Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Super Member
    Join Date
    Jul 2014
    Posts
    371
    Post Thanks / Like
    another pressure washer is dead, time for an upgrade.....
    Well.... after 2 years in business I have killed my second electric pressure washer, both were Greenworks from Lowes. The first one was replaced under warranty, but after the second failure it's time for a change.
    I've been looking at gas pressure washers, but i'm still reluctant due to the noise and emissions (I sometimes wash cars in my shop when it's too hot out).
    I have been researching the Sun Joe SPX3000 or the AR Blue Clean AR390SS. does anyone have any experience with either of these brands, how are their longevity?
  2. #2
    Super Member Fast Eddie's Avatar
    Join Date
    Oct 2008
    Location
    Commiefornia
    Posts
    513
    Post Thanks / Like
    Re: another pressure washer is dead, time for an upgrade.....
    I have the Sun Joe SPX3000 and a gas pressure washer when I need some serious pressure. That Sun Joe as been decent and works well with my foam cannon, but keep in mind it's just another cheap consumer pressure washer not meant for commercial work and should be considered disposable like the Greenworks ones. These types of cheap pressure washer just don't last if used a lot.
  3. #3
    Super Member
    Join Date
    Sep 2015
    Posts
    6,281
    Post Thanks / Like
    You need a Honda.Those are so tough you couldn't break it if you tried.
  4. #4
    Super Member
    Join Date
    May 2007
    Posts
    666
    Post Thanks / Like
    If you're using it in a professional grade environment, any reason not to buy one that has commercial/professional components ?
    Personally I would stick with electric but this is purely subjective like wax I suppose.
  5. #5
    Super Member
    Join Date
    Oct 2015
    Posts
    200
    Post Thanks / Like
    If you're going to stay with Electric, have you looked Kranzle?
  6. #6
    Super Member
    Join Date
    Jul 2014
    Posts
    371
    Post Thanks / Like
    Quote Originally Posted by chefwong View Post
    At this point it comes down to price. Im recovering from a really slow November/December. So i am trying to keep costs low.
  7. #7
    Super Member
    Join Date
    May 2007
    Posts
    666
    Post Thanks / Like
    I hear ya Matt....it's the balance between buying a new machine every year vs. XYZ on a pro/comm. machine.
    There is no right or wrong decision. It really depends on your situation. I misread your 1st sentence which said ~in business~. In a pro application, one cannot afford that downtime.
    I would not use Kranzle for a electric Matt. It's german, and just like my cars, parts are expensive outside of warranty. Stick with standard fare like general pumps (which parts are relatively inexpensive), etc, etc.
  8. #8
    Junior Member
    Join Date
    May 2015
    Posts
    83
    Post Thanks / Like
    Kranzle is a high quality unit, but as chefwong noted, pricey.
    Honda makes ENGINES...good ones at that. If going gas, a Honda POWERED unit is top shelf...IF it has a quality pump.
    CAT pumps are quality pumps and parts/service is readily available. Can be found on both gas and electric units. Premium price, but not crazy.
    Gas is a bit more hassle than electric.
  9. #9
    Super Member rlmccarty2000's Avatar
    Join Date
    Dec 2013
    Location
    Fitzgerald, GA
    Posts
    2,002
    Post Thanks / Like
    I've got the AR390SS and it's a good pressure washer, but I bought the 3 year warranty with it because I expect it to break down. Buy two so you have a backup. Not knocking this brand at all, just home grade pressure washers in general are not made to withstand commercial use.
  10. #10
    Super Member
    Join Date
    Jul 2014
    Posts
    371
    Post Thanks / Like
    My goal this year was to save up and invest in an electric pressure washer in the $600-$900 range. having this washer fail again i have to grab something that will get me through the year so i can keep on track financially. So fo now it has to be a cheaper "disposable" washer.
Similar Threads
  1. New pressure washer time. Input/thoughts ?
    By bean438 in forum Auto Detailing 101
    Last Post: 04-21-2021, 02:52 PM
  2. Power washer upgrade help
    By scribble79 in forum Auto Detailing 101
    Last Post: 12-30-2019, 01:44 PM
  3. Replies: 12
    Last Post: 12-13-2017, 08:25 AM
  4. My electric pressure washer is dead!
    By BenSRT in forum Auto Detailing 101
    Last Post: 08-01-2012, 08:57 AM
  5. Replies: 6
    Last Post: 10-28-2011, 03:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
