Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Newbie Member
    Join Date
    Jun 2017
    Posts
    9
    Post Thanks / Like
    Why do water marks a d scratches come out after buffing?
    I buffed my camaro a few times always had swirl marks come out for some reason. I bought the boss G21 to make my jobs go quicker and better. So I buffed it out and looked amazing under all my lights no issues what so ever. So I applied the Gtechniq ex0 coating how they recommended. 3 days later I'm noticing water spots , scratches and imperfections popping up. Now why is that after everything look great when I did it and now everything is showing thru? Looking to resolve this issue. I'm working on a black Mercedes that needs paint correction. So far it's coming out like glass. It I use a rotary buffer first to cut it better then I go with the boss g21.
  2. #2
    Super Member Cruzscarwash's Avatar
    Join Date
    Oct 2015
    Location
    Desert of California
    Posts
    2,425
    Post Thanks / Like
    Re: Why do water marks a d scratches come out after buffing?
    well, there are a lot of factors, lighting when you did the correction could have mislead you
    your polish of choice might have had filler in it
    you might have put the marring there during the wipe off or prep for the coating
    you might have put them there during the coating application itself
    if you touched the paint at all in the last 3 days for any reason that could have caused marring as well
  3. #3
    Join Date
    Oct 2015
    Location
    Posts
    2,425
    Post Thanks / Like
    oh also, NOTHING will stop water spots... nothing. if water is left to dry and has any contaminates in It, it will spot
  4. #4
    Mike Phillips
    Guest
    Quote Originally Posted by Gregj7105 View Post
    What pads and products did you use to cut the paint?
    When you say you correctly applied the GTechniq EXO "how they recommended" - I assume this means you used the GTechniq Panel Wipe to chemically strip the paint before applying the EXO?
  5. #5
    Newbie Member
    Join Date
    May 2007
    Posts
    12
    Post Thanks / Like
    What CruzWashes said.. "your polish of choice might have had filler in it"
    You can use this to find a product that doesn't use filler.
    Search
  6. #6
    Newbie Member
    Join Date
    Jun 2017
    Posts
    9
    Post Thanks / Like
    I was using the menzerna 400 compound and their polish. I buffed it all out with the boss g21. For lighting I got an idea from a thread on here so I don't think lighting was an issue. Pads I was using what I got from griots garage to test them out. Everything seemed fine and glossy I did the wipe down the GTechinq eso. I did notice some minor scratches but nothing to big. It say in the garage for over 12 hours. I finished polishing it on Saturday left it outside on Sunday and now I noticed all the imperfections in the paint. Anything from bird droppings to water spots and scratches. It looked great even when I took it outside but a day later i noticed something then today even more.
  7. #7
    Super Member The Guz's Avatar
    Join Date
    Jun 2013
    Location
    LA, CA
    Posts
    8,719
    Post Thanks / Like
    What version of exo? I read that exo V2 was prone to spotting and marring. Coatings typically are prone to water spots.
    Could also be the towels used.
  8. #8
    Newbie Member
    Join Date
    Jun 2017
    Posts
    9
    Post Thanks / Like
    Ex0 3, it almost looks like whatever was on there stayed on there from before. That the compound hid it for awhile and brought it back out.
  9. #9
    Mike Phillips
    Guest
    Okay, so just to clarify, you used,
    Griot's Garage BOSS 21
    Griot's Garage BOSS pads (I'm assuming here because you were not specific as to which Griot's pads but it's a fairly safe assumption)
    Menzerna FG400 and one of the Menzerna polishes
    eso?
    Gtechniq eso?
    Do you mean GTechniq EXO?
    I don't know what eso is?
    Also, did you CHEMICALLY STRIP THE PAINT AFTER MACHINE POLISHING?
    That would be a mandatory step before applying the GTechniq EXO.
    I think I asked this previously but so far you have not answered if you did this step and if you did what you used?
    Everyone here on the forum is all about helping you but sometimes the little things are the big things = as in little tidbits of information.
    Having a hard time following your typing.
    After polishing but before coating you left he car outside?
  10. #10
    Newbie Member
    Join Date
    Jun 2017
    Posts
    9
    Post Thanks / Like
    Sorry my phone keeps changing the words on me. I used boss 21 with the boss pads. Yes it's Gtechniq Exo V3 that I used and it came with a solution to wipe down the car after you polish it kinda like wax and grease remover. After 15 hours of being in the garage I left it outside because I'm working on another car. It basically looks like water spots on my car. I wiped it down with detail spray, but it wouldn't come off. I took some polish with the boss G21 and it cleaned up the spots. Looks like that's what I might have to do to it again.
Similar Threads
  1. Buffing Scratches
    By islandtees in forum Ask your detailing questions!
    Last Post: 12-23-2020, 09:56 AM
  2. Marks after buffing the polish off
    By Octaviavrs in forum Ask your detailing questions!
    Last Post: 08-06-2017, 08:01 AM
  3. Tape marks left in paint after buffing test spot......
    By Red Lehr in forum Ask your detailing questions!
    Last Post: 05-17-2017, 05:03 AM
  4. Isolated buffing marks / buffer trail
    By Jmbrown415 in forum Auto Detailing 101
    Last Post: 04-03-2017, 11:17 AM
  5. Cannot remove swirls/water marks/ scratches
    By RoyalBlUE08 in forum Ask your detailing questions!
    Last Post: 08-09-2011, 02:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» March 2024
S M T W T F S
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
