Dislikes: 0
Re: Possible damage to my 3401
Hopefully you didn't damage the motor. I think Mike Phillips just mentioned recently that the Flex machines have a thermal cutoff, so hopefully that protected the motor.
I bought a HF cheap rotary for boats and gel coat. Comes with a wool pad that does pretty good for boats as well.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Super Member
thank you for the replies.. better get this stuff ordered:-(
2012 Dodge Challenger RT Classic Bright Silver
2018 Ford F150 Xlt Sport 4X4 Magnetic Grey
Super Member
Parts ordered! Can't wait to get my Flex right again!
Super Member
Once you take your Flex 3401 apart you will realize how easy it is to repair. Zem Germans made it to where simpletons like me can repair it. If I can repair it you can to!! LOL Please give an update when it's all done and ready to rock again!
CJ
2013 Mustang GT w/Track Pack 6-Speed Manual
Save the Manual!
im sure you checked this..but was the locking nut tight on the backing plate?
Super Member
Do you mean the screw that holds the backing plate on? That was tight when I unscrewed it to take the plate off. Or is there something else I can check? Thanks for your help
Super Member
Received my replacement parts in the mail today. Pretty quick fix and easy fix. Looking back my error was laying to hard on the polisher and not evenly either. I was bending the backing plate thru the felt ring and into the metal part of the polisher housing causing the damage. Lesson learned 70 bucks!
Good to go!!
Super Member
Glad you got it fixed, man.
And, I truly realize I might bring down a hail storm of attacks on me with next line:
For almost $450 bucks, I would want to "Lay on" this unit as hard and long as I wanted to without worrying about a plastic gear, or anything else for that matter failing on me. JMO.
It is no coincidence that man's best friend cannot talk.
Newbie Member
Well, no attack or anything, but what makes you think that paying a higher price for a tool gives you an excuse to use it incorrectly? If I pay $50 for a Snap-On screwdriver, then I should be able to use it as a pry bar, ice-pick, or hammer? I'll never understand this reasoning
Similar Threads
By SpeedDemon77 in forum Auto Detailing 101
Last Post: 07-02-2018, 10:16 PM
By Nibby99 in forum Wet-Sanding, Cutting & Buffing
Last Post: 08-07-2014, 11:12 PM
By ludrady in forum Flex Polishers
Last Post: 07-03-2014, 03:11 AM
By mswerb in forum Ask your detailing questions!
Last Post: 07-24-2013, 12:01 AM
By Meticulous-Detail in forum How to make money detailing cars
Last Post: 11-28-2011, 06:54 PM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
25 | 26 | 27 | 28 | 29 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 | 2 | 3 | 4 | 5 | 6 |
Bookmarks
