Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 8 of 8
  1. #1
    Newbie Member
    Join Date
    Mar 2017
    Posts
    8
    Post Thanks / Like
    Swirls on RV gelcoat--Britemax hard to remove
    I have a problem with the Britemax Perfect Prep Fine Polish. I am using it with a white hybrid foam pad, when I put it on and machine it making several passes I have a hard time wiping it off. I use a microfiber cloth but it is so hard to wipe it seems like it is sticky and never comes off. I clean the pad often but this happened right from the start. What am I doing wrong? Should I be using something different, pads, compound, polish? I attached a picture to show the swirls I'm trying to get rid of.
    Swirls on RV gelcoat--Britemax hard to remove-rv-swirl-jpg
  2. #2
    Super Member Rsurfer's Avatar
    Join Date
    Jan 2007
    Posts
    14,093
    Post Thanks / Like
    Re: Swirls on RV gelcoat--Britemax hard to remove
    Sorry, never used Britemax, but you can't go wrong with Menzerna 400.
  3. #3
    Mike Phillips
    Guest
    I have not used the Britemax compounds or polishes so I don't have any experience with them.
    It's hard to see the swirls but from your other thread... here's a question...
    Did you do the first step using a rotary buffer?
    If so then technically you're not trying remove swirls but instead you're trying to remove holograms. As long as you keep using a rotary buffer you're going to have hologram issues. The only way to avoid them is to use a super soft foam pad and an ultra fine finishing polish and cross your fingers.
    If you want to make this super easy get any dual action polisher, the Griot's Garage 6" would be a low cost quality DA polisher. And then get some of this,
    SONAX EX 04-06 1000 ml.
    It's $50.00 for 1000ml which is around a quart and you're going to need this much to re-do the RV.
    One thing I try to tell guys is never skimp when it comes to abrasive technology.
  4. #4
    Mike Phillips
    Guest
    Quote Originally Posted by Rsurfer View Post
    That's another good option and with FG400 you could cut with a rotary buffer and then finish out hologram free using the same product but switching to any dual action orbital polisher.
    I've buffed out more RVs than I want to remember and seriously... it's worth it to do it right the first time.
    CutMax from SONAX is like FG400. It cuts like a compound and finishes like a polish. Can be used with rotary or dual action and wipe off is easy. Both use great abrasive technology.
  5. #5
    Newbie Member
    Join Date
    Mar 2017
    Posts
    8
    Post Thanks / Like
    Yes I first used a rotary but now I have the flex 3401. So I'm going to get the Sonax but what pads do you recommend?
  6. #6
    Mike Phillips
    Guest
    Quote Originally Posted by Roryq View Post
    Good idea getting the FLEX 3401 for a monster job like this...
    Get the SONAX I recommended and then get some 6.5" Orange Hybrid Foam Pads. For something this large I'd get 6 pads. You'll get much faster cutting and polishing by being able to switch over to a fresh dry pad versus punishing the pads and trying to limp around the RV with one or two wet soggy pads. Been there done that decades ago...
    Lake Country Hybrid Power Finish 6.5 Inch Pads 6 Pack
    Gel-coats don't like soft mushy foam pads for any product that is abrasive. Soft foam pad work good for machine applying a non-cleaning finishing wax but that's about it.
    I cover this in my boat detailing book.
    Can't wait to see her all done...
  7. #7
    Newbie Member
    Join Date
    Mar 2017
    Posts
    8
    Post Thanks / Like
    Smile Re: Swirls on RV gelcoat--Britemax hard to remove
    Hi Mike,
    Many thanks to you and AutoGeek. My results are great, my RV looks brand new after using Menzerna 400. This is the best product I have used. Had the new decals install and I am one happy camper. Take a look:
    Swirls on RV gelcoat--Britemax hard to remove-fullsizerender-jpgSwirls on RV gelcoat--Britemax hard to remove-fullsizerender3-jpgSwirls on RV gelcoat--Britemax hard to remove-fullsizerender5-jpg
  8. #8
    Mike Phillips
    Guest
    Hi Mike,
    Good to hear Rory!
    Here's your pictures, I uploaded them to your gallery so they could be inserted and you're right, she looks brand new!
Similar Threads
  1. Gelcoat Polish Question - Removed swirls but also deep gloss? - Pics
    By dnadrifterr in forum Boat & Marine Craft Detailing
    Last Post: 05-31-2021, 04:39 PM
  2. Swirls in gelcoat
    By 58LesPaul in forum Boat & Marine Craft Detailing
    Last Post: 03-17-2018, 09:39 PM
  3. Removing Swirls from gelcoat
    By RJ2244 in forum Boat & Marine Craft Detailing
    Last Post: 05-24-2017, 08:08 PM
  4. swirls on a white car. pretty hard to remove by hand. need advice
    By harris24742 in forum Ask your detailing questions!
    Last Post: 02-14-2015, 03:41 PM
  5. britemax? How 2 remove old mans spray paint
    By pillspillspills in forum Auto Detailing 101
    Last Post: 01-05-2007, 10:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
