Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Junior Member GrantLagasse's Avatar
    Join Date
    Mar 2016
    Location
    Cape Cod, MA
    Posts
    32
    Post Thanks / Like
    Rupes 75E Mini advise
    Hi all, I'm about to order a rupes 75e mini 3" to compliment my GG6. After reading lots of negative reviews on griots mini I decided to just spend the money on the rupes. I've never used a "long throw" machine and just wondering if there's anything I should know before using it on someone's car. Also, a little lost on pad selection. The 75e mini comes with a 3" backing plate and there seems to be a lot more people using the 3.5" BPs with 4" pads. Do I stay with the original 3" and go with some LC Thinpro 3.5" pads?
  2. #2
    Super Member WaxMaster1's Avatar
    Join Date
    Jul 2015
    Location
    Central Florida
    Posts
    1,261
    Post Thanks / Like
    Re: Rupes 75E Mini advise
    Grant, that's exactly what I do. I use my Rupes Mini with the Lake Country Thinpros. You'll love it.
  3. #3
    Super Member dlc95's Avatar
    Join Date
    May 2013
    Location
    Rochester Hills, Mi
    Posts
    6,016
    Post Thanks / Like
    Another route would be to get another GG6, and throw a 3" plate on it.
  4. #4
    Join Date
    Mar 2016
    Location
    Cape Cod, MA
    Posts
    32
    Post Thanks / Like
    Quote Originally Posted by dlc95 View Post
    Seems to be a lot of cons to that though. (Vibrations, hard to control, over powerful for 3" pads if I read correctly). Would you happen to know how it would be height-wise from pad to top of machine compared to the rupes?
  5. #5
    Join Date
    May 2013
    Location
    Rochester Hills, Mi
    Posts
    6,016
    Post Thanks / Like
    Quote Originally Posted by GrantLagasse View Post
    True, I've heard the too.
    I don't know off hand the height difference.
    It might be that people are using the gg6 full bore at speed 6 with 3" thin pads experiencing a lot of vibration.
    The GG6 is said to be smoother than the PC 7424 which I regularly use with 3" Hydrotech pads - with no vibrations.
    I also have a mini, which is an incredible tool, but I've only ever used it with the Rupes pads. I'm sure it would be fine using other pads. I actually just received my 3" HDO pads Friday. I'll probably be taking them for a spin this week.
    If you already have the GG6, maybe just order the 3" plate, some pads, and see how you like it. You might find that you don't even need the extra tool!
  6. #6
    Regular Member
    Join Date
    Mar 2015
    Posts
    133
    Post Thanks / Like
    I will recomend you to using Buff and Shine URO-Tec than thin pro, they are made for Rupes and Maroon pad is amazing. I am much prefer URO-Tec than thin pro, it's much flexible to tight area due to thicker and bevel edge.
  7. #7
    Super Member VISITOR's Avatar
    Join Date
    May 2007
    Posts
    9,721
    Post Thanks / Like
  8. #8
    Super Member custmsprty's Avatar
    Join Date
    Apr 2012
    Posts
    7,494
    Post Thanks / Like
    Too tall, it's tippy and at best a short term solution. I did a test one day with my GG6 and a 3" BP and my Rupes Mini, I otssed the GGR aside after a couple minutes. I love my Rupes Mini. I also use it to apply selantss and waxes. And even with the new Griots bp it's still not a dedicated 3" polisher. If you have the money you will not be disappointed with the Mini. If you want to save the money then do the GG6. I've never regretted once buying my Mini. It's also alot easier to get into tight areas and it doesn't have that metal shroud like the GG6 that can bang off of mirrors and bumpers and tighter areas. The Rupes pads exten out too, so it's easier to get into tight areas.
    This is my Mini with a 4" Buff and Shine Pad applying a sealant.
    2013 Genesis Coupe 3.8 Track Edition
    2015 Hyundai Sonata Limited, 2016 Pearl White Nissan Altima SR
    2019 Nissan Rogue SL
  9. #9
    Super Member Rsurfer's Avatar
    Join Date
    Jan 2007
    Posts
    14,093
    Post Thanks / Like
    You won't regret getting the Mini.
  10. #10
    Regular Member Natron's Avatar
    Join Date
    Dec 2013
    Location
    Carterville, Il.
    Posts
    151
    Post Thanks / Like
    A great tool. We use rupes MF most of the time. Very aggressive. Removes a lot of paint fast, very easy to get carried away and go through. Nathan
Similar Threads
  1. Recommended pads for Rupes mark ll and Rupes mini
    By Elger in forum Wool & Foam Buffing Pads
    Last Post: 06-21-2016, 09:32 AM
  2. My first time using my Rupes 21 and Rupes Mini
    By mrasmussen in forum RUPES BigFoot Oribital Polishers
    Last Post: 06-15-2016, 10:25 AM
  3. Replies: 29
    Last Post: 05-21-2016, 07:46 AM
  4. Rupes Mini 12 vs Griot's Garage Mini Polisher
    By Mike Phillips in forum Ask your detailing questions!
    Last Post: 11-13-2013, 12:57 PM
  5. New Rupes Duetto and Rupes Mini Polishers vs Prototypes
    Last Post: 11-13-2013, 08:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
