Dislikes: 0
Re: Pearl White Paint, How Do I See Swirls?
Originally Posted by Eldorado2k
It's kinda hard to put into words... Have you ever painted the walls inside your house? Do you remember how after painting for the 1st time you gained a whole new way to focus in on the paint and easily recognize the difference between 1 coat of paint vs. 2 coats of paint? Well it's nothing like that, but in a way it's similar because once you figure out how to spot swirls it just becomes sort of natural [easy] no matter what color the vehicle is. [even silver & white]
Here's an example of defects on white paint: The contamination is extreme here, and believe it or not so are the swirls, but they're still somewhat hard to see... Your car won't be anywhere near this bad.
And after decontamination & polishing away the swirls.
Ha, I get what you are saying. Thanks for the input.
Sent from my SAMSUNG-SM-G890A using Autogeekonline mobile app
Originally Posted by Mbss
This is the trick! I recently did "paint correction" on my Summit White Camaro. I tried all sorts of shop light combinations and in the sun but couldn't see scratches that I knew were there. Bought the Rupes Pen Light and used it in dark garage and was horrified of all the scratches I hadn't seen! Almost wish I hadn't used this light!
I turned off the lights in the garage and worked my way around the car. I tried to look at each area from various angels. I found holding the light a 45 degree angle worked best and hold the light away from me. Once I was ready to start compounding, I would find the spots again I wanted to correct and put a little dab of compound (used Meguiars Ultimate Compound which is slightly yellowish) on the spots. Then turn my work light on and start compounding using the dabs as my guide.
How is the UC to work with? What did you use for a polish?
Super Member
Similar Threads
By conman1395 in forum Ask your detailing questions!
Last Post: 07-21-2014, 02:11 PM
By TroyM in forum Auto Detailing 101
Last Post: 03-12-2013, 09:09 AM
By HellaBroke in forum Ask your detailing questions!
Last Post: 12-17-2012, 12:39 AM
By Buckskincolt in forum Auto Detailing 101
Last Post: 09-10-2011, 10:42 AM
By clm65 in forum Auto Detailing 101
Last Post: 08-30-2011, 05:28 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
31 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
| 1 | 2 | 3 | 4 |
Bookmarks
