Super Member
FLEX 3401 on its way out
Good evening all,
I have a FLEX 3401 that is around 7-years old that has a TON of detailing hours on it and I think it's on it's way out (failing) as today I was using it to correct a job and used it for around 8hrs and noticed on speed 5-6 it starts to withdraw itself to what seems like speed 2-3.
it also gets pretty warm on the cast aluminum housing (yes I oil the felt ring).
Not really looking to purchase a NEW unit and wanted to know does FLEX USA rebuild (recondition) their polishers?
Team Flex PE14-2 150(Serial#0005)/3401/3403/XFE 7-15
Super Member
Super Member
Re: FLEX 3401 on its way out
I have not replaced the brushes but that seems like a logical solution to my fix.
Will definitely try that route... Thank you for the reply.
Newbie Member
I have to get one of these machines.
Super Member
Super Member
Thank you for the source for the brushes.
Super Member
Looks like they (powerhousetoolparts.com) are out of stock but replacement parts .com has them in stock.
Super Member
if you're unable to fix it yourself, i would send it to powerhouse. they've been around since the beginning and know everything there is to know about the tool...
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
Super Member
Wow, some hours on that Beast! Glad to hear long term reliability on this machine! I love my 3401!
Super Member
Plus 1 for sending it to Powerhouse if you need a refurbish. I've sent mine there several times with great results.
Bookmarks
