Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 68
  1. #21
    Super Member Octopiston's Avatar
    Join Date
    Mar 2016
    Location
    Ft. Worth, TX
    Posts
    287
    Post Thanks / Like
    Re: Boss MF pad issue
    Had one do this in May. One of my neices was running it on her car so I just figured it was bumping against an emblem, and that could have very well be the issue that time. I'll definately watch for future issues though.
  2. #22
    Super Member mwoywod's Avatar
    Join Date
    Apr 2016
    Posts
    881
    Post Thanks / Like
    Quote Originally Posted by The Guz View Post
    I have one that started to show similar signs. Used on my Rupes LHR15 MKII on speed 4 with D300. The other one that came in the package looks fine.
    how many panels did you use it on? If you only used 2 for an entire car that would definitely be a contributing factor. Also, Boss creams are much more lubricated than even D300 so I would assume that plays a factor. Not sure though. There is clearly an issue with the foam but at the same time I haven't found another pad to run as smooth on flat and convex curves with a long throw polisher than the boss MF pads.
    I've said this before, but if they made a pad using the white open cell foam interface on the new buff & shine uro-fiber pads AND the actually microfiber from the boss pads, it would truly be the perfect microfiber cutting pad.
  3. #23
    Super Member The Guz's Avatar
    Join Date
    Jun 2013
    Location
    LA, CA
    Posts
    8,719
    Post Thanks / Like
    Quote Originally Posted by mwoywod View Post
    I honestly can not remember how many panels. I haven't used these pads in about a year when I worked on this 2002 Black C5 Corvette Coated with Optimum Gloss Coat.
    I was testing these pads at the time comparing them to the Meguiar's microfiber pads. Trust me I have way more pads than to use just two on one car.
  4. #24
    Super Member Legacykid's Avatar
    Join Date
    Sep 2013
    Location
    N. ATL
    Posts
    451
    Post Thanks / Like
    Well I am glad to see im not the only one.
    And if they made a pad,a machine and polished to run together as a complete system. These bad boys better run properly on speed 6 without issues at all.
    Ive had that interface pad melt after 2 sections.... Are you kidding me?
    Also the white pads are so stiff that they do not even make full contact. I even tried washing them too.
  5. #25
    Join Date
    Apr 2016
    Posts
    881
    Post Thanks / Like
    Quote Originally Posted by Legacykid View Post
    Micro-fiber pads generate too much heat and the fibers matte down making the pads less effective. Much like how Rupes Blue coarse foam cutting pads have been know to start disintegrating rapidly at too high of speeds, Boss Microfiber pads also do not work well with extreme machine speed. Speed 6 should be reserved for concave/convex areas where you are trying to maintain pad rotation you can temporarily turn it up to help power through those spots but if you're using speed 6 over an entire panel, you'll have to adjust your technique if you want the Boss system to work for you.
    I completely understand why everyone else is frustrated because they weren't aware of the precautions needed to use the pads effectively. But your issue is technique, and even if you have the pads replaced it's going to happen again if you don't make adjustments. Much like the Rupes system, the Boss system works as long as you're willing to be reasonable and adapt where necessary.
  6. #26
    Super Member
    Join Date
    Jul 2016
    Posts
    3,328
    Post Thanks / Like
    Has this happen to anyone else? I used this on the G21, and GG6. I use no pressure, just weight of machine to polish. Ive ripped up a few pads. The last one I ripped up was testing how it happens on a hood, one handed on speed 4.5 G21. I could see red foam flying out of the pad. So that eliminates heat, and pressure. <br><br>Any thoughts, or is this just what it is?
    i had a gg microfiber pad rip as far as the microfiber coming off the pad. i think it was from the washing machine though IDK.
    i was using gg microfiber pads on a boat last weekend with a flex on speed 6 and i felt no heat build up at all other then the motor of the flex
  7. #27
    Super Member
    Join Date
    Feb 2014
    Location
    Rochester MA
    Posts
    2,627
    Post Thanks / Like
    I use the BOSS microfiber cutting pads as my go to with my g21 on speed 6 all the time. Unfortunately this has happened to a good bit of them. Like someone​ else mentioned I think it's a combo of a few things. Foam not dense enough, putting pressure on an edge while polishing is the main reason or catching an edge while polishing.
    IGL Authorized Coating/Kenzo Installer
    Final Inspection Auto Detailing- https://www.facebook.com/FinalInspection
  8. #28
    Super Member RaskyR1's Avatar
    Join Date
    Apr 2008
    Location
    Shakopee, MN
    Posts
    3,733
    Post Thanks / Like
    I would contact Griot's then and I'm sure they will take care of you. These pads are really all I've used for cutting the last 30 months or so now and I have yet to have one fail or look like that. I've not run them on my GG6 but they have been used on both the G15, G21 and even my Rupes 21 MKII.
    Quote Originally Posted by CieraSL View Post
    Wait! I know! Mirror, mirror against the grass, tell me who has kicked swirls' ass?
    http://Raskysautodetailing.com/
  9. #29
    Join Date
    Sep 2013
    Location
    N. ATL
    Posts
    451
    Post Thanks / Like
    What exactly is the issue with my technique?
  10. #30
    Join Date
    Sep 2013
    Location
    N. ATL
    Posts
    451
    Post Thanks / Like
    This is an issue with too much pressure, speed, and heat more so than anything
    If you care to read the first post all of this was covered is why im asking whats wrong with my technique?
Similar Threads
  1. Detailing Class - Griot's BOSS System - Learn to detail like a BOSS!!!
    By Mike Phillips in forum PICTURES: 3-Day CAR Detailing Bootcamp Classes
    Last Post: 04-06-2018, 02:37 PM
  2. Boss 6.5&quot; orange pad issue
    By TiCaLLioNStaLLyN in forum Wool & Foam Buffing Pads
    Last Post: 08-26-2017, 10:10 PM
  3. BOSS Interflex Pad Issue
    By LSNAutoDetailing in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
    Last Post: 07-16-2016, 03:16 AM
  4. Boss! ur car is done..
    By JasonFong in forum Off-Topic
    Last Post: 03-26-2010, 03:02 PM
  5. What we do when the boss is away...
    By Meghan in forum Off-Topic
    Last Post: 11-08-2008, 02:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
