Dislikes: 0
Re: Meguiars Plastx Clear Plastic Cleaner & Polish
Originally Posted by Crispy
Heck with it I'm going to try it on my powder coated winter rims (the barrels).
It's May 24 long weekend so lots of time to try.
Going to try PlastX , Plastic Polish that starts with N vs
Menzerns 3800 and Meguiar Mirror Glaze.
Might even use some 2000 grit wet sanding to see what works best
Let me know how the plastX works on the powder coat
How about uploading some pictures?
Super Member
Well went ahead and gave it a test on my powdercoated wheels.
Tested:
PlastX
Novus Plastic Polish
Meguiar's Mirror Glaze
Menzerna 3800
I wet sanded some orange peel with 1500 and 2000 grit for test spot.
First up PlastX applied by hand.
-very little effect and no shine
-rag turned slightly black
Next Novus
-same as PlastX with a bit more black on the cloth
-no effect on the sanding marks in the orange peel
Next Meg's Mirror Glaze with blue cutting pad Rupes Nano 1" rotary tool
-orange peel partially removed and colour darkened noticably
-shine coming out now and pad turned black
Last up Menzerna 3800 yellow pad Nano rotary
-very little colour change
-nice shine
-pad turned jet black (just like polishing metal)
-would not undo colour change from Megs Mirror Glaze
Conclusions:
-Menzerna 3800 with yellow pad on Nano rotary tool best results
-don't wet sand orange peel unless want to spend long time and effort to remove (colour will darken as well)
-polishing turns pads black (looks like you are polishing bare metal)
Comments:
Surprised that a fine polish produced best results
Colour change was result of wet sanding and blue cutting pad
Plastic polishes or compounds do not work
Crispy 2001 Pontiac Grand Prix DD, always clean (except today) Hobby Detailer
Tested:
PlastX
Menzerna 3800
Next Novus
-nice shine
Conclusions:
Comments:
Thanks for this info. So to conclude, I should not waste my time using PlastX to remove fine surface scratches?
Super Member
Yes it does nothing.
Fine polish for paint seems to be best.
Maybe metal polish might work too.
I'm not going any further on tresting.
Originally Posted by mengelhardt
Because Plastx is designed to be used on plastics..... which you are not going to be working on. You said you are polishing clear coated, painted wheels.
Since you are going to be polishing clear coat (paint), use a product designed to polish clear coated paint like swirlX, ScratchX, or UP. (if sticking to Meguiars products)
he said the wheels are powder coated. He thinks there is a clear coat but he doesn't know. If they are powder coated then they probably are not clear coated.
Originally Posted by OCDetailingTO
Not sure. The guy who powder coated the wheels (reputable business) says that the candy red is a clear coat which can be buffed just like plastic. The base coat is Kromezone and top coat is candy red. Not sure if that info helps. I'm assuming a plastic powder was applied?
how can it be clear if its candy red?
Super Member
If requested: Powdercoaters can apply
clear-powdercoat...no problem.
"Be wary of the man who urges an action in which he himself incurs no risk."
~Joaquin de Setanti
Super Member
My wheels are only powdercoated.
Basecoat and clear.
The fine polish turned black just like metal polishing bare metal.
Shine was really good, but the powdercoating was poorly done so lots of orange peel and defects remain.
To clarify, my powder coat wheels have a base coat - Kromezone with candy red clear coat on top. Just spoke to my powder coat guy and he had success in the past using PlastX on fine scratches. He says I can treat them like clear coated wheels and any swirls buffs out just like plastic. Not sure if that sounds confusing but just relaying.
Similar Threads
By Crispy in forum Ask your detailing questions!
Last Post: 10-09-2016, 04:11 PM
By AZpolisher15 in forum Auto Detailing 101
Last Post: 08-20-2016, 11:17 PM
Last Post: 12-15-2015, 10:41 PM
By Islander in forum Auto Detailing 101
Last Post: 06-29-2007, 06:54 AM
By Bulla2000 in forum Auto Detailing 101
Last Post: 05-06-2007, 07:40 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
25 | 26 | 27 | 28 | 29 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 | 2 | 3 | 4 | 5 | 6 |
Bookmarks
