questions..
    By WRAPT C5Z06 in forum Rotary Buffers
    Last Post: 03-04-2010, 10:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
