Dislikes: 0
Super Member
Re: Sealant suggestions
Originally Posted by idriveblackcars
I dunno man I never had any issues with Jetseal. And I used it for winter. Would totally use it again.
Here's the thing, uv rays trump winter. You have a black car, park that bad boy outside in Florida even in January and the paint will be hot, May right now in Tampa surface temp would be hundreds of degrees, that cooks lsp's. It's 95 degrees outside right now and that's in the shade. The surface temp of your black paint right now would fry an egg down here in minutes. Now park that outside at work for ten hours a day and let's talk about longevity.
My GC is a garge queen. If I pull it out in todays sun and wait 10-15 minutes to wipe it down with any type of detaling spray other than DoDo Tropical Mist it is already too hot on the paint sruface. You can see heat waves baking off of it after 20 or so minutes. So consider all day and the temps that black paint and darker colors get to down here for 9-10 months of the year.
2013 Genesis Coupe 3.8 Track Edition
2015 Hyundai Sonata Limited, 2016 Pearl White Nissan Altima SR
2019 Nissan Rogue SL
Well so far there seems to be a majority of jetseal and powerlock users may give them a try although that sonax pns still has my top interest!
Sent from my SAMSUNG-SM-N920A using Tapatalk
Jetseal was reformulated around the end of 2014. It was jetseal 209 the newer one is supposed to last "up to a year" many that tried it and didn't like it had the older version
There are a bunch of great sealants. Why not go with the Griot's poly wax. http://www.autogeek.net/griots-garag...-poly-wax.html
Super Member
Mike P's recent post on sealants, you may find this interesting
https://www.autogeekonline.net/forum...ml#post1490222
Sealant suggestions
I'm a big fan of Wolfgang's Fuzion estate wax as my final top coat. Its probably the easiest wax i've ever used and is super easy to remove. One coat lasts me about 4-6 months here in NY. I maintain it between washes with Mothers showtime.
Cost's $60 for 3oz
Super Member
This thread is like asking "Who's the greatest rock band"?
I think it all depends on your climate, working surface, paint color, and expectation level.
That being said, I always defer to Mike P's statement of: "Find something you like, and use it often."
It is no coincidence that man's best friend cannot talk.
Super Member
Meguiar's M21 2.0 Synthetic Sealant is the one I use most often.
Rupes 808, and Duragloss 111 are the other two.
Originally Posted by MattPersman
Poly Wax sounds like a rock solid performer. It's next on my list to try. There's a couple good threads floating around here somewhere about the poly wax.
Originally Posted by Cruzscarwash
I have to get doing something wrong with fk1000p because I just don't get the results I hear everyone rave about. I don't get the super glossy look I always hear people claim. Maybe I need to let it set longer then 20 mins. How long are you letting it sit for before you remove it?
Sent from my XT1609 using Tapatalk
I actually take it off pretty quickly. Often I'll do a panel, then one more, then go back and remove the first. I just keep an eye on it and when it finger swipes clean, I take it off. Am I remembering this correctly- did someone here say they even let this sit overnight sometimes before removal? I think I read that recently. Mighta been Bob.
Super Member
Actually no. The greatest rock band is Iron Maiden. Now, trying to find the best Sealant that is one heck of a hard thing to do
Similar Threads
By Mr.Lincoln in forum Auto Detailing 101
Last Post: 07-01-2019, 05:17 PM
By jtuds in forum Auto Detailing 101
Last Post: 06-01-2015, 11:14 PM
By TH3M B0N3Z in forum Off-Topic
Last Post: 04-01-2014, 12:28 AM
By Chuck-Michigan in forum Introduce Yourself
Last Post: 02-26-2014, 02:09 PM
By jkf1983 in forum Auto Detailing 101
Last Post: 04-12-2009, 11:19 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
25 | 26 | 27 | 28 | 29 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 | 2 | 3 | 4 | 5 | 6 |
Bookmarks
