Thanks Thanks:  0
Dislikes Dislikes:  0
Results 1 to 9 of 9
  1. #1
    Senior Member ICEMAN's Avatar
    Join Date
    Aug 2009
    Location
    Oak Harbor, Ohio
    Posts
    779
    Post Thanks / Like
    My new Pressure Washer!! Pretty Stoked!!
    I work at a motorcycle shop part time (www.schietsmotorsports.com) and figured id pick up one of the best pressure washers money can buy since i get it at a hell of a cost.
    Yamaha PW3028 3000PSI
    https://www.yamahamotorsports.com/pr.../models/pw3028
    CAT pump, all brass fittings, exactly what ive always wanted. The end it comes with will rotate to whatever spray pattern you want. Its very nice and you can feel the quality in this unit. Cant wait to get my Torq foam cannon hooked onto the end of it and start spraying!!!
    IMG_2374 by ICEMAN TMCF, on Flickr
    IMG_2381 by ICEMAN TMCF, on Flickr
    17 Tucson | 13 Sonata | 01 Ford Mustang GT | 89 Kawasaki Ninja ZX-10
    @TheRealPolisher on FaceBook
  2. #2
    Senior Member WaxMaster1's Avatar
    Join Date
    Jul 2015
    Location
    Central Florida
    Posts
    688
    Post Thanks / Like
    Re: My new Pressure Washer!! Pretty Stoked!!
    Congrats on the purchase. I just watched a video and it looks really nice. The only problem I see is.....for a car, would be that it's gas and not electric. With the gas, you cannot simply put down the wand and wash individual wheels without turning it off and starting it up multiple times. Keep us posted.
  3. #3
    Senior Member Joe@NextLevelDetail's Avatar
    Join Date
    Jun 2015
    Posts
    1,881
    Post Thanks / Like
    Nice, 2.8 GPM :O
  4. #4
    Join Date
    Aug 2009
    Location
    Oak Harbor, Ohio
    Posts
    779
    Post Thanks / Like
    Quote Originally Posted by WaxMaster1 View Post
    Quote Originally Posted by Joe@NextLevelDetail View Post
    Nice, 2.8 GPM :O
    With how i have my routine set up, it shouldnt be an issue. Its a yamaha so even if i had to shut it off multiple times, i am not worried about the motor one bit. You're supposed to shut it off every time to remove something from the 1/4" quick connect (per the manual). so im supposed to shut it off every time i take off the foam cannon to put on the standard spray end.
    Detailing isnt the only thing i bought it for. i bought it for many other uses as well!
    One thing i really like is how it has the 800PSI nozzle on the rotating tip.
  5. #5
    Senior Member LEDetailing's Avatar
    Join Date
    Jan 2016
    Location
    Wisconsin
    Posts
    1,036
    Post Thanks / Like
    That rotating nozzle is cool. That spray wand looks like its built to serious use. 2.8 gallons per minute isn't far off my regular hose at full volume.
  6. #6
    Join Date
    Aug 2009
    Location
    Oak Harbor, Ohio
    Posts
    779
    Post Thanks / Like
    Quote Originally Posted by LEDetailing View Post
    Ya i cant wait to get at it!!!! My little 2000 Watt Yamaha Generator has been a beast for the past 3 years for what ive put it through. Honda or Yamaha for me, when it comes to this type of equipment!!
    Yamaha is giving an extra year warranty with these purchases so I have 4 years of a full warranty so thats nice. With 3.9% financing i didnt have to drop the entire amount right away,. i threw it on the card and put some down. This way i will only pay 10-20 bucks over the little bit of time til i pay it off. Figured why not. That way i drop around $700 all at once. lol.
  7. #7
    Join Date
    Aug 2009
    Location
    Oak Harbor, Ohio
    Posts
    779
    Post Thanks / Like
    well i finally used it and DAMN is it nice. The 800PSI nozzle is great when rinsing. Its nice to be able to quickly switch from a powerful spray to a lighter spray in a second. I need to adjust the foam ratio in the Torq Foam Cannon but it still worked great. Left it run the entire time except when i was done foaming i turned it off to remove the foam cannon to put the rotating nozzle on. It runs quiet when the pump isnt being used.
  8. #8
    Join Date
    Aug 2009
    Location
    Oak Harbor, Ohio
    Posts
    779
    Post Thanks / Like
    I let it run the entire time. I have no issues doing it. Like i mention in a previous post, its a Yamaha, the motor is gonna last. Its built to run. Ive used it a few dozen times at least already on house and car projects and its amazing to have. Using it with the Torq foam cannon is awesome.
    As i mention above as well, the 800psi spray nozzle is nice to have for delicate areas where you dont want a full spray nozzle. Yah you have to shut the machine off when you switch from the foam cannon back to the factory rotating spray nozzle, but thats it. Then you let it run til you're done washing.
    This is my Yamaha set!
    My Yamahas by ICEMAN TMCF, on Flickr
  9. #9
    Senior Member
    Join Date
    Jul 2016
    Posts
    1,782
    Post Thanks / Like
    I love my pressure washer
  10. Likes ICEMAN liked this post
Similar Threads
  1. Loss of pressure with my new pressure washer hose
    By CaveRacing in forum Auto Detailing Tools and Accessories
    Last Post: 06-19-2017, 06:48 PM
  2. Homemade undercarriage pvc washer for the non pressure washer.
    By ndsports in forum Auto and Garage Accessories
    Last Post: 02-04-2017, 03:09 PM
  3. Pressure Washer
    By RoacheC in forum Hot topics & Frequently Asked Questions
    Last Post: 09-03-2012, 08:54 AM
  4. Pressure Washer
    By Alan777 in forum Auto Detailing Tools and Accessories
    Last Post: 03-20-2012, 09:32 AM
  5. Replies: 6
    Last Post: 10-28-2011, 03:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» October 2017
1 2 3 4 5 6 7
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30 31 1234
