Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Super Member WillSports3's Avatar
    Join Date
    Jun 2016
    Location
    Toronto, ON
    Posts
    1,453
    Post Thanks / Like
    2015 Lexus IS250 Corrected and Coated
    I've been meaning to post this for a while but because of work and lack of time, I've been putting it off. This was actually done in June and it was sort of an experiment for me. This car was purchased as part of Lexus Certified Pre-Owned program last year in November. It had very low kilometers and I was able to talk the sales guy down about 5 grand on purchase so I thought it was a great deal. Plus my girlfriend thought it was pretty, so it's a win win. After I purchased this last year, there was no way I was going to do any paint correction or coating when the average weather was about 6 degrees or so Celsius. That's about 42 degrees Fahrenheit for most of the forum. So in order to ensure no more damage was done to the car, I clayed it and applied Pinnacle Black Label Synergy to it. It looked great except for the swirls but that was a whole another matter. To give you a bit of a background, when I purchased the car, the agreement was for them to not detail the exterior at all. The Sales Manager was confused and asked why, and I basically told him I would rather do it myself. He was a very nice gentleman and I didn't want to insult him by saying I don't trust his minimum wage detailers to run a rotary over thin Lexus paint. I already knew I had my work cut out for me and I didn't want to add to it.
    So here are the pre-correction swirls on it, this car was obviously rotaried by the dealership when it was purchased and the previous user took advantage of the Lexus wash tokens. After my purchase, the sales manager handed me a handful of tokens for the automatic brush wash they had on site. I could take my car there at any time and get my car washed. What surprised me was he even said, it was better to do a touchless wash and because too many runs through their car wash will scratch the car up. I was pleasantly surprised by the fact that he would admit that but I digress.
    2015 Lexus IS250 Corrected and Coated-20170612_111629_resized-jpg 2015 Lexus IS250 Corrected and Coated-20170612_111645-jpg 2015 Lexus IS250 Corrected and Coated-20170612_111725_resized-jpg
    These are just one side of it. I didn't even bother taking more because, well, quite frankly this was everywhere.
    The car was washed with ONR, as well as clayed with ONR and then Iron Xed. After the Iron X, I hosed it all off and dried it. I forgot to take pictures of the wheels but the wheels were not too bad, I had the car for about two days before I put on the winter tire rims so a quick Iron X and then Zep 505 on the rims and rubber cleaned them up. Afterwards, I applied Reload to the rims and then TW Tire Coating, five coats total.
    2015 Lexus IS250 Corrected and Coated-20170613_140007_resized_2-jpg
    So as an experiment, I used a Lake Country MF cutting pad with CarPro Essence to compound and then Hyper Polish to finish it off. To be frank, it worked better than I thought it would. I figured I would have to break out the CG V32. I know a lot of guys on here don't like their polishes but I find their V32 with an Orange pad a great one step as long as you spritz the pad with distilled water to get rid of the dusting issue.
    2015 Lexus IS250 Corrected and Coated-20170612_111958_resized-jpg
    This was the amount I used to prime the pad. I also keep a bucket of ONR solution which I keep my pads dipped in, as well as a seperate grit guard I use where I dip the pad in ONR and then spin it on the highest setting pressing hard against the grit guard to clean it.
    2015 Lexus IS250 Corrected and Coated-20170612_111932_resized-jpg
    This is the result between a freshly used MF pad and my ghetto pad washing method.
    2015 Lexus IS250 Corrected and Coated-20170612_112928_resized-jpg Dirty Pad
    2015 Lexus IS250 Corrected and Coated-20170612_112954_resized-jpg Cleaned Pad
    Now at this point the paint looked pretty good so I figured ok.. I'm already screwing around with the nature of things by using a Glazing finishing polish as a "compound" of sorts and using an orange pad to finish off with a polish. So, I decided why not violate nature some more? I put three dots of Essence on the MF pad and give it a spritz of Hyper Polish at the same time. I figured if that didn't work well, I would just go back to my original method but.. this was the result.
    2015 Lexus IS250 Corrected and Coated-20170612_114727_resized_2-jpg
    That worked well for me so screw it, the whole car got that treatment. Now that being said, this is still a daily driver and there were a few deep scratches I didn't bother trying to compound. I actually hate compounding in all honesty, don't get me wrong I know those who do this professionally do it for their bread and butter. However for me, being that this has already been rotaried by someone when it was brand new, the last thing I want to do is compound it. Especially since I can live with the odd scratches on the hood and the roof. I probably could have got it out with a compound but I would rather save the clear coat for when I go over it with some Essence and an Orange pad every year or two.
    After that, the car was wiped down with CarPro Essence diluted with about 15 percent IPA mixture three times. Then it was Gloss coated. The blue applicator sponge was as much a PITA as I remembered it. It squeaked like a small vermin in heat quite frankly and I switched over to the CarPro block and the MF suede applicator cloth. It was Gloss Coat so the process was easy. I did two coats, and then let it bake in the sun for a few hours.
    This is the end result.
    2015 Lexus IS250 Corrected and Coated-20170613_135948_resized_1-jpg 2015 Lexus IS250 Corrected and Coated-20170613_151326_resized-jpg 2015 Lexus IS250 Corrected and Coated-20170613_152153-jpg
    The windows were treated with an oddly effective combination. I used GTechniqs G5 and then Pinnacle Synergy Black Label after. I have that on my Mazda since Spring of Last year and it still beads off at 55 km/h or around 35 Miles in the rain.
    2016 Mazda 3 Sports GT
    2015 Lexus IS250 F Sport
  2. #2
    Super Member VISITOR's Avatar
    Join Date
    May 2007
    Posts
    9,723
    Post Thanks / Like
    Re: 2015 Lexus IS250 Corrected and Coated
    nice job, love that color too...
  3. #3
    Super Member ICEMAN's Avatar
    Join Date
    Aug 2009
    Location
    Oak Harbor, Ohio
    Posts
    807
    Post Thanks / Like
    damn thats nice! Love that color. My sister had a dark gray IS250 and man i loved that car! She always drive it in ECO mode to get the gas mileage and everytime i visited it went straight to sport mode. Eco mode had to long of a pause between touching the gas pedal and it actually moving, lol. and a big difference in suspension.
    17 Tucson | 2015 Mustang Ecoboost Premium PP | 89 Kawasaki Ninja ZX-10
    @TheRealPolisher on FaceBook | @green2kgt on IG
  4. #4
    Join Date
    Jun 2016
    Location
    Toronto, ON
    Posts
    1,453
    Post Thanks / Like
    Day to day I do have to say, eco mode saves you gas. But if some punk pulls up next to me with his fart can mufflered lowered car and revs at me.. sports mode gets worked.
  5. #5
    Join Date
    Aug 2009
    Location
    Oak Harbor, Ohio
    Posts
    807
    Post Thanks / Like
    Quote Originally Posted by WillSports3 View Post
    HAHA yah i hear yah. she lived in seattle and her work was only 4 miles away but it took 20 minutes so her gas mileage was always like 12, lmao. she needed eco as much as she could.
  6. #6
    Super Member TMQ's Avatar
    Join Date
    Mar 2015
    Location
    Germantown, Md
    Posts
    2,243
    Post Thanks / Like
    That is looks so rich!
    Did you find paint on the soft side?
    Tom
  7. #7
    Join Date
    Jun 2016
    Location
    Toronto, ON
    Posts
    1,453
    Post Thanks / Like
    I would say so. I've used an orange pad before with Essence on this car when I polished out one panel when I first got it just to see how soft it was and it was fine. I just used MF pads this time to make the process faster.
  8. #8
    Junior Member mojo122's Avatar
    Join Date
    Jun 2010
    Location
    Southern Maine
    Posts
    43
    Post Thanks / Like
    F-Sports are nice. I have a black GS350 F-Sport. Is much easier to maintain thanks to this site and having applied a coating to it.
  9. #9
    Super Member Sizzle Chest's Avatar
    Join Date
    Apr 2011
    Location
    Naples, FL
    Posts
    5,897
    Post Thanks / Like
    Very nice work...that color too! Looks great!
    Scott Harle
    Autodermatology
    #autodermatology
  10. #10
    Newbie Member
    Join Date
    Jul 2017
    Posts
    1
    Post Thanks / Like
    You mean Pinnacle Black Label Diamond Glass Coating or a wax?
Similar Threads
  1. 2015 Porsche Macan Turbo Corrected and Coated
    By Dabbac in forum Show N' Shine
    Last Post: 03-23-2018, 09:24 PM
  2. Detailing in a Blizzard! 2015 SHO Taurus gets corrected and coated
    By Justin at Final Inspection in forum Show N' Shine
    Last Post: 03-20-2018, 06:55 PM
  3. Replies: 41
    Last Post: 12-12-2016, 10:18 AM
  4. 2015 Black TESLA Corrected and Opti Coated
    By tdekany in forum Show N' Shine
    Last Post: 12-13-2014, 11:52 PM
  5. 2015 WRX Corrected & Opti Coated
    Last Post: 08-21-2014, 04:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
