Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Super Member The Guz's Avatar
    Join Date
    Jun 2013
    Location
    LA, CA
    Posts
    8,719
    Post Thanks / Like
    Re: Rupes LHR 21ES Bigfoot vs LHR21 MarkII
    Quote Originally Posted by GoBison22 View Post
    Hi all,
    Looking to buy a new polisher and I have come down to the Rupes LHR 21ES Bigfoot and the LHR21 Bigfoot MarkII. From what I have read, the only differences are the MarkII has the piece on the back of the polisher that allows you to set it upside down and it also has a more powerful motor (by 30%). With that being said, I'm only a weekend warrior/hobbyist, but looking to do more; should I get the LHR 21ES or spend the extra money and get the LHR21 MarkII?
    Being you are a hobbyist, stick with the 15. It will be more than enough and suit your needs. The 21 is good for larger panels.
  2. #12
    Super Member Dylan@RUPES's Avatar
    Join Date
    Oct 2015
    Posts
    215
    Post Thanks / Like
    Hi all,
    Aside from the things you listed there is a rubberized grip on the underside of the Mark II head, the chassis is also redesigned for the new motor - its not outwardly obvious unless you look at a Mark II and an ES side by side, and even then its very subtle. The housing is a little more reinforced to deal with the increased torque levels. Essentially its like we beefed up the motor mounts which gives it a little different feel. Obviously with the increased motor output we remapped the electronics to put the sweet spot in the mid speed range (3-4) to give you speed 5 and 6 as your "NEED MORE POWERRRRRRRRRR!!!!" levels.
    That being said - like someone else pointed out, the 15 is the better detailing tool and for an enthusiast the ES tools still are more than adequate. When you're only polishing your car a handful of times and not doing work for others the added benefit of the Mark II isn't going to be realized. It really starts to benefit someone who does a lot of polishing and stands to save time with the increased power.
Similar Threads
  1. Rupes MarkII
    By joleyred in forum Auto Detailing 101
    Last Post: 01-13-2018, 11:58 AM
  2. Issues with Buff & Shine Low-Pro's LHR21 MarkII
    By VT675 in forum RUPES BigFoot Oribital Polishers
    Last Post: 07-13-2016, 09:18 PM
  3. Rupes Bigfoot 21es
    By Calendyr in forum Products Guides
    Last Post: 09-19-2013, 01:02 AM
  4. Testing Rupes Bigfoot LHR 21ES With M205
    By ihaveacamaro in forum Auto Detailing 101
    Last Post: 06-01-2013, 04:55 PM
  5. Replies: 0
    Last Post: 01-30-2013, 12:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
