Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
  1. #31
    Super Member PaulMys's Avatar
    Join Date
    Jan 2014
    Location
    Eastern L.I. NY
    Posts
    10,773
    Post Thanks / Like
    Re: Possible damage to my 3401
    Quote Originally Posted by Black Lab View Post
    Well, no attack or anything, but what makes you think that paying a higher price for a tool gives you an excuse to use it incorrectly? If I pay $50 for a Snap-On screwdriver, then I should be able to use it as a pry bar, ice-pick, or hammer? I'll never understand this reasoning
    Quote Originally Posted by kkritsilas View Post
    Hoyt66 did say "...my error was laying to hard on the polisher and not evenly either....". Which by his own admission was causing the backing plate to bend. How does anybody see this as proper use of the polisher? No matter how much you paid for the polisher, if you are bending the backing plate, it will create a problem. It is to the 3401's credit that it continued to turn with that kind of pressure applied to it on my mind. Says a lot about the motor just having the power to do just about anything.
    Just read this entire thread again. Now I see where he says that he used it unevenly.
    My "criticism" was based on the fact that I thought he was just using the unit hard all day long. (a.k.a "Rode hard, and put away wet")
    This being said, with my understanding that the tool wasn't used as intended, but just for a sustained and rigorous period and failed, was my original posts' intention.
    It is no coincidence that man's best friend cannot talk.
  2. #32
    Newbie Member Black Lab's Avatar
    Join Date
    Oct 2016
    Location
    South of Chicago
    Posts
    17
    Post Thanks / Like
    Quote Originally Posted by PaulMys View Post
    No worries, I almost missed the part about it being misused too. I like my Flex polishers a lot, but I'm no apologist for them. I agree with what I think you were saying. For the money, this is a professional tool, and should hold up to being used as such.
    As a mechanic, I've just seen so many people who do actually have the belief that if it's expensive, it should be able to take unusual abuse. I guess it's just a pet peeve of mine
  3. #33
    Join Date
    Jan 2014
    Location
    Eastern L.I. NY
    Posts
    10,773
    Post Thanks / Like
    Mechanic myself. Loved your "Snap-On screwdriver used as a pry bar" analogy.
  4. #34
    Super Member VISITOR's Avatar
    Join Date
    May 2007
    Posts
    9,723
    Post Thanks / Like
    off topic... Black Lab & PaulMys (both of you being mechanics), any good tips on buying a used car other than checking the carfax, body lines, etc,?
  5. #35
    Join Date
    Jan 2014
    Location
    Eastern L.I. NY
    Posts
    10,773
    Post Thanks / Like
    Quote Originally Posted by VISITOR View Post
    Better take BL's opinion. I'm a marine mechanic Allen.
    But, if it were me.. check underneath the car. Check ball joints, shocks, signs of leakage from rear end seals, rear main seals, tranny, inspect the U/CV joints, Check the tranny fluid for anything other than a dark red color, and smell it for a "burnt smell".
    Outwardly, check for ill-fitting body joints (fender to hood, etc.). Not all things (IMO) show up on those CarFax things.
    Ask for service records. Look at the tires. Uneven wear? Wear on the outer tread like the owner didn't give a crap whether the tires were low?
    Stuff like that.......
  6. #36
    Join Date
    Oct 2016
    Location
    South of Chicago
    Posts
    17
    Post Thanks / Like
    OK, I'm sure I'm gonna leave stuff out but...CarFax only works if they report it. If you narrow down to a car you want, the best thing is to bring it to a mechanic you trust if possible. Otherwise, I always bring a scanner with to check for codes and if everything is running within spec. Look for leaks under the car, under the hood and run it on pavement. Some people show cars on grass to hide leaks. Check the oil. Smell for antifreeze under the hood. Check the antifreeze for color and oil contamination, and the level. Pull the trans dipstick and check that it's a reddish color usually, not dark brown. Smell the trans fluid. If it smells burnt, run away. I like to use a combustion leak tester. It checks for CO2 (engine exhaust) in the coolant which could be a bad head, head gasket, or cracked block. You should be able to rent one from a parts store. It's an easy test to do in the field.
    Get down on the ground with a flashlight and check for rust, damage, etc. I almost bought a low mile Town Car until I looked under it and saw the rust creeping up the rockers. Drive it with radio off and listen for unusual noise from the suspension, differential, motor, etc.
    Don't be pressured into anything! "Oh, it's just a 5 minute fix." Sure. Then why didn't you fix it already?
    If you can bring someone with you, do it. I never go alone. I may be a mechanic, but I know better mechanics than me. They can catch stuff that I may miss. And finally, look the person in the eye and ask about the maintenance history of the car. If they're gonna lie to you, make them look you in the eyes.
Similar Threads
  1. Fluid Damage?
    By SpeedDemon77 in forum Auto Detailing 101
    Last Post: 07-02-2018, 10:16 PM
  2. HELP - Damage to Flex 3401 backing plate
    By Nibby99 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 08-07-2014, 11:12 PM
  3. 3401 plate damage
    By ludrady in forum Flex Polishers
    Last Post: 07-03-2014, 03:11 AM
  4. Hail damage
    By mswerb in forum Ask your detailing questions!
    Last Post: 07-24-2013, 12:01 AM
  5. Ever damage someone's car?
    By Meticulous-Detail in forum How to make money detailing cars
    Last Post: 11-28-2011, 06:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
