Dislikes: 0
Junior Member
Re: RUPES Lhr15es mk11, mini or duetto
Would you go for the 15 or 21. Fund not an issue. Is there a big difference between the two, apart obviously from the bigger throw?
Super Member
Originally Posted by TMQ
Yes custmsprty---I agree. Funds are bit stretched at the moment and that is the reason I opt for griots/thin pro pads for now. Using thin pro pads actually gives the 3" more cutting ability than before. Will cut better than by hand but not as good as mini. Eventually I will pursue the mini at later time.
Tom
You'd be better off getting a PC and putting a 3" backing plate on it, or if you already have a PC put a 3" or 3.5" bp, you can run 3" and 4" pads that way. Much better correctibility than the GG3. That's how I ran until I could afford the mini
2013 Genesis Coupe 3.8 Track Edition
2015 Hyundai Sonata Limited, 2016 Pearl White Nissan Altima SR
2019 Nissan Rogue SL
21 will have more pad spinning torque based on momentum alone. It will cut noticeably faster, BUT, the 15 is no slouch. The 21mm throw makes it less versatile, even with a 5" backing plate.
id go either mark II flex xfe 15(but with 5 in BP) or G15
if you cant afford those, gg6...then when you can afford one of the above you can upgrade GG6 with 3in BP
duetto and mini are under powered(but havent tried them with LC thin pros yet or aluminum BP
Junior Member
Thanks as as always for all the help guys.
decided to go for the 15mm throw mk2 in the end.
very excited to get it now!!
Super Member
You will be amazed at how smoothly it runs with yellow/white Rupes pads. Megs microfiber cutting discs spin well too.
Super Member
What set ups (pad/polish) did you use with them? I find them to be adequately powered.
Super Member
Me too, I love both of mine and find them more than adequately powered.
Super Member
I got a call to take care of some patches of 2000 grit sanding marks with the Zephir/blue microfiber, on a resprayed caddy. It did a very nice job cleaning it up.
Super Member
I guess I can't say whether the Duetto is under powered or not since I have nothing to compare it to, but I really love mine.
It's very smooth running, and I haven't had issues with stalling on concave sections or while edging it. I just let the machine do the work. And like Dlc said, it spins like mad with the washer mod.
If the LHR 15 and 21 are that much more powerful like has been said, then they must really kick but.
____________
"The more answers I seek, the more questions I find."
Similar Threads
By Brendlinger in forum RUPES BigFoot Oribital Polishers
Last Post: 12-09-2019, 09:41 PM
By Mike@ShineStruck in forum RUPES BigFoot Oribital Polishers
Last Post: 02-29-2016, 11:37 AM
By dlc95 in forum RUPES BigFoot Oribital Polishers
Last Post: 08-14-2014, 06:44 AM
By Nick McKees37 in forum New Car Care Products
Last Post: 12-05-2013, 11:34 AM
By Mike Phillips in forum Ask your detailing questions!
Last Post: 11-13-2013, 08:04 AM
Posting Permissions
- You may not post replies
- You may not edit your posts
Forum Rules
S |
M |
T |
W |
T |
F |
S |
25 | 26 | 27 | 28 | 29 |
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
| 1 | 2 | 3 | 4 | 5 | 6 |
Bookmarks
