Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 8 of 8
  1. #1
    Junior Member master_photog's Avatar
    Join Date
    Nov 2011
    Posts
    55
    Post Thanks / Like
    newer boat - best for removing water spots?
    I'm close to finishing my bottle of Collinite 840 which is what I've mostly used on removing my water spots on the gel coat of our 2015 boat.
    It's done a pretty decent job, although it does take a good amount of elbow grease when doing it by hand.
    I'm curious if anyone has used any other products that do an equally good job or better with a little less work than the Collinite 840?
    Thanks!
  2. #2
    Super Member Rsurfer's Avatar
    Join Date
    Jan 2007
    Posts
    14,093
    Post Thanks / Like
    Re: newer boat - best for removing water spots?
    Quote Originally Posted by master_photog View Post
    Thanks!
    Get a DA polisher. You also have cars don't you? Doing it by hand is like having a land line only.
  3. #3
    Super Member VISITOR's Avatar
    Join Date
    May 2007
    Posts
    9,716
    Post Thanks / Like
    here's a line of products specifically for boats.
    call nick, i'm sure he'll be more than happy to assist in any questions you may have...
    Marine31- Boat Waxes, Cleaners & Polishes
    1-877-797-8803
  4. #4
    Newbie Member
    Join Date
    Jul 2017
    Posts
    26
    Post Thanks / Like
    I've used use white vinegar and water 50/50; Boat Bling Hot Sauce; Meguires Hard Water Spot Remover; and Babes Spot Remover, and they all worked fine for run-of-the mill hard water spots on gel. Now I wipe the boat down with Babe's Boat Bright pretty much every time I pull it (I trailer for every use) and have not had any water spots to remove in a while.
  5. #5
    Super Member
    Join Date
    Feb 2015
    Location
    Ft. Lauderdale,Fl
    Posts
    615
    Post Thanks / Like
    I use an acid based product if they are bad. Lot less work and it's ready for wax after that.
  6. #6
    Newbie Member
    Join Date
    Jul 2017
    Posts
    18
    Post Thanks / Like
    There is a product called "Boat Bling Hot Sauce". When I purchased a new seadoo we went out to a lake that had lots of minerals in the water and what was once a new ski looked like it sat outside for a year. I was beyond upset and nothing was making it better. I found this stuff on another forum and gave it a try. The first time you might have to go over it twice but after that, its a piece of cake. I used it now after each ride and the ski looks new again.
  7. #7
    Regular Member
    Join Date
    Nov 2013
    Posts
    110
    Post Thanks / Like
    Muratic acid bath
    Dry
    Alcohol whip down
  8. #8
    Super Member
    Join Date
    Dec 2006
    Posts
    798
    Post Thanks / Like
    FWIW, I've had really good luck with Mother's Cleaner wax on hard water spots. So good that one time I got a rental that was hammered with some too, figured it couldn't budge them, I was wrong. I've tried all sorts of other products, not much luck with others, DG501 was even marginal in that respect.
Similar Threads
  1. Removing Water Spots
    By lightsout66 in forum Auto Detailing 101
    Last Post: 05-12-2018, 11:09 PM
  2. Help Removing Hard Water Spots on Boat
    By malibuboats91 in forum Boat & Marine Craft Detailing
    Last Post: 06-04-2014, 08:10 AM
  3. help removing water spots
    By cadd in forum Auto Detailing 101
    Last Post: 01-05-2011, 10:55 AM
  4. Removing Water Spots - Very Old Car
    By rmmagow in forum Ask your detailing questions!
    Last Post: 01-03-2010, 05:23 PM
  5. Removing Water Spots
    By dsyukon in forum Show N' Shine
    Last Post: 08-19-2006, 09:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
