Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 6 of 26 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 259
  1. #51
    Super Member
    Join Date
    Apr 2015
    Location
    PGH, PA
    Posts
    1,482
    Post Thanks / Like
    Re: Flex 3401 vs. Rupes Mille/Makita P5000C, for those that are wondering.
    Quote Originally Posted by WRAPT C5Z06 View Post
    Buy this machine for the forced rotation. The random orbit mode is terrible. I was going to sell my GG 6" random orbital, but I'm going to keep it now.
    it seems like when a DA has less stroke, it stalls easier...GG3 good example , nano with 3mm essentric.. etc
  2. #52
    Super Member ScottH's Avatar
    Join Date
    Nov 2015
    Location
    Northern NJ
    Posts
    895
    Post Thanks / Like
    Quote Originally Posted by nothingface5384 View Post
    yeah, ill try the scion fender again, and does your makita body get warm, mid section?
    I haven't used it to polish a car yet but running it for a few mins (free air) I didn't notice any warmth at all. But it had no load on it so I wouldn't expect it to get warm ...
    ScottH
  3. #53
    Super Member
    Join Date
    Apr 2015
    Location
    PGH, PA
    Posts
    1,482
    Post Thanks / Like
    I've don't have 1/3 scion hood, small section of fender and a door..body got warm between tool rests. Front and rear grip uneffected.
  4. #54
    Super Member VISITOR's Avatar
    Join Date
    May 2007
    Posts
    9,726
    Post Thanks / Like
    i thought you already sold the GG6 when you bought the HF DA?
  5. #55
    Join Date
    Nov 2015
    Location
    Northern NJ
    Posts
    895
    Post Thanks / Like
    Ok guys so I conducted a rudimentary but effective test of random orbit mode of the Makita 5000 as it relates to pad stalling, on flat surfaces and curved. I started with an LC CCS pad on it with the 5000 in free rotation mode, speed setting at 2. While on the flat surface of my dryer, I started the polisher and the pad did not spin at all. Bumped it up to speed 3, and again the pad was stalling under ONLY it's own weight - I was applying no pressure at all. Bumped up to speed 4 and of course the pad started to spin, but not very fast at all - lifting the head of the polisher up the pad regained speed - but who's going to do that while polishing! Speed 5 the pad spun very quickly and on a flat surface was hard to bog down. Now I thought to try this same test on the curved 'panel' of the dryer - shown here in the picture. On speed 4 or less, there was very little if any pad rotation as I rode the corner, and it regained speed once on the vertical panel of the dryer. On speed 5 the pad did maintain rotation around the curve albeit slower than while on a flat surface.
    In direct drive mode, the pad rotated regardless of speed setting, and was not possible to bog down whether on a flat surface or curved, but that is to be expected in a direct drive unit.
    I understand this was not a 100% scientific test but it did second what WRAPT said above - I was extremely unimpressed with the unit in free spin mode - bogging down under its own weight unless it was run on speed 4 or higher, and at speed 4 there was very little pad rotation.
    If you are buying this to use solely as a direct drive unit, it's got power. If you are planning to use it extensively in free spin mode, get a GG6, BOSS15/21, Rupes etc. Makita missed the mark by a MILE in free spin mode as far as pad rotation goes. I ran the same test with my GG6 and on speed 1 (flat surface), and the rotation under its own weight was what the Makita needed speed 4 to match pad rotation.
    PS when I swapped the CCS out for a LC ThinPro, pad rotation was slightly better but no where near what the GG6 could muster in pad rotation.
    Sorry I couldn't video this tonight - wife was in no mood to be bothered with my 'tests' tonight - I knew better than to ask. LOl!
    ScottH
    Attached Thumbnails Attached Thumbnails Flex 3401 vs. Rupes Mille/Makita P5000C, for those that are wondering.-img_0054-jpg   Flex 3401 vs. Rupes Mille/Makita P5000C, for those that are wondering.-img_0055-jpg
  6. #56
    Super Member
    Join Date
    Nov 2009
    Location
    Pasadena, CA
    Posts
    12,615
    Post Thanks / Like
    Quote Originally Posted by VISITOR View Post
    I still have an early 2nd generation GG DA that I recently fixed. The cord was bad and I finally got around to fixing it. It's better than the newer GG 6" and the HF DA.
    '03 Corvette Z06
  7. #57
    Super Member
    Join Date
    Nov 2009
    Location
    Pasadena, CA
    Posts
    12,615
    Post Thanks / Like
    Don't have those to compare, but maybe it is the stroke length. Anyhow, while VERY smooth the Makita is in random orbit mode, it's stalls VERY easy.
    '03 Corvette Z06
  8. #58
    Super Member
    Join Date
    Nov 2009
    Location
    Pasadena, CA
    Posts
    12,615
    Post Thanks / Like
    Quote Originally Posted by ScottH View Post
    ScottH
    Nailed it, Scott.
    I haven't had a chance to test true correction ability in forced mode, but if Rupes claims the Mille will correct better than the Mark II 21, the Makita in forced mode should correct better than both the Mille and Mark II 21.
    I'm really looking forward to trying the Mille pads and polishes on the Makita.
    '03 Corvette Z06
  9. #59
    Super Member
    Join Date
    Apr 2015
    Location
    PGH, PA
    Posts
    1,482
    Post Thanks / Like
    On another note
    When I tested rotation on test panel, I used dry 6.5 low pro
    On Scion XB i used compound with both 6.5 low probably 5.5 thin pro
    Rotation we're both excellent at 3 and 4 but nothing with 5.
    I'll video it all
  10. #60
    Join Date
    Nov 2015
    Location
    Northern NJ
    Posts
    895
    Post Thanks / Like
    ScottH
    Mike Phillips - hi Mike, did you experience the same poor pad rotation in free spin mode during your initial review?
    Thanks,
    ScottH
Similar Threads
  1. Replies: 3
    Last Post: 10-25-2019, 05:52 AM
  2. Rupes Mille or Flex 3401
    By Trevine in forum Auto Detailing 101
    Last Post: 03-15-2019, 04:04 PM
  3. Rupes Mille vs 3401 - UPDATED Thoughts
    By TTQ B4U in forum RUPES BigFoot Oribital Polishers
    Last Post: 10-22-2018, 08:26 PM
  4. Flex XC3401, Rupes Mille, or Makita
    By minirips2 in forum Ask your detailing questions!
    Last Post: 04-16-2018, 09:36 AM
  5. Makita PO5000C vs Rupes Mille vs Flex 3401 specs
    By Mike@ShineStruck in forum Auto Detailing 101
    Last Post: 12-23-2017, 02:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
